Question about Garden
Motor starts then hunts will not
Starts but will not run hunting all the time
  •  johnny rebel
    johnny rebel Apr 04, 2015
    Hi Steve Smith, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Top Expert:
  • Garden Master
  • 51,587 Answers
Remove air filter and see if it runs better
Posted on Apr 04, 2015
    Top Expert:
  • 10,875 Answers
Chambers 3 & 4 are not firing
wet indicates excessive fuel
check the injectors and seals
run the fault codes
do a compression test to check gasket between 3&4
Nov 15, 2015 | Cars & Trucks
I have a nissan sentra 2000 model has idle hunt problem. replaced TPS IACV had computer remanned. when vehicle starts hunting can shut car off then restart idles normal. shut off again wait 2-4 minute
You check fuel pressure?
OBD Codes in ANY Module?
All Emission Monitors Run clear?
Look at a trouble chart for the IAC problem
I do not know what having the computer remanned means
If it was replaced or not, it may need an update flashed
Did you Google the problem & check nissan forums?
Slip into service bay at a dealer, from the outside & ask a
tech,I do that all the time,no one will stop you,your going to
parts dept (right & got lost)
Nov 06, 2014 | 2000 Nissan Sentra
Mountfield rotary 4 stroke grass cutter motor 'hunting' continuously.
Norman PRICE THE WORD HUNTINDG IS TRUE THE MOTOR IS LOOKING FOR FUEL ON SOME MOTORS YOU ADJUST THE MIX ON THE CARB CHECK THE AIR FILTER TO SEE IF PLUGED ON A FOAM FILTER YOU CAN CLEAN ON A PAPER YOU WILL NEED TO REPLACE. ANOTHER THING IS HOW OLD IS THE GAS . TODAY THE GAS IS ONLY GOOD FOR A MONTH,
Apr 20, 2014 | Garden
Idle up down
hunting or surging ilde. name the 2 RPMS, low and high , is it hot or cold engine this issue.? 400rpm or 1000 or 2000 all are diff.causes.
no year, stated. so cant help.
but ill answer in the generic,
1: the ECU (got a carb,? )
the ecu controls idle speed at all times.
if not , there is a problem (you)
A: air leaks in the induction will make motor race at some point the ECU/ISC loses control. and hunts. trying hard to correct it.
b: egr stuck open idle too low, iSC cant correct it,, bad EGR.
c: engine EFI running way too leak starving for fuel so it hunts for 2 reasons < ISC hunting, and lean does that.
lean is gross power loss and opening throttle bogs the engine.
so is double bad. ISC makes it worse,
all this breaks down to 2 reasons.
1: ISC bad. in some way (gummed up. or restricted inside)
2: bad fueling or air leaks. vacuum leaks.
try answers , the hot cold question and the 2 speeds, of the hunt.
lowest rpm and highest of the hunted range of RPM.
Nov 23, 2013 | Honda Civic Cars & Trucks
Qualcast Motor Mower Starts but will not run
there will be a butter fly in the carb that pulsates this is conected to rev cable plastic may have snapped or cable come loose
take it it is petrol
Jul 29, 2012 | Garden
I set up Hunt Group 1 (290) on a CICS, w/6.1 softewre with A Call Pilot 100 and assigned & initialized mailboxes for each Hunt Group member (222, 223 & 224) to FNA to Voicemail (227) after 4 rings....
Without having the programming manual on hand for this switch I have to generalize from other switches. Double check your auto forward settings within your hunt groups. It sounds like you have auto forward set wrong. If you have the voice mail set to engage on the 4th ring try changing that to engage on the 6th ring with the forward within a hunt group to forward to next available on the 3rd ring, see if that helps.
Aug 05, 2010 | NorStar Cics 6.1 & Call Pilot 100...
Rpm hunting
check for a vaccuum leak this is where i would start if it rolled into my shop. possibly a PCV valve sticking or a hole in the hose, this hose should run from the valve cover, or crank case and then to the intake, or carb.
Apr 25, 2010 | 1998 Isuzu Trooper
2003 Eclipse V6 Hunting at idle after we replaced the Timing belt
on my sons car it was the idle speed control motor it on the throdebody
Apr 06, 2009 | 2003 Mitsubishi Eclipse Spyder
Stalling & hunting idle
does throttle sensor check out correctly???
Jun 10, 2008 | 1995 Volkswagen GTI
Garden Logo
49 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
