Question about LG Televison & Video
The remote control buttons have been pressed by mistake the television went off when turned on again there is a black screen with the LG cube rotating and underneath the wording Not Programmed
  • 46 Answers
Locate the menu, go into channels and search for channels.
Posted on Apr 04, 2015
I hit the wrong button on the remote, and the tv now saids no signal. How do I get back to the channel the tv was on
hit the source button again that is for your scat press down to 1 HD should get you back on.
Jan 10, 2015 | Televison & Video
Black screen!!!
his is what I have found out so far the YSUS PC board is your problem
Part number 6871QYH045B I have a call into Haier to see if I can get this
I did a search on the web and found a couple but none in the US
so if someone can traslate these sites and help out
http://www.soel.com/view/catalogo/f...278763_&lang=en
It also seems the LG uses the same board
http://monitor.net****/forum/topic138985-0.html
Jan 21, 2008 | Haier 42EP24S 42 in. EDTV-Ready Plasma...
I have an LG, LCD TV, I have picture but no sound
some times you have to turn it off, unplug it, wait for 20 secs and plug it in again and turn it on, this would be the last step after trying the remote control thing, you know, check if mute buttom or volume, or the languaje option, good luck, God bless
Jan 26, 2011 | LG 42LB1DRA 42 in. LCD Television
Took radio from car would like to put it back but dont have the instruction manual to imput the code properly car make and model renault clio authentique
It all depends on the radio make+ model.
Most RENAULT have the PHILIPS radio with a remote steering wheel control.
Here are the Code Entry Instructions
Philips Renault Code Entry (For cars with a Steering Wheel Remote Control.)
Note: If your car does not have this remote control, then please ask again for alternative instructions )
Turn on the radio and the display will show 'CODE'
Use the Steering Wheel Remote Controls for code entry.
Press the [ ¬] button then rotate the thumb wheel for the correct first digit
Press the [ ¬] button then rotate the thumb wheel for the correct second digit
Press the [ ¬] button then rotate the thumb wheel for the correct third digit
Press the [ ¬] button then rotate the thumb wheel for the correct fourth digit
If the correct code is now shown on screen,
press and hold the [ ¬] button for up to 10 seconds to store the code
May 17, 2010 | Car Audio & Video
Need Time Warner Remote code for LG 42LB5D HDTV
For Time Warner Cable digital remote controls to work with your 42" LG HDTV, do the following:
1. Press "TV" and "OK" simultaneously for 3 seconds, until the button "tv" light on the remote is on.
2. Enter the TV code. In this case, it's "113". With the right code, your component will turn off. Quickly press the power button on your digital cable remote to turn it back on. Press the "TV" button again so that the remote saves that code.
3. You should be done.
Feb 08, 2010 | Directed 434MHZ Remote Control
I went to turn on my Vizio and the scrren was
Do you have back light when turning on the TV? if you do then just replace the main board should resolve the problem. if you do not have back light, you will need to replace the inverter board(s) depending on your model. The inverter board(s) is located on the left side of the TV facing back of TV. you may have two inverter boards depending on your model. the other is located on the right side of the TV. Both mount vertically.
Jun 17, 2009 | Vizio L32 32 in. LCD HDTV
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Reseting lamp counter (LG)
Make sure the TV is on and:
1) Press and hold the Menu button on your TV SET
2) Press and hold the Menu button on your REMOTE CONTROL (at the same time)
3) Continue holding BOTH buttons down for 5 secconds or until the Service Menu pops up
4) Release the MENU button from your REMOTE CONTROL, then release the MENU button from the TV Set.
5) Press and hold ENTER (or OK) on the TV Set, then:
6) Press and hold MUTE on the REMOTE CONTROL (while still holding down the ENTER button on the TV SET
7) Holding both buttons down should lead to the Lamp Life Hours screen to pop up.
Release the MUTE button the REMOTE CONTROL, then release the ENTER (or OK) button on the TV Set.
9) Come back to this blog and post your HOURS on our site
10) Now press SELECT, then SELECT again to confirm the reset of the counter
** If the procedure above does not work swap steps 5 & 6.
** For a few special models (including 44SZ8D), you might have to change step 5 to:
5a) Press Enter on the TV Set to enter the Position Adjustment Screen
5b) Press and hold Enter on the TV Set (the TV should go back to the main Service Menu, continue holding Enter) and now also hold down the MUTE button on your REMOTE CONTROL. After about 5 seconds, your Lamp Life Counter should pop up.
Jun 30, 2008 | Televison & Video
Televison & Video Logo
Computer Repairing
Computer Repairing
