Question about Samsung Washing Machines
Machine is on but will not run; what could my problem be? Model number WA80V3
All filters have been cleaned, water faucet turned on... machine comes on, set program, then it does absolutely nothing. Help please? Samsung WA80V3
  • Samsung Master
  • 5,323 Answers
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
Posted on Apr 13, 2015
Water coming through at trickle
Although you have not shared the make, model, and year, I will give it a try anyway.
Start by turning off the water at the faucets for the washer.
Then unhook the hose ( or both of them) and attach a garden hose to the faucet, and run the hose outside, or if that is not possible, run the hose to a sink or a shower or a tub, for the drain.
Turn on the water faucet and see if you get good pressure through the water hose.
If you do, then examine the black hoses from the faucets to the washer.
Often these have a tiny wire mesh filters inside the end or ends of them to filter the incoming water.
These can plug up with sediment, and you will need to clean them.
If they are clear, then examine the attachment on the back of the washer, where the hoses go.
These can also have tiny wire mesh filters inside, that can plug up with sediment.
Those screens can be removed and cleaned.
God bless your efforts.
Dec 19, 2016 | Washing Machines
Why does my Samsung washing machine wa80v3 not wash, spin or drain. ?
There are a few things that could cause this, first of all check the lid switch. That is a safety thing that makes sure the lid is closed before it allows it to start washing or spinning. Some other culprits could be a clogged filter, or a broken belt ( if your model has a belt) does the machine sound like its trying to wash? or does it just turn off and do nothing like its dead? if it seems dead its more than likely the lid switch, they are about $40 and simple to replace.
Jul 15, 2014 | Washing Machines
Explain erroe 4E
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Jun 05, 2012 | Samsung WF337AA Front Load Washer
Describe your 4E problem in samsung front load Problem
Thanks for using FixYa!!
Sep 19, 2010 | Samsung WF203ANW Front Load Washer
Samsung model WF8602NHS showing error message 4E
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Sep 03, 2010 | Samsung WF306BHW High Efficiency Front...
I have a samsung 7Kg J845 front load washing mechine, when i turn on, water not fills enough ( only water fills couple of seconds after stops flows. the error shows 4E, Then i clean up all mesh filters...
Aug 08, 2010 | Samsung WF203ANW Front Load Washer
Samsung B1245 front loader
Mar 15, 2009 | Samsung B1245 Front Load Washer
My samsung washing machiene keeps coming up with the error 4e. what does this mean?
Mar 15, 2009 | Samsung WF337AA Front Load Washer
Inlet tube on washing machine
Jan 21, 2009 | Washing Machines
Washing Machines Logo
205 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
