Question about Baby Gear
Can I make Harlhy seat fit? - Baby Gear
Does Maxi cosi pebble car seat cover fit to maxi cosi mico car seat?
Hi
We wouldn't advise a Pebble fabric on a Mico as the models are a different design so the Pebble fabric wouldn't be an optimum fit on the Mico model.
For replacement Mico fabric contact crelations@djgusa.com
Apr 25, 2013 | Maxi-Cosi Mico Infant Car Seat
I have a quinny buzz 2005 frame will a replacement seat unit fit this and will the carry cot fit please
Good Afternoon
The original Quinny Buzz 2005/2006 chassis is not suitable for fitting the current seat fabric. However you can purchase a sub seat (seat frame) which will fit onto your chassis (RRP 75GBP) and the current seat fabric will fit onto that (RRP 40GBP). The Quinny Dreami carrycot is suitable for use on any Quinny Buzz chassis. You can order the sub seat and seat fabric via your local Quinny retailer or direct from the customer service department on 01284 413 141 Mon-Fri 8.30-4.30.
Jan 11, 2011 | Quinny BUZZ 3 Capri Stroller
Infant car seat to fit lanos ?
fit the baby seat in the rear no problem ,it is extremely dangerous to use a front seat mounted one as dont think that this vehicle has the option to turn the front airbag off .if you move the seat back it will fit but its at your own risk .
Jun 15, 2010 | 2000 Daewoo Lanos
Can a buzz seat fit speedi frame
No unfortunately not. The Quinny Dreami carrycot can be fitted as can a maxi cosi car seat using adaptors but not the buzz seat unit.
Mar 06, 2010 | Quinny Buzz Three Wheel Stroller
Need to fit rear seats in vw t5
this is a mind field mate. what u SHOULD do is go to a proper coachworks and have the seats peopley fitted by them. for this you have to by seats which have been certificated (£500 - £1000) 4 two seats, and have them fitted which also requires a certificate (£300 - £500) but they want to fit their own seats . . . extra costs! ! also VOSA should inspect the seats and change the REG docs to the van . . . EXPENSE EXPENSE. . . what i did on my T5 was had a garage fit me some second hand seats which i got off e-bay with seat belts etc. they invoiced me saying the seats are fitted correctly and to current regulations. i phonned my insurance got them insured (£30) so covered my self in the event of a problem! ! also worth mentioning the MOT stations dont know anything about it . . . (i told them about the certificates needed) - For more info contact VOSA - coachworks fitters - seat companys on the net
Hope this helps you will need to do alot of digging m8 ! ! d.jenkins
Jan 03, 2010 | Baby Gear
How to fit carry cot to car
I assume you are referring to the Matrix Pro Car Seat that lays flat? You can fit this in two different ways. To fit it sitting upright, make sure it is in the most upright position and facing the back of the car. Pass the lap belt underneath the car seat itself, through the blue catches, then plug it in. The long part of the seat belt goes around the back of the car seat through the blue catch nearest you. Pull it all really tight and it should be more secure. To fit the car seat laying flat, this depends on your car. It needs to use two 3 point seat belts. 2 point seat belts don't work. Plug in both seat belts, and pull the lap belt part through the silver catch on both side. Pull as tight as you can. To make car seat fitting more secure, try placing a slip mat like the Sunshine Kids Grip It or Super Mat underneath to hold it in place. These are all crash tested and safe.
Sep 12, 2009 | Baby Gear
Front seats
Yes it will fit in perfectly.
cheers.
Do rate this please.
Apr 22, 2009 | 1993 Ford Festiva
Elongated toilet doesn't fit where a round toilet was installed
Hi. There are toilets designed to accept a round seat and there are other toilets designed to accept an elongated seat. The primary difference is that the round seat fits a round bowl and the elongated seat fits an elongated bowl.
I recommend that you return the elongated seat and exchange it for a round toilet seat. good luck
Jan 31, 2009 | Kohler - Toilet - One-piece - Gabrielle -...
Cant fit solofix car seat into a toyota
any mums that can answer this ??when i done a bit in the car hire and got collared with fitting these baby seats i would put the seat in then so keep it tight i would wrap the seat belt around the head restraint that stopped the seat moving around.
Nov 02, 2008 | 2004 Toyota Corolla
Baby seats ( fitting inyour car with correct seat belt
all cars have lap seat maybe to top and the bottom of the belt are connected together but that our lap belt what kind of car i look at it for you thanks for using fixya pierre
Feb 09, 2008 | Baby Gear
Baby Gear Logo
205 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
