Carry out following work:
Removing:
Undo and remove bolts -4- at top from radiator grille -1-.
Lever out spreader rivets -3- (Qty: 4) from below using a screwdriver.
Push thickness gauge -6- with the thickest feeler (1 mm) into space between radiator grille trim -2- and clip -5-.
Note
This releases the latch -arrow-.
Using the front end hook -3370--7-, pull the radiator grille trim -2- out of the clip -5-"carefully" in -direction of arrow-.
Fit on the right-hand side.
With help of a second mechanic, pull radiator grille trim -2- parallel out of the clips -5-.
Caution
Radiator grille trim -2- is seated very tightly in the clips -5-.
Remove bolts -2- on left and right.
Remove radiator grille -1- upwards.
IF U NEED FURTHER INFO LET ME KNOW..
Testimonial: "thanks for that your info was spot on"
