Question about Acer H236HL 23" LED LCD Monitor - 16:9 - 5 ms Adjustable Display Angle - 1920 x 1080 - 16.7 Million Colors - 250 Nit - 100,000,000:1 - Full HD - DVI - HDMI - VGA - 26 W - Black - MPR II
My acer monitor H236HL is flickering. my brightness is set to 100%. I've turn eff the power off & on but it doesn't help.
    Sergeant:
  • 291 Answers
This sort of flickering is sometimes reduced by turning brightness up. You have already tried that. My guess this is a PWM led monitor and that characteristic is what is bothering you. There are monitors that do not have the PWM feature. You can safely assume they are more expensive.
Posted on Apr 07, 2015
  • Acer Master
  • 13,433 Answers
check that all the cables are properly connected, if possible test the monitor on another computer.
if the problem persist when connected to another computer, the problem is in the display itself. You could try going into the menu, and resetting it to factory defaults.
if that doesn't help the problem is most likely inside the display, possibly some of the components on the powersupply are worn out. Capacitors typically, which might need to be replaced in order to get rid of the problem.
the problem can also be in the settings of the computer, but if noting has been changed recently then its unlikely.
you can also try another cable, since the display has more than one way to connect to the computer, you could try another type of cable that fits the display and your computer.
if the display is still covered by warranty, after you have checked that the problem is not being caused by the settings of the monitor or by your computer, then you might want to get in touch with your dealer to arrange service / warranty replacement.
Hope it helps.
Ekse
Posted on Apr 06, 2015
I just purchased a Acer model #H236HL to add to my HP computer. It already has a monitor. I have two ports but one is small and one is large. The sales clerk said I didn't need anything else! Help
so as i am getting you cpu to moniter connection ...simply detach and pugin your new Acer H236HL bid 23-Inch Widescreen LCD Monitor With VGA, DVI & HDMI inputs so you can easily power and extend the enjoyment from your smartphone or tablet on Full HD display.
you can even run both....simply....follw the user manual.with your product...any more questions..simply ask me....happy to help
Aug 15, 2017 | Acer Computers & Internet
Can't figure out how to adjust volume on new h236hl monitor
Once you get to Volume mode, use the "<" and ">" keys.
Aug 03, 2014 | Acer Computers & Internet
I need power cord and AC adapter for an Acer H236HL BID monitor
You may want to call Acer support for them to send you a new power cord and ac adapter. Acer technical support number is 1-800-816-2237
May 15, 2014 | Acer Office Equipment & Supplies
Powered but not booting. No visual. HDD light not doing anything.
Remove the RAM and start, see if it beeps and/or shows something on the screen. Try with the external screen too.
Let me know how it goes
Cheers
Jun 27, 2013 | eMachines Acer 350-21g16i Netbook
204b backlight getting dim
change the inverter if it does not work ,you will have to change the backlight bulbs or you change the screen
Jun 22, 2013 | Samsung SyncMaster 204B 20.1" LCD Monitor
Westinghouse L2210NW Monitor Problem My screen is very bright and i believe it to be a hardware issue.(I've tried other monitors on my computer) I have the brightness set to the absolute min and its...
The black splotch your describing sounds very much like something failed on the board and burned the board so now that is a carbon patch that can conduct electric current. With that in mind, I would suggest replacing the board definately
Apr 18, 2017 | Westinghouse Electric L2210NW Monitor
Monitor flickers unless brightness is at 100%
Try monitor menu select Memory Recall and press that, should clear right up
Mar 08, 2009 | ViewSonic VA1912wb Monitor
Acer AL1916 LCD monitor is getting darker!!
sounds like backlight is failing,contact acer and see if its under warranty.
Mar 04, 2009 | Acer AL1916B 19" LCD Monitor
LCD problems
Try turning the brightness all the way up to 100. That seemed to solve the problem for now. I believe neilneves is right that the power inverter is not supplying enough power, but in my case at least, by increasing the brightness the LCD is now receiving enough power to not flicker.
Jun 26, 2008 | Acer AL1717 17" LCD Monitor
Acer AL1715 - insufficient brightness
No there isn't any. there is probably a part that is damaged due to the surge u should get a new one or send it back to the company
Feb 02, 2008 | Acer AL1715 17" LCD Monitor
Acer H236HL 23" LED LCD Monitor - 16:9 - 5 ms Adjustable Display Angle - 1920 x 1080 - 16.7 Million Colors - 250 Nit - 100,000,000:1 - Full HD - DVI - HDMI - VGA - 26 W - Black - MPR II Logo
675 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
