Question about SmartParts SPX8 Digital Picture Frame
Need mounting screw for frame had 2 lost one? how can I replace
Lost screws for Mounting. Need to know size screws for mounting
To know more about this, you have to download the repair manual of this set. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy Pull up older posts. Surf the site with patience.
Disassemble procedure to many popular brand TVs are given.
Apr 18, 2014 | Sylvania LC370SS9 LCD TV
How do I replace the oven door gasket on my VGIC3686
Replacing a Door Gasket
If the oven won't heat to the desired temperature or heats unevenly, the problem could be a defective door gasket. The best way to test for this is to pass your hand around the door, being careful not to touch it, while the oven is turned on. If you can feel heat escaping, the gasket needs replacement. Replace it with a new gasket made for the range.
On most ovens, the gasket is located on the frame of the oven, and the door closes against it. This gasket is generally friction-fit in a channel and can be replaced. In other units, the oven door has two sections, and the gasket is not mounted on the door frame, but is installed between the front and back sections of the door. Don't try to replace this type of gasket; call a professional service person. Here's how to replace a frame-mounted gasket:
Step 1: Pull the old gasket out of the channel. On some oven door frames the gasket is held in place with screws. To get at the screws, bend back the exposed edge of the gasket.
Step 2: Clean the channel and the door frame with a solution of mild household detergent and water.
Step 3: To install the new gasket, start the replacement at the top of the door frame and work down the sides, easing the gasket around corners. Finish the installation along the bottom, butting the ends of the gasket firmly together.
Apr 16, 2012 | Viking Kitchen Ranges
How do i remove a harddrive from a computer case when only one side has screws to remove? Details: Okay so i'm trying to remove a hard drive from a computer case that only has screws on the back right...
In this case the hard drive is mounted in a frame. Look for mounting screws that locks this frame to the computer case. When you remove this frame you can access the screws holding the hard drive.
Jun 12, 2011 | Compaq Computers & Internet
How to replace oil pan gasket
1994-96 VEHICLES
( see Figures 6 and 7 / click image for zoom )
Fig. 6: Oil pan mounting bolt locations-1996 3.1L engine shown
Fig. 7: Oil pan sealant application points-1996 3.1L engine shown
  1. Disconnect the negative battery cable.
It may be necessary to remove the hood, with the help of an assistant, for access.
  1. Remove the engine mount strut and A/C compressor (if equipped) and the engine mount strut bracket assemblies.
  2. Remove the electric cooling fan assemblies. -28467 and J 26462, or equivalent.
  3. Raise and safely support the vehicle. Drain the engine oil.
  4. Remove the front exhaust manifold pipe.
  5. Remove the intermediate shaft bolt/screw.
  6. Remove the oil level sensor.
  7. Remove the engine splash shield.
  8. Suitable support the drivetrain and front suspension with jack stands.
  9. Remove the transaxle mount side frame retaining nuts from the drivetrain and suspension frame assembly.
  10. Remove the engine mount side frame nuts from the drivetrain and suspension frame assembly.
  11. Unfasten the rear drivetrain and front suspension frame bolts/screws.
  12. If equipped, remove the lower drivetrain and front suspension frame bolts/screws.
  13. Remove the engine mount assembly.
  14. Remove the flywheel inspection cover.
  15. Remove the starter.
  16. Disconnect the transaxle mount assembly from the oil pan.
  17. Unfasten the side bolts and screws and the retaining bolts and screws, then remove the oil pan. Remove and discard the oil pan gasket.
To install:
  1. Clean the gasket mating surfaces.
  2. Apply a small amount of sealer on either side of the rear main bearing cap, where the seal surface on the cap meets the cylinder block. Install a new gasket on the oil pan.
  3. Position the oil pan and secure with the retaining bolts and screws. Tighten the retaining bolts and screws to 18 ft. lbs. (25 Nm) and the side bolts/screws using tool J 39505 or equivalent.
  4. Fasten the transaxle mount assembly to the oil pan.
  5. Install the starter motor.
  6. Install the flywheel inspection cover.
  7. Install the engine mount assembly.
  8. Carefully raise the drivetrain and front suspension assembly. Install the rear drivetrain and front suspension frame bolts/screws.
  9. Fasten the engine mount frame side nuts to the drivetrain and front suspension frame assembly. Install the transaxle mount frame side nuts to the drivetrain and suspension frame assembly.
  10. Remove the jackstands from the drivetrain and front suspension frame assembly.
  11. Install the engine splash shield and the oil level sensor.
  12. Install the intermediate steering shaft bolt/screw. Connect the front exhaust manifold pipe.
  13. Carefully lower the vehicle.
  14. Remove the engine support tools.
  15. Install the electric cooling fan assemblies.
  16. Install the engine mount strut and A/C compressor, bracket and the engine mount strut bracket.
  17. If removed, install the hood assembly.
  18. Fill the crankcase to the correct level. Connect the negative battery cable. Run the engine to normal operating temperature and check for leaks.
Hope this helps (remember to rate this answer).
Jun 04, 2011 | 1994 Oldsmobile Cutlass Supreme
How to replace the grill element in a Stoves 720EF double oven?
1) Isolate the unit by turning the power off at the main switch.
2) Remove appliance from housing unit.
a) When handling the appliance care should be taken to ensure the outer frame trim is not damaged.
b) The appliance is secured into the housing unit by 2 screws through the top corners of the front frame, open the doors and unscrew the 2 corner screws.
c) Grasp the bottom of the frame, pull forward and out onto a suitable surface.
3) Unscrew the top and rear panel securing screws and lift the panels clear.
4) From the rear of the appliance, pull off the 4 (top) grill element leads and the earth lead.
5) From inside the oven unscrew the 2 screws from the grill mounting plate.
The above is from the Handbook. I assume from point 5 the element is then free to be removed. reverse the procedure to fit the new element.
If you want a copy of the Handbook, then I will need an email address for you.
Mar 11, 2010 | Stoves 720EF Electric Double Oven
Ibm 6400
This is a easy problem... Have any question call 972-907-9771 x311
51e9bbd.jpg ATTENTION Hammer springs and hammer tips are fragile. Do not touch the hammer springs or tips. Handle hammer springs by the
thick mounting base only. Apply pressure only to the mounting base.
NOTE: Replace a hammer spring assembly only if there is visible damage or broken parts can be seen in the assembly.
5. Remove the mounting screws from the old hammer spring assembly. (See Figure 18, page 367.)
6. Handling the hammer spring assembly by the mounting base only, gently pry the old hammer spring assembly off its
mounting pins. (See Figure 18, page 367.)
7. Inspect the hammer bank and the old hammer spring assembly:
a. If there is ink on the hammer bank mounting surface, the hammer spring assembly mounting surface, or the hammer
spring neck or tines, reinstall the old hammer spring assembly and replace the shuttle frame assembly (page 405).
b. If the old hammer spring assembly and the hammer bank are free of ink, install the new hammer spring assembly
Installation
1. Using a clean dry cloth, wipe the hammer spring mounting surface on the hammer bank. Make sure the cloth does not
leave lint on the hammer bank.
NOTE: Replace a hammer spring assembly only if there is visible damage or you see broken parts in the assembly.
2. Handling it by the mounting base only, remove the new hammer spring assembly and mounting screws from the box.
3. Handling the hammer spring assembly by the mounting base only, carefully position it on the hammer bank mounting pins.
then gently press the mounting base down against the alignment pins. (See Figure 19, page 369.)
4. Continue pressing down on the mounting base of the the new hammer spring assembly as you install the mounting screws
from the replacement kit. Using a Torx T-10 bit adapter, torque each screw to 14 inch-pounds (1.58 N•m). Tighten the
center screw(s) first. (See Figure 19, page 369.)
NOTE: Use the 1-30 inch-pound Torque Screwdriver, IBM part number 16F1661.
5. Install the hammer bank cover assembly (page 354).
6. Install the shuttle frame assembly (page 405).
7. Install the ribbon and load paper.
ATTENTION Do not attempt to adjust or “tweak” hammer springs.
8. Run an operator print test and check print quality (page 223):
a. If print quality is acceptable, return the printer to normal operation (page 339).
b. If print quality is still degraded, replace the shuttle frame assembly (page 405).
Sep 10, 2009 | IBM 6400 Matrix Printer
I have just bought a car with an overhead tv i dont know how to get power to it
    Headrest TV
  1. Step 1 Disconnect the headrest from the car seat and remove its upholstery. Trace the outline of the TV's mounting frame onto the foam cushioning with a permanent marker.
  2. Step 2 Cut a hole into the foam using a razor knife for the frame to fit into. Using the frame as a guide, whittle into the hole until it is deep enough for the frame to fit into. Glue the frame into the hole with contact cement and poke another hole into the foam with a screwdriver where the frame's cable hole is.
  3. Step 3 Place the headrest's upholstery cover back on and cut the fabric away where it is over the frame.
  4. Step 4 Place the TV into the frame once the contact cement is dry and hard and run its cable through the other hole. Connect the TV to its tuner console with audio/video cables and store the tuner under the seat.
  5. Step 5 Connect the TV's power adapter cable and route it so it can plug into a cigarette lighter adapter. If it doesn't use one of these, it will have a three-way cable where one connects to the car starter, another to a constant 12-volt source and the last one to a good ground. Disconnect the negative battery cable before connecting any wires
  6. Overhead TV
  7. Step 1 Make sure there is a metal sheet installed in the ceiling below the headboard. This is needed to mount the overhead player onto.
  8. Step 2 Pull away the upholstery on the ceiling. This might require a solvent that will remove the upholstery's adhesive. Insert a plywood or metal sheet between the headboard and upholstery and glue it to the upholstery.
  9. Step 3 Mount the TV set to the ceiling, making sure the screws for the TV's mount are securely screwed into the sheet within the ceiling.
  10. Step 4 Route the wires to the engine compartment if the TV doesn't use an adapter plug for the cigarette lighter. With the negative battery cable unplugged, connect the TV's red wire to the starter's electrical connector, the yellow to the battery or other 12-volt source and the black to a metal ground like on the chassis.
  11. Dash TV
  12. Step 1 Unplug both battery cables from the car's battery, starting with the negative terminal.
  13. Step 2 Remove the stereo from the car. Pry away and remove any trim panels on the dash, then unscrew the mounting screws on the stereo and disconnect the electrical connectors. Some stereo units have an anti-theft mounting system requiring special tools that fit into holes on the stereo front to release its mounting clips.
  14. Step 3 Place the TV within an installation kit designed for your model carmag-glass_10x10.gif. Connect the antenna's cable to the TV and mount the antenna on the outside of the car; the trunk or the roof near the door frame are two possible locations. Route the cable along the weatherstripping or secure it to the side with cable ties.
  15. Step 4 Connect the TV to its tuner box with RCA video (composite) cables and store the tuner somewhere secure, like the glove box. Wire the TV to the radio antenna and stereo connectors with a wiring harness designed for your car, which can be purchased at a car audio supply store.
  16. Step 5 Mount the TV into the stereo's old spot within the dash, fasten all the mounting screws and replace the trim panels. Reconnect the battery cables once the set is mounted, starting with the positive terminal.
i hope this will help.you can send a message if you not satisfied
Sep 10, 2009 | Necvox Car Audio & Video
My Coleman Powermate 5500 is lose inside its frame
Rubber feet normally attach via a bolt or screw through the center of the foot. Look for a bolt or screw were the feet use to be. The rubber may have torn free, so you may need to glue or replace the feet.
May 31, 2009 | Coleman Powermate Powermate 5000W...
Brakes and pegs
There is two ways to put the pegs on.
1. they screw on th the threads of the wheels where it mounts to the frame.
2. If there is just a hole in the peg you have to remove the nut where the tire mounts to the frame put the peg on then put the nut back on the wheel. You will need a long extension for your socket for this method.
Good Luck
Dec 21, 2008 | Razor Fz 2000 20-Inch Freestyle Bike
SmartParts SPX8 Digital Picture Frame Logo
185 people viewed this question
Top SmartParts Photography Experts
Joseph Hoffmann
Tony
Are you a SmartParts Photography Expert? Answer questions, earn points and help others
