My tv has no volume on despite being at 35. I've tried leaving it unplugged all night and it had no affect. It is the same regardless of being plugged in to the sky box or normal tv. It's a JMB 42"
    Sergeant:
    Champion:
  • 219 Answers
U may of activated the mute?
Posted on Apr 04, 2015
  • robo12007 Apr 04, 2015
    Nope. Checked that first. Plus if I activated mute when I adjust the volume it'd cancel the mute.
bluegreenash
  • 661 Answers
SOURCE: RCA - 4228ASPDP - 42 inch Plasma - Audio Problems
Usually you would connect the SKY box to the DVD recorder and the DVD recorder to your TV, check you installation guides for setup instructions, which should show you a preferred layout diagram,
Posted on Sep 27, 2007
chrispurs1
  • 372 Answers
SOURCE: Unable to Tune TV to Sky + RF output
Hi.
The problem is that the modulator output frequency of your sky box is exactly the same as for example chanel 5 on your terestrial aerial.
You need to change this number to a different one thats clear of local terestrial transmissions
1) Select the Services button on your Sky or Sky+ remote control.
2) Type in 401 [select] on your key pad and you will get to the installer menu. You cant gain access to this via the drop down menu as it is designed for the Sky Engineer to use.
3)
Select Option 4 to configure the RF outlets on your Sky Digibox.
4) The option RF Chanel Number change this number from example 35 to 60 .
You may need to do this using other numbers 26 34 55 etc
Every time you alter the number store it then try & tune TV to sky.
Any other sets in the house connected by RF leads will require retuning for sky.
Save new settings and you should find that your RF outlet to TV works fine.
http://dysonmanuals.llc.nu
Chris.
Posted on Jan 31, 2008
melnavz
  • 1226 Answers
SOURCE: Plasma TV-power light does not come on
Hello!
most probably the fuse inside the circuit blown out, You should open the back of the tv to become circuit board visible. But this hard when novice do it.
To be sure that everything will be alright i would rather suggest you to bring the tv to the nearest service center. maybe warranty work for that.
best regards,melnavz
Posted on Mar 03, 2008
  • 138 Answers
SOURCE: Sky remote code for JVC GM-P420E
Go to www.remotecentral.com
Posted on Aug 19, 2008
rapanSF
  • 150 Answers
SOURCE: 42'' LG Plasma bought in Australia doesn't work in UK?
Find out if Australia uses a different standard of HD programming than Guernsey or not since it's not picking up any channels at all with an attenna. Does the skybox use only scart connections and that's how your small lcd is connected to it?
Posted on Nov 17, 2008
HTC wont turn on
HTCs have a known power glitch that affects many of their model of phones. Unplug the phone. Hold down volume down, volume up and power. Do not let go. Plug in power. Hold those three buttons down for NO LESS THAN three minutes. You may see a flashing red light in the process. Once you see solid red, it is in a charging state. Allow it to charge for an hour or so and then attempt to power it up normally. You may want to get a quality replacement battery from eBay or a respected vendor, since chances are you other battery is toast. Li-Ion batteries don't like to sit in a drianed state for very long without loosing their mojo.
Mar 17, 2014 | Cell Phones
Menu keeps popping up ever few seconds, wont go away.
Check and replace the main system control memory IC. It is faulty.
Feb 11, 2013 | Toshiba 35A44 35" TV
Changed the light bulb and my TV still will not come on. We have volume, but no picture.
Try unplugging the HDMI cable. Turn off the sources (complete power cycle by unplugging all from the wall and the equipment if possible). Turn on monitor and then plug in all the rest.
Jan 02, 2013 | Toshiba 72HM195 72" HDTV
MY 32
Yes, in these sets almost all the audio circuit is on the main signal board which with this model is not likely to be cheap if it can be found.
You have tried to unplug set, a box, or a audio/video receiver and also nothing on any input--leaves unless something odd wrong--audio circuit problem.
May 20, 2012 | Polaroid TDA-03211C 32 in. LCD HDTV
I've owned for approx 3 yrs. Today I was watching a show on my Panasonic TH-50PZ80U and all the sudden the sound went away. From the lowest volume setting to the highest, no noise at all...Please...
Hello!
First move: unplug your broadcast provider's box, wait for a minute, then plug it back into power source. I mean: leave all the connections intact, just unplug from power source. It might be just power cord or power adapter. If that's not the case, please do the same with TV. Unplug it from wall outlet, wait a minute, plug it back in. It's a next step, if your "box" won't take care of the problem. If that won't take care of the issue, refer to owner's manual for "reset" procedure. Worst case scenario: you might need to replace main board inside or your TV.
good luck,
Thanks,
Alex.
Oct 09, 2011 | Panasonic Viera TH-50PZ80U Plasma TV
We had a really bad storm yesterday with a lot of lightning. our power flickerd on and off a couple times but all of our electronics are plugged into surge protectors. everything in our house is working...
Few mins will not resetting tv and recovering power supply board from it protection modes that quick.Tries tv unplug,replug it back like about an hour later for tv resetting it back to the factory setting.The tv should get out it protections modes and might work again.If tv still have the same problems,than enough high currents got in the tv and kill ur tv power supply board.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish power supply board for the replacement.
Jun 30, 2011 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Hi, I have a Samsung refrigerator and the frizer has not being cold enough for about a year I realized that it was to close to the wall. I unplugged it last night until this morning and now it is between...
If your refrigerator is too close to the wall and you've used that almost a year without realizing that it may affect the coldness inside, it already done some harm to the refrigerator compressor machine, to overheat hence it cause damage to it.
Check the temperature control, overload protector hope that the things become defective instead of the compressor motor that is expensive. Check it if you can, if not call a service technician.
I hope I help you.
Jun 12, 2011 | Samsung RB215LASH
After fixing Wii console power light is not getting on ? what next
Did you open up the Wii console and perform self-maintenance inside of it? If so, you may have caused damage to a vital component needed for the Wii to work properly. Regardless, if the Wii light isn't turning on, unplug the power cable from both the Wii and the wall and leave it unplugged for a couple of minutes. Plug it back in and check again.
If it still doesn't work, leave it unplugged for the rest of the night and try again in the morning. Beyond that, if it's still experiencing problems, call Nintendo. Don't tell them that you opened up the Wii console (if that's what you did) or they will note it on your file and the warranty will become void.
Jan 04, 2011 | Nintendo Wii Console
Volume
I have the same problem with my 51S500 which just started. I used to have it set at 12-14, now needs to be 25-30. Playing DVDs is not affected. External speakers hooked into the external speaker jacks are affected.
Apr 02, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
