Question about KitchenAid 12-Cup Food Processor Chef&39;s Bowl
Pin dislodged in handle
Pin dislodged in bowl handle
    Top Expert:
  • KitchenAid Master
  • 10,875 Answers
KitchenAid Food Processor Parts
find your processor here and find parts
ereplacementparts has all kinds of parts available!!!
Posted on Apr 08, 2015
  • KitchenAid Master
  • 1,309 Answers
The bowl is a one piece item, not able to be pulled apart and with no parts available for it apart from a complete bowl. The pin will not be just dislodged, it will be broken off from where it belongs.
HOW CAN I TELL WHICH PART OF THE PROCESSOR NEEDS REPLACING WHEN IT WON'T CONNECT
Difficult to tell as I could be a few things.
Motor
Safety interlock
On Off switch
Check the safety pin or whatever stops the power unless the bowl and lid are fully in place. With the blade and bowl off you can defeat the safety by inserting a pen into the hole if it has one or a teaspoon handle into the slot if it has one.
I am a chef and in a commercial kitchen, home type processors last 15 months to 2 years max.
Even if you find the problem your problem will be finding spares unless it is a top brand.
Jan 27, 2016 | Food Processors
Motor won't start when bowl locked in position
Hi, I had the same problem with my KitchenAid KFP740. The fix was the handle cap was loose. We all have a tendency to lift the unit out of the cabinet by the handle and it is heavy! The handle has a mechanism inside. The outside piece of the handle that holds it all inside gets loose making the pin at the bottom of the bowl not reach where it needs to be when you put the lid on. If you assemble the unit and squeeze the top of the handle after you put the lid on mine would work. A little gorilla glue and I was back in business!
Apr 13, 2014 | KitchenAid KFP750 Food Processor
Kitchenaid kfc 3100
Probably the mechanisms in either the bowl or the parts of the lid that engage the bowl mechanisms.
Aug 31, 2012 | KitchenAid Chefs Chopper KFC3100 3 Cups...
How do I remove the cover from the bowl on the EV-11PC9?
The bowl cover needs to be turned (rotated) clockwise a small amount to release the catches on the bowl.
Easiest way is to grasp the bowl handle and press to the left with your thumb on the extension of the cover that goes over the top of the handle.
Remember that the pusher MUST be removed from the cover to do this because of the interlock that goes down through both the cover and the bowl handle.
Oct 10, 2011 | Cuisinart Ev11pc9 Food Processor
Remove pin & replace in work bowl
it takes two to do this. there are two holes on the bottom part of handle. find something strong to push them in. one person pushes them in and have other person with pliers pull on the plug that you need to remove to get to broken pin. after that...replacement is easy
May 14, 2011 | Robot Coupe R2U Ultra Food Processor
I have a Hamilton Beach Scovill Food processor model 712. The "bowl and lid" are cracked and broken. I need a replacement. I have all of the small miscellaneous parts, the blade is in good...
I have the 712 that has everything but the drive pin for the shredder. I also have the manual and replacement parts list. I can't find the drive pin anywhere. I need to either find it or part mine out. Help?
Feb 05, 2011 | Hamilton Beach 70100 Food Processor
It won't go on. Nothing, no noise at all. Does not work
Can you check the safety switches. There are usualy a couple of spots that will cut off power to machine if the bowl is not installed properly. One is at the bottom usually a pin type of setup that tells it the bowl is installed and then a lock on topto make sure the top is on properly. Check to make sure A it is installed properly B thatnone of thos pins have cracked therefor not doing it's job properly
Dec 14, 2010 | Oster 3200 Inspire In2itive Food Processor
It will not start no matter how well everything is in place and locked.
I had the same problem until I called Cuisinart. The handle of the bowl needs to face you. Have you tried that as well?
Jul 25, 2009 | Cuisinart DLC-5 Food Processor
Motor runs but switch won't activate despite new parts
Make sure the handle of the bowl is facing the front of the food processor. Place the lid tab just to the left of the handle and slide it toward the handle until it won't turn anymore. Remove the pusher sleeve from the lid and reinsert it with the lock facing the front of the food processor. Slide the lock into the locked position. If it still doesn't work, replace the third piece on the work bowl - the one piece that you haven't replaced. It will then work.
-Tha Mp3 Doctor
Jan 10, 2009 | Cuisinart DLC-8S Pro Custom Food Processor
My food processer does not work
I had the exact same problem. The red light came on when I hit the "On" button, but nothing happened. Then I noticed that when the lid is locked into place, a small pin in the handle goes into a small hole in the base. I took a wooden chopstick and poked it in this hole in the base, and the unit started running. I put the bowl and lid back on the unit and locked them into place, and this time the unit ran just fine. Yeah! I will remember this the next time my unit won't run even though I know that I've properly locked down the bowl and lid. Good luck!
Oct 11, 2007 | KitchenAid KFP750 Food Processor
KitchenAid 12-Cup Food Processor Chef&39;s Bowl Logo
412 people viewed this question
Top KitchenAid Food Processors Experts
xalint1
xalint1
Don Eagan
Are you a KitchenAid Food Processor Expert? Answer questions, earn points and help others
