Question about Toshiba Satellite 5105-S501 Notebook
Need key numbers
I need to find key numbers for echostar were do i go to find them
    Sergeant:
  • 263 Answers
Http://www.ebay.com
Posted on Jan 03, 2008
Using a echostar 1223475322-aa ir remotehow to program to tv this remote does not have pound key and no sat key or device keys how to progeam to tv
If your EchoStar remote does not have the keys you need, you will have to try using a remote that does have them.
Jan 31, 2017 | Televison & Video
The echostar remote cannot control the VIP 211 cable box are there codes I need
try the folowing:Press menu -menu on the receiver. You should be able to see the remote address for the receiver. It will typically be set to 1 if it reset somehow but whatever the case make note of this number. Take the remote and hold the SAT button until all lights across the top illuminate. Now key in the two digit address- single digit numbers are preceded by a 0. Now press the pound sign in the lower right of the remote and observe that the SAT button flashes thrice. Now press the record button a few time to ensure it is locked. Now try exiting the menu screen with the remote.
If this does not resolve the issue let me know and we will delve further into this issue. Thanks for using Fix Ya.
Dec 05, 2009 | DISH Network ViP 211 DTV Receiver
I need codes to program direct tv remote (20.0IR EchoStar 158926)
Press 'Menu'
Scroll to 'Customer support' and Press Select
When the application loads you'll see the codes menu.
May 25, 2009 | Akai LCT3201TD 32 in. LCD Television
I have a disney princess T.V. and I lost the remote for it, I bought a univercial remote and cannot find the code to use it. I followed the directions and the code is not listed in the paper that came with...
My disney princess tv model P1310ATV uses code 759 with Echostar 6.2 and 6.3 remotes. This code is listed in the echostar manuals as a code for Hisense manufactured TV's.
Feb 28, 2009 | Disney 13" TV
Dish network remote code for Disney 13" TV
On your dish remote, press and hold the tv button until all 4 buttons light up, then release. push either of the power buttons once. Now start pushing the down channel button, It's the one right below select, continue pushing it until tv turns off. When tv goes off push down button one more time then push up button, when tv turns back on stop and press # key, tv light will flash 3 times and should be set. Note....if u press down button and tv does not turn off after going through all codes( tv light will start flashing) press cancel and try again only channel up this time. hope this helps.
Dec 31, 2008 | Disney 13" TV
Echostar 5.0 remote
https://rweb.echostar.com/departmental_content/TechPortal/content/tech/remotes/5.0.shtml
Dec 26, 2008 | Universal Remote Control Activity Based...
I need the code for an echostar remote ir103602
How to Program a EchoStar Remote Control
Instructions
Step1
Ensure that the remote control has new batteries installed. If you are not sure or have been using the device for a while, go ahead and insert fresh batteries. You need four AAA batteries.
Step2
Locate the mode buttons on the controller. You will see SAT, AUX, TV, and VCR. SAT stands for the satellite receiver. Your remote is automatically set up to work with your EchoStar receiver, and you do not need to program it for this function. AUX may refer to a cable television device or an audio device that hooks it into your stereo system. TV refers to your television set. VCR may be chosen to control a standard VCR or a DVD player.
Step3
Press the mode button that corresponds with the device which you want to control with the EchoStar remote control. For example, if you want to program the remote to control the TV, press down the TV mode button.
Step4
Turn on the device. This is the item you want to control with the EchoStar remote. You may need to do so manually or with its own remote control. In this example, you would turn on your television set with its own control.
Step5
Press down the EchoStar mode button for the device again, but this time hold it down for three seconds. You are going to notice that all the other mode buttons are going to flash on. Aim the remote at the device you want to control.
Step6
Depress the EchoStar remote power button briefly and then slowly click either the up or the down arrow button. You are performing a code scan that allows the remote control to run through all the preprogrammed codes that are stored in its memory. Proceed slowly and do not hurry this process. It may take a few minutes, but it is virtually foolproof.
Step7
Stop when the appliance you want to control with the EchoStar remote control suddenly turns off. You have hit upon the correct code, and if you save it now, your remote will be able to use it in the future to control the functions of the item.
Step8
Store the code in the EchoStar remote control’s memory by pressing the pound button. You will notice that the corresponding mode button is going to flash, acknowledging the programming choice. You are now ready to control the item with the EchoStar remote control.
Aug 28, 2008 | Televison & Video
The right code
Dish Network can be listed as Echostar as well.. There is a possibility that they don't cover Dish Network. What is the model number of the TV?
Dec 06, 2007 | Syntax Olevia LT32HV 32 in. HD-Ready LCD...
Toshiba Satellite 5105-S501 Notebook Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
