Question about Pentel Arts Wet Erase Chalk Marker, Chisel Tip, Black Ink, 1 Pack (SMW26BPA)
Can I have more information about liquid chalk marker?
Replace rear side marker light
I had this message sent to me to solve....THIS IS MY QUESTION THAT I ASKED....LOL....SINCE THEN; I'VE BEEN INFORMED THAT YOU HAVE TO GO THROUGH THE OUTSIDE TAIL-LIGHTS TO GET TO THE MARKERS
DOES ANYONE ELSE KNOW ANOTHER WAY?
I have stainless steel covers over my tail-lights and will have to remove the "adhesive" on the covers to remove the tail-lights...HELP!
Jul 05, 2014 | 2007 Chevrolet Corvette Convertible
What liquid solution will disolve chalk
If you can't rub the glass because it's coated, try an auto-parts store for solvent to remove the chalk.
If it's bare glass, a razor-blade scraper will do the trick, but don't scrape the tinted/coated side! Or you could use an auto-detailers clay bar - see http://www.wikihow.com/Use-a-Clay-Bar
Jun 25, 2014 | Computers & Internet
Straws in the tank as white chalk
try using liquid soap in stead of powder see if it clears up
Jan 10, 2014 | Whirlpool Washing Machines
What are tailors tacks?
Tailors tacks are helpful when you are trying to transfer details from the pattern to the fabric. They are little squares of fabric that you can use to mark where the button is going to be or where darts will meet up.They are easy and quick and very good if you can't use fabric chalk or markers.
Feb 25, 2013 | Crafts & Hobbies
What is a whiteboard?
A whiteboard is a non-electronic variation of the traditional "rewriteable" schoolroom blackboard, but is white instead of black and of a material that can be written on with colored markers (known as dry erase markers). Dry erase markers are easier to erase than the chalk used on a blackboard (which sometimes requires a wet rag for thorough erasing).
Jan 24, 2013 | Office Equipment & Supplies
My 3yr old daughter used permanent marker to write on our toshiba regza flat screen tv.. how do i remove the ink from the marker?
there is a liquid called stoko slig which is used to remove permanent marker they are on the web i think they based in stafford hopes this helps
Oct 18, 2012 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Manuel has 6 boxes of chalk having 100 pieces each and 7 boxes of colored chalk having 20 pieces each.he shared equally the colored chalk among his 4 friends. how many chalk does manuel have?
If manuel is sharing the box with 4 friends and himself that is 5 people.
First multiple 6 times 100= 600 chalks/ 5 people. so 120 chalks per person.
Then for colored chalks. 7*20= 140 chalks/ 5 people. so 28 colored chalks each.
In total manuel and each of his friends have 148 chalks each.
Jun 15, 2011 | Computers & Internet
Have a 2004 Peterbilt 379, headlight setting is terrible, tried setting them by eye but just not right, does any body have any specs or ideas?
Yes, if you are running over- the- road just stop in a State that has vehicle inspections and they can set the lights to their specs. In those States that have an inspection setting the headlight aim is part of the job.
Next method, park your unit about 20 feet from a garage door or the side of a building or carwash. Use some tape or pencil and make 2 crosses. The passenger side is allowed to be high and slightly to the right. A correctly aimed right headlight will focus on the curb or lane marker with the right headlight spot-on the lane marker. This will mean you will be safely within your lane on the right side of your truck as long as the headlight hits the lane marker.
For the left light it is suppose to be almost straight ahead and not tipped out to oncoming traffic. In some States the left light is turned slightly towards the center of your truck. You can check against the crosses you put on the surface of the building and watch the beams move as you adjust the lights. Use some chalk to mark where the tires were so you can get into the same spot.
I had to do some Vehicle Inspections in Texas years ago. I want to say the headlights were suppose to be 42" high at 20 feet, but you have a Peterbuilt. And now some of the cars are barely 48" high.
Mar 04, 2011 | Ford F-150 Cars & Trucks
How to change the head gasket on a 1998 cavalier.
take off the belts mark timing marks before doin soo save you hours white chalk or black magic marker but then you have 16 bolts in the head have to take out then head lift off scrape old off (this is important make sure the gasket surface 100% clean then put new on and then put all back togethor make sure timing is exact you will have to unplug a bunch of senors and wires but thats around a 12 to 22 hour job depending experience make sure change oil after wards too
Sep 14, 2010 | 1997 Chevrolet Cavalier
Do i add the blue chalk inside the power winder?
Yes there is a small sliding door most likely where the chalk line comes out, pull that back and squeeze it in. Hope this helps. D
May 21, 2010 | Stanley 47 464 Powerwinder Chalk Box 3...
Pentel Arts Wet Erase Chalk Marker, Chisel Tip, Black Ink, 1 Pack (SMW26BPA) Logo
120 people viewed this question
Top Pentel Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Pentel Office Equipment and Supply Expert? Answer questions, earn points and help others
