Does it come with usb cable? Can I connect it to imac (desktop computer)?
  • Sean Cole
    Sean Cole Apr 13, 2015
    Hi There. Does what come with a USB cable? The iMac itself has a number of USB ports. Sometimes the keyboard has a usb cable (if it's not wireless) as does the mouse. What do you want to connect via USB?
  • Computers & ... Master
  • 2,825 Answers
Depends on what "it" is. Printer? Scanner?
Most likely it won't come with USB cable.Get one, they're not expensive.
Posted on Apr 13, 2015
Does it come with usb cable? Can it be used as speaker for apple imac desk computer?
The question is not clear...
Does what come with a USB Cable?
No A Mac doesn't but the peripherals often do.
Any computer store sells USB cables for a multitude of purposes
Cheers
Apr 04, 2015 | Apple Computers & Internet
How do I get my Targus TGR-MSD500 to work with my iMac desktop
Rear USB ports may not be connected - check cabling. But possibly you only have two USB ports on motherboard.
Sep 26, 2014 | Computers & Internet
Cannot print says printer offline
try different usb port, try different usb device to see if port is working try different cable.
Apr 16, 2014 | Apple iMac Blueberry Mac Desktop
I Need drivers for iMac 10 that work with Micronet PHD16072u2f
Hi, seeing that this drive has both USB and FireWire connectors it does not need any drivers. - In fact I have never needed drivers for any external drive in all of my 20+ mac years.
First thing to check is that the drive is powering up. Can you feel it come on and off when you turn the power on and off?Try connecting via the FW or the USB in turn (never together). TYry different cables - there are poor cables of both sorts.
If there is still nothing, try connecting something else to the same connectors of the computer - does it show up?
Sometimes the built-in USB hub can throw a wobbley - as can the FW hub. Resetting the USB hub is normally done by rebooting the computer. Resetting the FW is a little more complicated and varies from Mac to Mac - so check out on the Apple support pages at Apple.com the correct way to do it for your particular Mac.
Mar 26, 2013 | Computers & Internet
IMac deactivates USB port when I connect my Nikon P300
Try connecting the camera directly to the computer, without going through a hub. If that doesn't work, then buy a card reader.
Apr 20, 2012 | Nikon Coolpix P300 26246 4.2x Fast F/1.8...
Locks frequently and restarts sometimes all by itself. Parts of the screen regularly skews in triangular shapes.
  • Verify that the power outlet you're using is good and your power cable is firmly connected to the wall outlet-if using a surge protector, be sure that it's firmly plugged into the wall outlet. Also, try temporarily plugging directly into the wall outlet to eliminate any issue with the surge protector; plug a different electronic device into the same wall socket to make sure the socket works, and also try the iMac's power cable in a different wall outlet.
  • Make sure the computer's power cable is firmly connected to the computer.
  • If any external devices are connected to your iMac, disconnect them and try to turn the computer on again. If the iMac will power up when those devices are removed, but not when they are connected, contact the manufacturer of those devices for assistance.
  • Try resetting the iMac's SMC
  • Remove and reinstall the SO-DIMM memory modules, located in the bottom of the computer.
  • Resetting the SMC for Mac Pro, Intel-based iMac, Intel-based Mac mini, or Intel-based Xserve
    1. Shut down the computer.
    2. Unplug the computer's power cord.
    3. Press and hold the power button for 5 seconds.
    4. Release the power button.
    5. Attach the computers power cable.
    6. Press the power button to turn on the computer.
Nov 12, 2010 | Apple 2.16GHz iMac Intel Core 2 Duo...
Kensington cable lock
Kensington lock slots are universal. Any Kensington or similarly branded laptop/computer lock will fit any iMac, and Macbook, Macbook Pro, Mac Mini, or Mac Pro.
Apr 16, 2010 | Apple iMac G4 20" Mac Desktop
I have a sony e-reader prs-600. I plug in the reader using usb to my iMac (which is new) and it doesn't charge. I use a usb to electrical outlet converter (not sure of name) and it doesn't charge. I can...
Please turn OFF the Reader and press the Reset button using a sharp pointed object to reset it.
Next, please connect the Reader directly to a different USB port of the Computer using the supplied USB cable.
Now, please allow the Reader to charge for 2-3 hours and check if it charges. This should resolve the issue.
However, if the issue persists, please try connecting the Reader to a different Computer to confirm if the issue is with the Reader itself.
If the Reader is charging with a different Computer, there might be an issue with the iMac, else, with the Reader.
Note: please ensure to connect the Reader directly to the Computer using the supplied USB cable.
Mar 01, 2010 | Sony Reader Touch PRS-600
I am a novice on these things I want to use my portable hard drive as a back up for my Imac I connect the cable to unit one end to computer and where do I connect other cable piece? to the modem?
The portable hard drive's cable is connected to the computer's USB port (socket). The computer will see this as an external hard drive. You can open and create a folder on this hard drive and copies the files such as music, data etc from the computer to the portable drive.
Sep 16, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
No scan with imac
Make sure that the hardware is functioning correctly.
Restart the product and the computer
Manually check the USB connection between the product and the computer
Make sure that the USB cable is connected correctly to the product
Test the USB connections and restart the computer
The USB cable is connected to a USB hub or a docking station for a laptop
or Desktop.
Fully uninstall and reinstall the HP software
Use the MSCONFIG utility to enable the Startup software
Try the scan again
If the scan is successful, the issue is resolved.
Aug 09, 2009 | HP PSC 1510 All-In-One InkJet Printer
Computers & Internet Logo
299 people viewed this question
David Payne
David Payne
