When I turn on the TV it goes to white fuzz then the regular picture flashes periodically. What's wrong?
When turned on it goes to white fuzz then the regular picture flashes periodically. What's wrong?
    Top Expert:
  • Televison & ... Master
  • 74,198 Answers
Check the LVDS cable connection for any loose at both its end with socket. Re-seat both the end once, and check.
Posted on Apr 04, 2015
    Sergeant:
    Champion:
  • 219 Answers
Sounds like bad ariel connection check that first, sometime water get in cable if its fine on dry days that's it.
Kshfidej ed jdkkcjh dew hh
Posted on Apr 17, 2015
I have an hlp4663w 46in dlp samsung. The problem is after turning on the set it runs for a few minutes and I loose the picture, but I still have sound. I can turn it off and then back on and the picture...
It could be the temp sensor going bad. This sensor sits on top of the metal housing which the bulb assembly slides into. The bulb assembly will have a hole on top and this is where the sensor is above. There is a small blue and white wire that plugs into it. If you pull the wire out and put a paper clip or wire in the coupling you will basically bypass the sensor connecting the blue and white wire. If your tv turns on then that is your problem. Its cheap too. Here were my symptoms..1] Turn tv on 2] Bulb would light up..(which eliminates the ballast) regular picture would show up (which eliminates the bulb and color wheel) 3] 30 seconds later tv would shut down with 3 flashing lights. After bypass the tv turned on as always and hasnt shut down yet. Always un plug tv first. Get the replacement part to avoid overheating and possible fire
Aug 01, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
Can anyone point me in the right direction?I have had my samsung DLP (model SP50L6HD) for 4 years. This morning my children were watching TV and the tv started turning itself on and off. I switched it...
Jul 24, 2011 | Samsung HLM507W 50" Rear Projection HDTV
After a few minutes of being on my Samsung HLN507w dlp tv the picture will freeze and turn black and white, but the sound still works, I have to unplug the tv to reset it then it will work again for a...
This tv have a colors wheel design in it.The tv make loud grinding motor noises or pictures flashes or freeze and pictures turn in black&white with sound.The tv colors wheel it is dying or worn out already.Don't tries to change the tv colors wheel ur self.If u don't any mechanical skills,because the colors wheel it sit way back of the tv,must take out many mechanical parts before even can come to the tv colors wheel itself to replace it.Best to hire a tv tech. to change the colors wheel,so no problems for tv funstions for later or damages more parts on the tv set,if u install the new colors wheel in the tv wrong way.
May 12, 2011 | Samsung HLN507 50" Rear Projection...
My tv goes on and works then the picture disapears and the tv shuts down with the lamp lamp/heat and source blinkers on. what does that mean?
Mar 30, 2011 | Samsung HL-S5087W DLP TV
Have a 42 inch dlp samsung the tv is starting to turn it self off random. after being on for a long period of time
We have had the same problem with our 42" Samsung DLP - only two years old! We searched all over the internet for a list of ways to fix it. I found several things can help, including a switch that pops to the wrong position, cleaning the fan, etc. I put all the information together in a how-to format because it was so frustrating to go all over the internet looking for ideas on how to fix it.
http://www.ehow.com/how_4802985_fix-samsung-dlp-tv.html
Mar 14, 2009 | Samsung DLP HL-P5663W 56" TV
TV SREEN GOES BLANK, BUT AUDIO CONTINUES NORMAL,
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
No picture
hello
Seems to me that your power supply has weak 330 or 470 Mfd 200 volt capacitors.
Use computer grade Caps
I would have them changed first.
Thanks Guy9
May 07, 2008 | LG 42LB1DRA 42 in. LCD Television
No picture but has sound
My LG TV
switch on no picture but short period of sound then nothing
Jan 20, 2008 | Sony KP-51HW40 51" Rear Projection...
Black screen
could be some bad solder connections on the crt socket or around the flyback area dealing with the brightness
May 12, 2007 | Panasonic CT-32G34 34" TV
Televison & Video Logo
199 people viewed this question
Top Televison & Video Experts
Electro Med Services...
