Question about Welding Tools
1965 portable welder model 400037 300Amps 40Volts rheostat burned out. What is there for a replacement
  • Dave Carlberg
    Dave Carlberg Apr 06, 2015
    The welder is a Stick welder with the serial# 12CW39551 spec 4296. This is a large portable welder used at a construction site
    Top Expert:
  • Welding Tools Master
  • 45,301 Answers
Contact the mfg only they will know .
Posted on Apr 06, 2015
Hobart beta mig 170 wire feed wont adjust
The variable speed motor runs on 0-24VAC controlled by the speed control dial. The dial may be toast. Replace this part first. You may verify the part failure by using a bypass wire to see if the motor runs at maximum speed without the control dial (rheostat or potentiometer).
Sep 02, 2014 | Welding Tools
Hobart beta mig 170 wire feed wide open
Replace the wire feed potentiometer or rheostat control.
Lincoln pro core 125 won't feed on c or d
If this is an old machine the reason it's not welding on C or D set is because the voltage control rheostat it's worn out or just dirty. Open your machine and take the rheostat out (also know as petentiometer) and inspect it for carbon build up along the spring try to clean it with a stainless steel toothbrush if problem persist then just buy another control.
Feb 24, 2014 | Welding Tools
My wire feed welder wont slow down. I was welding some thick galvanized pipe and went to turn the wire feed down and it didn't work
the speed feed rheostat(control) is shorted or you've got a short on the board if it has one. Hopefully just your switch. Check for a short from the switch to the drive motor. Remember, electricity can and will kill you. Be safe
Bryan
Nov 04, 2013 | Lincoln Electric Lincoln Easy MIG 140...
I have a miller econotig and the amp rheostat seems not to respond when turned to a lower setting
Wendell,
Call the Miller Help Desk at 920-735-4505 and ask for parts. Give them your machine s/n and they will get you the replacement rheostat. Good luck.
Jan 31, 2012 | Miller Welding Tools
My 220at keeps on burning back up into the tip? is
Hi James, There are a couple on things to check on, firstly there is usualy a clutch unit - a bolt- which is used to stop the reel spining on after release of the triger, if this is too tight, then the wire will burn back.
Secondly, check the front pannel for burn back control this alters the stick out of the wire.
thirdly, dont have the nozzle too close, 1/2 to 3/4" from the work would be good. lets know how you get on.
Ken
Jan 25, 2010 | Welding Tools
Wire feed always full speed
Wire speed is controlled by the rheostat attatched to the speed control knob on the front of your welder/Unplug unit, take it apart and see if there is a loose connection going to the rheostat. If all connections look good, either the rheostat is bad or there is a break in the wiring under the plactic coating on the wire that you cannot see. Good luck
Jul 03, 2009 | Welding Tools
Wire feed not working Miller 250 mig welder
If the knob spins all the way around (and especially of it didn't always do that), it's broken. This could mean that the nut that holds the rheostat in place has come loose, or it could be that the wiper inside the rheostat has broken off the shaft. To find the voltage measurements, correct schematics, etc, I'd need to know the serial number of your welder.
Regards,
Carl
Feb 22, 2009 | Miller Welding Tools
Snap on welder ya212a
check that the liner is fully plugged in and twisted to the correct position. Also, if there is a speed rheostat, give it a turn back and forth.
Dec 22, 2008 | Lincoln Electric LINK2400-+1 CV-305 MIG...
No power to weld or use A/c power outlets
You don't say what model welder you have, some Miller welders have 3 slip rings and brushes some have just 2. In either case the next step is to use an ohm meter to check the resistance of the rotor and brush assembly. If this is a 2 slip ring model, take one of the wires off of one of the brushes then measure the resistance between the 2 brush terminals - it should be something between 10 and 100 ohms. If you get an open circuit measure the resistance from one slip ring to the other right at the slip rings - if you now get something other than an open you've got bad brushes (about $10 each to replace),
The 3 slip ring models are similar but have 2 rotor windings - take off the wire from the middle brush and measure from it to each of the ends.
If your rotor and brushes checked out OK you should next check the fuse in the exciter circuit, this will be on the block where the other end of the brush wires go.
If the fuse was good you need to do an excitation test. This is a bit dangerous so be careful. Look at the schematic pasted inside the case and figure out which brush is the positive (+) one. The wires are numbered and so is the schematic so this isn't as hard as it might seem.
Disconnect the wires from both brushes (all 4 wires in the 3 slip ring model) and tape them off so you won't get shocked. Get a 9V battery or make up jumpers that will let you connect the welder battery to the brushes. Start the welder and connect your temporary power supply, measure the AC at the outlets (it should be around 60VAC with a 9V battery) and the DC voltage at the weld terminals (should be above 10V), lastly measure the voltage at the wires you disconnected from the brushes (should be around 70V DC). Disconnect the temporary power supply and shut down the welder.
If you didn't get AC at the outlets and DC at the weld terminals above, something is wrong with the stator in your welder. If you didn't measure any DC on the wires that go to the brushes (most likely thing to happen), you've got something wrong in the exciter circuit. Check the rectifier, the capacitor, the exciter winding in the stator, and lastly the current control board. Older welders will also have the fine current control rheostat in this circuit (look for burned windings on it).
That's about all of the general advice I can give you without knowing more about which welder you have.
Carl
Oct 23, 2008 | Miller Welding Tools
Welding Tools Logo
146 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
