I have blaupunk TV it was working Friday morn recently moved it to different room now wont turn on Ive checked the fuse its fine Also even the standby light isnt on Any ideas of how to get it to work?
    Top Expert:
  • Televison & ... Master
  • 75,311 Answers
Try an other Wall plug. Check whether AC comes to its SMPS board. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Apr 04, 2015
dodgecharger
  • 254 Answers
SOURCE: LCD TV WONT POWER ON
A dead condition usually indicates one of the following: Open fuse (often internal, and usually pops due to other circuit defects). Short (overload condition) in the circuitry. Failure elsewhere in the circuitry. Most modern electronics have some logic circuitry, and if there is a section of the circuit not working, the logic circuit keeps the set from coming on at all.
First, if your power cord plugs into the set, check that it is properly connected. If you can get into the internals, find the fuse, check it, replace with an exact or near exact size.
If problems are beyond the simple, technical expertise will be required to nail down and fix the problem.
Posted on Nov 28, 2007
dsacco86
  • 1077 Answers
SOURCE: No Power to a Vizio VX32L
My best guess is to check for blown fuses or the power board when bad inside the TV.
If that doesn't work, looks like you'll have to pay a repair shop to find out what's really going on.
Sorry I can't help you further.
Posted on Feb 03, 2009
SOURCE: no power to my Hitachi 42Pd6600 plasma tv
the master switch at the bottome of the TV per Brianbuy solved my problem...Thank you!
Posted on May 31, 2009
  • 1039 Answers
SOURCE: LG 32LP1D TV no power
Check the fuse on the power board. If ok change the power board.
Posted on Nov 01, 2009
Testimonial: "cheers man thats what it was."
SOURCE: it will not turn on the standby light isnt even on
The Vizio VP322 is notorious for having bad capacitors on the power supply circuit board. They will probably be bulging and may have electrolyte leaking. I replaced four bad capacitors (with a different brand just in case) and fixed it. Total cost under $10. A lot cheaper and better than replacing the whole circuit board which may contain the same "faulty" capacitors from the factory.
Posted on Dec 01, 2009
Ive just bought a 22 inch lg tv, tuned in ok but remote is now not working, wont do anything, wont even put tv in standby mode. Any ideas?
unplug tv, take batteries out of remote. plug tv back in, replace batteries. best idea i have. sometimes that resets the devices. good luck
Mar 05, 2015 | LG 22LV2500 22" Inch 720p Widescreen LED...
I unplugged tv to move it across the room now it wont turn back on??
POE:
  1. Connect tv directly to socket without any powerboards and make sure the power cord is properly inserted (if it works than any powerboard you have been using is probably faulty)
  2. Try a different power cord
  3. See if socket is dead using another appliance. If another appliance works then the Tv is probably damaged (refer to warranty if applicable)
  4. if other appliances don't work in that socket check your fuse box.
  5. If fuse box is fine then try a different socket (if it works you may need to get an experienced person to fix the socket your trying to plug the tv into)
Dec 20, 2010 | Televison & Video
Power went off and came back on last Friday and now tv wont turn back on
Have you got a stand by light on, or is tv dead totally.I would Check plug fuse if dead, My suspect would be power supply capacitors drying out (had this fault recently with friends tv) this caused tv to be working sometimes but eventually stuck on standby. Capacitors are cheap but not a job for the novice.
You could ask local tv shop for estimate
pete
Nov 08, 2010 | RCA L37WD12 37 in. LCD HDTV
Nov 01, 2009 | Televison & Video
No Power Sony KV-27FS12
IF the unit is completely dead (no standby light at all) then teh main fuse is most likely open. Try replacing that first. If the stnadby light is on, then when you attempt to turn it on, the light shouild blink. If so, the blinking should be a repeated count with a short pause between sequences. Post that count here as it will indicate what circuit has the problem. We will continue from there.
Thanks,
Dan
Feb 11, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
My magnavox model mwc20t6 keeps turning off after 10 to 20 secs
tv was working fine however when we moved it to another room it will not power on at all even using different plug ins
Nov 22, 2008 | Philips Magnavox 20MC4304 20 in....
Tv wont go from standby to on....
I SUGGEST TO CHECK THE INTERNAL FUSE , IT MAY BE OPEN
Dec 06, 2007 | Televison & Video
JBL encounter
HI! Red14 happy holidays
Well, may be a lot things, from bad cable, welding inside , or bad resistor is burn. but check the cable, and if you can open the panel on inside speakers, try to figure out if the cable is not loose, or bad.
Nov 27, 2007 | JBL Encounter 2.1 Computer Speakers
Televison & Video Logo
Top Televison & Video Experts
