When i turn up base,left speaker pops in and out and vibrates like mad,right side perfect.
    Sergeant:
    Champion:
  • 219 Answers
First swap them over to see if it is that speaker or a prob with the unit.
Posted on Apr 04, 2015
Testimonial: "done that still the same.if i turn bass to minus it starts to vibrate and pop the speaker but if i turn bass to plus no popping or put on tone bypass,cheers."
3 Suggested Answers
SOURCE: Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
Posted on Aug 28, 2007
  • 5 Answers
SOURCE: right side speaker barely works
Likely the control is old and dirty.  It is known as a rheostat on older units and often a little contact cleaner on it will work.  A simple thing to try that might work is to rotate the knob back and forth, left to right, each time going to full stop.  do this several, several times.  See if this makes things better.  Of course, the assumption I am making is that the right speaker is operating normally.  If you switch out the left speaker for the right, and the problem persists, on the same side, it is the receiver.  If the problem now appears on the left side, it is a speaker issue and not the receiver.  Good luck and let us know how it goes.
Posted on Jan 02, 2009
Why are my headphones making a vibrating sound on the left side, when there is a lot of bass.
Each speaker works independently from each other. One speaker may use more low frequency tones than the other one.. Low frequency tones create a lot more noticeable vibration than higher frequency tones. You can reduce it by turning the volume down a little on the left speaker. It is possible that nuts came loose on the speaker.
Jun 01, 2014 | Beyerdynamic DT 770 PRO Professional...
Left speaker not working
I don't believe it to be a cable or plug problem, so it sounds like it's a speaker problem. I look up the review of these and it could have some kind of circuit built into each side. If it does it could be that. As they are not cheap headphones by the look of it, perhaps worth repairing. But if the speaker has gone, it might be as much as a new pair.
Jan 03, 2014 | Sennheiser HD 558 Headphones
Panasonic TH-50PX70EA HAS A HALF SCREEN PERFECT BUT OTHER HALF IS LINED AND CHANGES COLOUR AND SOMETIMES GOES BLACK GETS CLOSE TO PERFECT THEN GOES LINED AGAIN PS sorry for caps
If its a Plasma it uses sustain or t con boards--sustain will usually be two--one for left side and one for right.
Only boards are sold for these sets--no individual parts--discover which board drives the right side and replace it while crossing your fingers--either it fixed the problem or you have a bad display panel (entire screen unit which is fatal from a cost point of view).
Apr 22, 2012 | JVC PD-42WV74 42 in. Plasma EDTV
I have a Sony STR-DE605 and all of the right side channels are distorted and have to be turned up 1/4 before you can hear any ot the distortion but if i turn if off switch to the left sounds perfect.Center...
Sorry for a dump question ,
have you changed the distorted Right speakers to LEFT to verify if speaker is OK ?
First try with just STEREO ,not on Surround and please contact me for further solution possibility..
Take care..
Jun 27, 2011 | Sony STR-DE605 Receiver
How do i turn my lap top microphone on or do i need to plug one in regards mike
Hi Mike,
The spec say it has a built-in microphone. If you are using Windows, open the sound controller and check that the slider on the microphone is turned at least half-way up. When you open the sound controller (speaker in the systray next to clock), the microphone is normally muted. To test, unmute and tap the microphone or speak into it. Make sure you have the volume turned up on the speakers too.
The dv1000 notebook is equipped with:
  • 1 Type I/II PCMCIA card slot. I store my Media Remote control. (left side)
  • 1 IEEE-1394(Firewire) (right side)
  • 3 Universal Serial Bus (USB 2.0) (Two on the right side and one on the left)
  • 1 Built in 6-in-1 digital media reader (No Compact Flash)(Right Side)
  • 2 headphone-out (front)
  • 1 microphone-in (front)
  • 1 TV-Out (S-video) (right side)
  • 1 RJ-11 (modem) (left side)
  • 1 RJ -45 (LAN) (left side)
  • 1 External VGA monitor port (left side)
  • 1 expansion port for use with HP Expansion Base(sold separately). Available only with Intel Extreme graphics with productivity port (left side)
  • Power jack (in the back)
  • CD/DVD drive (right side)
Jun 01, 2011 | HP Pavilion dv1000 Notebook
The right side of the speaker is low, you can hear it but it's like there is no bass to it like the left side, sounds like the right side is like whispering to you but the left side is talking normally,...
If your subwoofer is placed to the left side try moving it to the right side or try to move it in the center. Otherwise if you are using a PC go to the control panel and click the sounds and audio devices icon. a little window will pop up and the button labeled speaker volum click on and reduce the volume for the left speaker and then turn up the volume on your speakers and see if that helps.
Nov 30, 2010 | Logitech Z-2300 Computer Speakers
I have a vibrating in the front right. At most speeds. When I turn slightly to the left it does not do it.
The problem you describe is consistant with a tire problem. Could be as simple as rebalancing, however since it does not do it when you turn left, it makes this solution unlikely, but not out of the question. I would, based on your description of the problem tend to think that your tire may be slightly out of round from the center to the left side of the contact patch, or possibly a belt separating on the inside. When you turn left, your tire will tend to ride on the right edge, you loose the vibration, which would lead me to believe that your tire is "true" on the right side of the contact area.
Oct 14, 2009 | 1996 Lexus LS 400
Just bought a new car. i removed old stereo and put in my kenwood kdc-w808. whenever there is base in a song it distorts i have to turn my base rite down to get rid of it. worked perfectly well in my old...
your speakers probably cant handle the bass.,also they are probably full range speakers ,so hwen the base hits at the same time a voice is singing the woofer is vibrating to produce the basss,there fore distorting the highs and mids {or voice}.You need to add a seperate sub woofer.And puyt capicitossr on the full ranfge speakers to limit the bass..Rating please. :}
Jun 16, 2008 | Kenwood Car Audio & Video
Onkyo receiver TX-DS777
You have a bad amplifier left or right whichever pops if both sides pops then it both amps
Dec 25, 2007 | Onkyo TX-DS777
Problem with Diamond 8.4
No - sounds like the speaker/ cross over is faulty - I assume there are only one set of connections on the back - on some speakers you have 4 connections for dual wiring - and you usually bridge those out Play a piece of music with some drumming in it and you should see the midrange move a lot Just to make sure there is not a problme with the Amp - swap the speakers around - so you have a left speaker and a right speaker connected physically move the left speaker over to the rightside and connect to right side cables - and the right speaker to the left side and connect to left cables Now if the problem goes over to the other side - its the speaker thats fault if it stays on the sam side - its the amp
Apr 12, 2007 | Wharfedale Diamond 8.4 Main / Stereo...
48 people viewed this question
 Grubhead
Grubhead
