There is no output signal from speakers or headphones
    Sergeant:
  • 402 Answers
This sound like channel outputs are shorted these components normally fasten to heat sinks.
Posted on May 05, 2015
    Sergeant:
    Champion:
  • 219 Answers
Sounds like amp has had it.
Posted on Apr 04, 2015
Why cant i get sound from wireless headphones when plugged into rca input
Looks to me like you answered your own question. INput is for INcoming signals (microphone...). OUTput is for OUTgoing signals (headphone, speakers...) Looks to me like you answered your own question. INput is for INcoming signals (microphone...). OUTput is for OUTgoing signals (headphone, speakers...)
May 23, 2016 | RCA Televison & Video
1500 Series- The receiver works perfectly through the headphone jack but there is no output to the speakers. I am very familiar with Denons and this is not a speaker "on" issue or a setting. I...
The speakers are disconnected with the switch in the headphone jack. If you use headphones regularly and speakers quit working right after a session with headphones, the contact in the headphone jack my have gotten stuck or the relay this switch controls may have gotten stuck. -mark
Jun 12, 2011 | Denon AVR-1506 Receiver
My tuner will not work! I've had this unit for 4 years & it's always worked perfectly. Then yesterday, the tuner stopped working. "Tuning" flashes on-screen intermittently & no...
1. Verify the source of the signal - Look for any antennas that may have been hooked up, and verify connection has not been moved or removed.
2. Test with a different output by plugging in some headphones, and recheck the volume through the headphones.
3. Check that the A/B switch for the speakers has not been moved, and that they are switched to the correct speakers.
4. Try AM and FM for any signals both with speakers and then headphones.
Bruce
May 05, 2011 | Audio Players & Recorders
My Sennheiser RS 110 headphones won't work. I followed the installation directions but all I get is static. What else can I do?
First thing is you need to have a signal going to the headphones for them to work.
If you are getting a signal the green light should be lit.
If only the red lamp is lit the headphones are not getting a signal.
If hooked into a television you should have them plugged into a Fixed Output not variable output..
If you only have a variable output then you must turn the speakers off on the television and then turn the volume up on the TV in order to send a signal to the headphones.
If you are using a amplifier make sure you are using the correct output. Tape Monitors generally will not work as this output is not amplified.
Lastly try using an rca to headphone adapter and plug them into a headphone jack.
Don
Jan 02, 2011 | Sennheiser RS 120 Consumer Headphones
What are the correct speaker connectors for this unit RCA, Phono ,3.5 mm ?
Does it have a speaker output - I'm sure it does? More likely it's the 3.5mm. which may look like for headphones. The RCA are for low level signals so therefore it's not for the speakers. Do the speakers have two wires a piece? If they are, then there should be speaker output clips on the stereo to connect to. If they look like phono plugs then they go into the speaker output jacks.
Oct 25, 2010 | GPX S7799 Shelf System
My built in speakers don't work ..but any headphone works ..please help
The output of the speaker jack is not very high, mostly 5 volts DC. This is not enough to power speakers. Most add on speakers have their own power supply (a plug in or Batteries) to boost the volume or signal. If you plug the speakers in without the additional power requirements, they won't work.
It is a good test to plug your headphones in, that determines that your speaker jack is working.
Sep 26, 2010 | HP Compaq Computer Speakers
Just wondered if i can connect my speakers straight to cd player or do i need to go through an amp Thanks
Component CD players like yours must be used with an amplifier. Their output is called "line level" and isn't beefy enough to drive speakers directly. An amplifier is needed to boost those line level signals to speaker level. The same is true for other components like tape decks, DVD players and so on. A CD player may have a headphone output jack, though, since headphones don't require the same power levels as speakers. So you could use the player by itself for headphone listening.
Hope this has cleared the air for you. Thanks for using Fixya!
Feb 10, 2010 | Teac CD-P1160 CD Player
I have a Samsung ht-p1200 system, and would like to use speakers AND headphones at the same time. How do I do that (when I plug in the headphones the signal to the speakers disconnetcs.
You could try rigging headphones to the speaker output if you don't mind cutting some wires and spending a couple bucks on a headphone jack thing.
Nov 18, 2009 | Samsung HTP-1200 System
My sony dav-s-400 system keeps activating headphone port output.
Just had and fixed the same problem that hundreds of people are suffering with this system!!
Sony DAV s400 - same problem, won't play though speakers and display indicates that headphones are plugged in - when they are not. Fairly easy to fix and took me less than an hour from start to finish:
1) Remove top cover
2) Remove circuit board that has Audio In/Out phono scockets (to get access to Amplifier Circuit Board)
3) Remove Amplifier circuit board (has the speakers attached)
4) Turn it over and remove copper heat shield
5) Resolder joints where the big brown capacitor is and where the wires go to the front headphone socket...and any other dodgy joints that you find
6) Reassemble.
Feb 03, 2009 | Sony DAV-S400 System
245 people viewed this question
 Grubhead
Grubhead
