Question about Kenwood Car Audio & Video
I have a Kenwood kac-x301t and 2 Kicker compvt svc 10" subs in a sealed box. How do I connect them to get the best sound and most power?
zzedly
  • 300 Answers
SOURCE: Kenwood KAC-9152D monoblock
The amp says it's 1 ohm stable, so assuming the DVCs are dual 4 ohm, you should be able to connect all "+"'s together and all "-"s together, like the picture below:
As for the amp shutting off for a few seconds, it sounds like it's either:
A) Not getting enough power at high volume.
OR
B) Overheating.
The cap on the +12V to the amp should help, but putting a meter on the +12V might tell you whether it's dropping too low (<11V).
When you first turn the volume up, how long does it work fine before shutting off? Is it with the vehicle running or not?
Posted on Mar 25, 2008
SOURCE: Rockford Fosgate 800a2 To 2 SVC 2ohm subs
Ok.. Bridge the two sub into 4ohm than bridge to amp.
So. this how it goes.
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
This will use the full potiental of RF 800a2 amp. I believe it like 1153 watts max out.
Posted on May 29, 2008
Hazardsneon
  • 100 Answers
SOURCE: how to install kenwood kac-9102d in 2006 acura rsx
My recommendation is to get a line level converter. Go to a car audio shop or even best buy and specifically ask for a line level converter. It will have speaker wires in and RCAs out. Connect the speaker wires to the sub woofer speaker wires and then you will have the RCAs to run to your amp. I hope this helped.
-Andrew Hawkins
Posted on Aug 29, 2008
wikkidd420
  • 96 Answers
SOURCE: want to bridge my subs I have a kenwood kac-719
from what i have read about your amp, it is already a mono amp, and rated for 2 ohm's, so all you have to do is wire the subs in parallel (both positives together to positive and both negatives together to negative) or series/parallel if you have dual voice coils (both positive and both negative paired on each sub, then positive from amp to positive on one sub; negative on that sub to positive on next sub; then negative on sub to negative on amp) Note though, with two dual voice coil subs, you can have a 1 ohm load with the first set up, which can damage your amp. Let me know if this helps :)
Posted on Jun 11, 2009
craigperry23
  • 185 Answers
SOURCE: I need to know how to wire 2 Kicker comp 10" subs
you can find your wiring diagram here
http://www.crutchfield.com/S-lCf6ewrWNQM/learn/learningcenter/car/subwoofers_wiring.html
Select from the list shown which describes your amp and subs (ie 2 channel amp with 2 4ohm subs)
Hope this helps and please rate, thanks
Posted on Mar 19, 2011
I a looking to qire two 10 inch kicker comps what is the best way to get sound out of this set up in a sealed box and kac 7252 amp 1000 watt
check the ohms on the subs if its single 2 ohm make sure you dont bridge it avoid 1 ohm unless the amp is class d duel 2s make 4 or 1 depending on if you series on paralel them duel 4s make 2 ohms or 8 you want to make a duel 4ohm 2ohm and put one on each chanel email me for better exp.
Feb 05, 2010 | Kenwood KAC-7252 Car Audio Amplifier
Have kenwood mono amp 4,2,1 ohm capabilitie. What is the best sub to run. The amp is 1600 watts, howmany ohms and 1 or 2 voice coils.
Hello pelikant75,
The best answer depends on your budget for the sub(s) and exactly what kind of sound you are looking to get. Your amps RMS output at 4 ohms is 200 watts and at 2 ohms, it's 400 watts. I could not find that it was 1 ohm stable.
If you are looking for the absolute best bang for your buck, I would highly recommend a pair of entry level MTX 10" subs, model 4501-04, currently priced by Crutchfield at $49.99. And if you buy a pair, they throw in a free Bass Slammer BS210S sealed enclosure. The MTX's power range is 112.5 to 225 watts each, right in there with your amps output. 2 of them in parallel give you a 2 ohm load, just right for your amps best power. And they sound great. You simply can't find a better deal for $100 bucks!
If you want a little better SQ, a pair of Rockford-Fosgate P1S410's should be considered. Again, going to Crutchfield, they currently have this one "BOGO" (buy one get one) for $99.99. You will have to provide your own box, though, no free one with these.
Finally, if you want the best SQ, and your budget allows, consider a set of Alpine SWR-1022D's for $179.99 each. These have dual 2 ohm voice coils, allowing you to series the coils and parallel the subs, resulting in a 2 ohm load to you amp just like the MTX's and RF's recommended above. You will probably want a somewhat larger enclosure for the Alpines as well as a fatter wallet. Your amp is right at the lower end for powering them, so they probably will not be as loud. But they will sound good.
One thing we haven't discussed is the box. The enclosure is just as important, perhaps even more important than the sub(s). More accurate bass is generally produced from a sealed enclosure. A ported enclosure will be louder, but at the expense of sound quality. And whether it's sealed or ported, the enclosure needs to have enough internal volume for the particular sub you are planning to use. A sealed box in the range of .75 to 1 cu/ft will be OK for any of the recommended subs. Add about 15-20% more volume for a ported box and keep in mind that the port needs to be specifically sized for the frequency for which it is tuned.
Hope this helps.
Apr 12, 2009 | Kenwood KAC-8101D Car Audio Amplifier
My sub flickers on and off in my truck!!!
could be a number of things loose wires bad ground fuse on its way out or internal problems
Feb 13, 2009 | Profile BAJA HA700M Car Audio Amplifier
Adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Jan 02, 2009 | Kenwood KAC-9103D Car Audio Amplifier
Install my Kenwood KAC-9102D in my 2006 Acura RSX Type S
You will probably need to use a Line Output Converter (LOC). They're available at virtually any shop that sells car audio.
Many times, the outputs of the OEM amplifier will have significant DC voltage on them. This could damage the input circuits on the kenwood amplifier.
Let me know if you have any other questions.
Aug 24, 2008 | Kenwood KAC-9102D Car Audio Amplifier
How to install kenwood kac-9102d in 2006 acura rsx
-Andrew Hawkins
Aug 24, 2008 | Kenwood Car Audio & Video
OR
B) Overheating.
Mar 25, 2008 | Kenwood KAC-9152D Car Audio Amplifier
sub1 + -
to      | |
sub2 - +
=      4ohm
           From Sub
                Two
amp (L) - + (R)- +
Sep 26, 2007 | Rockford Fosgate Punch 800a2 Car Audio...
Kicker solobaric l5 12''
how to wire a kicker solo baric l5 12'' 4ohm down 2 and 1 ohm
Sep 25, 2007 | Car Audio & Video
Car Audio & Video Logo
85 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
