Removal steps of keyboardLoosen the screw to the unlocked position to unlock the keyboard frame. Turn over the computer. To reveal the screw heads beneath the frame, use the flat-head screwdriver to slide the keyboard forward by 2.5 mm (0.1 inch). Use the cross-head screwdriver to loosen the screws.
Almost all door panels are attached by: SMALL PHILLIPS HEAD SCREWS- these are found all around the door panel. They are normally hidden by; small plastic grommets (round, flat plastic push tabs used to cover and make it look pretty!) -remove with flat head screwdriver or your nails at-own risk, THE SPEAKER COVER- -easily popped off by squeezing outer edges inwards releasing the male part on the speaker cover from the slot on the door panel and THE RUBBER OR PLASTIC COVER- found on the inner side of the door handle -this cover may not be there for your model and you may see the screw or the grommet. If not, remove cover with flat head screw driver or needle nose plyers, then remove screw/s
Tips: 1)check for grommets if screw/s are not in plain sight)- plastic push tabs (flat head and round about a 1/4 to a 1/2 inch in diameter, normally matches the car door panel and fits flush with the panel as well so look closely! You will need a flat head screw driver for this part or try your nails at own risk.),
2) Once you have removed all the screws and or push tabs shake the panel to pin point any remaining screws or tabs. Some times there are slots in the door frame that join with the male part located on the inner side (touches the door) of the plastic panel.
In this case the hard drive is mounted in a frame. Look for mounting screws that locks this frame to the computer case. When you remove this frame you can access the screws holding the hard drive.
You are on the right track...:) After removing the two visible mounting screws...you need to wrap your flat head scredriver with tape...and carefully pry the assembly away from the body...after removal...sounds like you can find the defective blulb...:)
1st: Dont listen to the so called gurus at FixYa. As the guru there was telling me that the frame was glued to the cabinet. If I would have followed his recommendation Id be buying new cabinets as well as a new mounting frame. FixYa should credit me my fee paid. The solution: For the built-in cabinet AEG microwave oven, it is required to use the AEG mounting kit. The AEG mounting face frame uses for screws, one at each corner concealed by small black plastic caps that blend in perfectly with the contour of the mounting face frame. If you look closely towards the inside of each corner you'll see a very small slot in the cap that will allow you to put a small flat head screw driver into the slot to work the cap out. Once the four caps are removed use a phillips screw driver to remove the screws that fix the mounting face frame to the cabinet.
OK, I just (11/29/09) replaced the battery on Conair TH301S glass scale. You will need a CR2032 (3V) battery, a small (P12) phillips screwdriver, a flat screwdriver and a small twiser (to hold small screws).
On a stable and clean surface (kitchen table, no kids around due to small screws) lay flat upside down the scale.
1) Remove all 6 phillips screws that hold the inner frame.
2) With the help of the flat screw driver unhoock each side of the inner frame (horse shoe shape)
3) Open slowly because there are 2 wires that connect the weight sensors and lay flat on the side.
4) There is an eletrical circuit beside the display, it is being held by 5 very small phillips screws (remove them)
5) The you will find underneath a small round black box held by 3 phillips screws. Remove them, open slowly the top cover and inside reside the battery, pop it up gently with the flat screw driver.
6) Replace the battery, reinstall the 3 screws.
7) Where the display stand, remove the 4 screws of the plastic cover. Slowly remove the cover and the LCD display itself (pay attention on how the display is installed).
8) Re install the circuit board with the 5 smaller screws
9) With a QTips and alcohol clean the contacts of the circuit board where the LCD dispaly sits. Sit in place the LCD display (it will touch the circuit from above) .
10) Place the plastic cover with the 4 screws.
11) re install the frame and put the 6 screws.
12) YOU HAVE DONE IT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
if it is a 1001 all you need to unscrew is 4 screws on back black ones you will need to remove warrenty sticker inside battery compartment and then remove screw on trim ring. with 2001 remove 4 screws 2 under batery as above one is covered by warrenty sticker then remove one screw on bottom of trim then 2 small screws by usb use small flat head screw drive to release screen from screen mount
tools:
philip head screw driver,
metric socket std and deep.
rachet metric or 3/8 driver with a adaptor.
socket extension.
lower the windows.
look for small plastic cover on the door handle and door pull, pop the cover with a samll flat head screw and loosen the screws with philip head screw driver.
pull the in side panel from the button of the door panel with the help of screw driver and along the sides.
push the inside panel up wards to clear the glass. and disconnect any of the electric wiring. and left the panel out of the way.
take the window switch from the door pnael and roll up the windows.
peel down th inside water seal.
you should be able to get to the mounting screws for the mirror.
a few trips to the hardware store will solve this, take a few screws from around the house and find one that will thread into the barrel or whatever is in the frame, measure the lenght and off to the hardware store. home depot has a large selection of specialty screws.
