Question about Samsung Washing Machines
Machine is on but won't run; what could my problem be?
All filters have been cleaned, water faucet turned on... machine comes on, set program, then it does absolutely nothing. Help please?
    Genius:
  • Samsung Master
  • 1,585 Answers
Check door inter lock
Posted on Apr 13, 2015
  • 3 Answers
SOURCE: i cant get the filter out of my washing machine help please
DO NOT keep trying to force the filter, especially not with pliers! Mine wouldn't turn, and when I eventually got it out it was because a coin was stuck in there! Rattle it left and right many times to free the coin, and eventually it will come out, but if you force it, either the plastic filter will break or the coin. Guess which?!
Posted on Oct 29, 2008
Sometimes a bigger object might block the filter knob, and make it impossible to screw out. Then the only way is to remove the end of the sump hose attached to the filter and remove the stuck object.
(In my filter this object was an Umbraco key) :-)
Posted on Feb 09, 2009
SOURCE: Samsung P1253 Filter Clean
I bought a new FI_ICKER
Posted on Feb 10, 2009
SOURCE: lg 801 3f washing machine. 15 seconds after selecting any cycle a
I had the same problem. Redistributing the clothes inside the machine seems to do the trick. Even though the clothes seemed evenly distributed and I had far less than maximum capacity in the machine- it seemed to think that something was out of sync- simply moving the clothes around did the trick!
Posted on Oct 05, 2009
  • 215 Answers
SOURCE: water coming out of drawer & door
Hi Gary,It sounds to me that you have a blockage within the pressure systemas this is a classic sign. If you take the top off the machine you will see a round switch with a few wires going to it.This is the pressure switch. at the bottom of this switch is a thin pipe,normally black or clear. there is a small spring clip holding this pipe to the switch, If you remove this pipe and gently blow down it you will probably find it is blocked. You will then need to follow this pipe to the bottom of your machine. At the bottom of the machine where this pipe is fitted you will see there is a chamber and it is this chamber likly to be blocked.Some times you may clear this with a small piece of wire by removing the small pipe and poke wire through, but best way is to see how this chamber is removed and remove it for cleaning.Ensure machine is off at mains. this chamber fills with water and causes air pressure within the switch at the top of machine, which in turn tells programe when machine is full and also when empty. If this fails then machine will not turn off water supply as long as it is on. there fore when you reconnect parts ensure they are tight and clips back in place. Good luck and hope this works. Failing this working you may need to call an engineer to check switch and possible fault on board.
Posted on Feb 13, 2010
I have a simpson 9.5 kg washing machine an ezi you put powder in and it wont fill you turn the settings to fill and it wont work any ideas i was working fine then now it wont fill up
Power off the machine. Close your wall faucet which brings water into the machine. Unscrew the nut, hold a bag or bucket to collect water coming in from the wall, gently open the water control to see if water flows - the flow should be in good pressure. If it is good, close valve; now open the other end of the pipe going into your machine. You will see a fine filter connected to your machine; clean this out if clogged with an old toothbrush; clean out your pipe too. Refit carefully both nuts, without cross-threading; open the wall faucet to check for leaks. Things should be fine.
Mar 01, 2015 | Simpson Washing Machines
Explain erroe 4E
When error message 4E is displayed, you should clean the water hose mesh filter. To do this:
1. Turn off the water source to the washing machine.
2. Unscrew the hose from the back of the washing machine.
3. With a pair of pliers, gently pull out the mesh filter from the end of the hose and rinse it under water until clean. Also clean the inside and outside of the threaded connector.
4. Push the filter back into place.
5. Screw the hose back onto the washing machine.
6. Turn on the faucet and make sure the connections are watertight.
Also, please check the following:
• Make sure the source water faucet is turned on.
• Check the water pressure.
Jun 05, 2012 | Samsung WF337AA Front Load Washer
Describe your 4E problem in samsung front load Problem
Thanks for using FixYa!!
Sep 19, 2010 | Samsung WF203ANW Front Load Washer
Samsung model WF8602NHS showing error message 4E
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!!
Sep 03, 2010 | Samsung WF306BHW High Efficiency Front...
I have a samsung 7Kg J845 front load washing mechine, when i turn on, water not fills enough ( only water fills couple of seconds after stops flows. the error shows 4E, Then i clean up all mesh filters...
Aug 08, 2010 | Samsung WF203ANW Front Load Washer
My 7kg samsung washer always flashes error code 4E now... please give me the solution...
Jul 04, 2009 | Electrolux EW1200i Front Load Washer /...
Water gets drained immediately without washing
Jun 04, 2009 | Samsung WF203ANW Front Load Washer
My samsung washing machiene keeps coming up with the error 4e. what does this mean?
Mar 15, 2009 | Samsung WF337AA Front Load Washer
4E code keeps apearing
Jan 29, 2009 | Washing Machines
Inlet tube on washing machine
Jan 21, 2009 | Washing Machines
Washing Machines Logo
53 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
