Question about Konica Minolta Bizhub Pro C6500 Color Copier Color Printer
How do I fix FF display error code
It is displaying FF code error instead of 00 therefore unable to finish booting, in addition the monitor is not displaying controller.
  • stephanie Sep 01, 2015
    I have this same error - anyone have advice?
My LG display is reading ER FF what does this mean and what can I do to fix it?
Error Code Er FF
This code is not to be confused with the O FF or demo mode error message. The "Er FF" error code indicates a problem with the unit's freezer fan. The freezer fan controls the temperature in the freezer. The source of this error is most likely ice buildup. As with the Er IF error, allowing the unit to thaw should resolve the issue. Contact customer service if the error code continues to be displayed after having thawed the unit.
Hope helps.
Apr 03, 2011 | Refrigerators
My display is damaged on my vaio laptop so I have to use an external monitor. How do I make the laptop go to the monitor BEFORE windows boots. My problem is I cannot make my computer boot up and I think I...
Usually, you can press a key combination to send the video to the VGA connector instead of the notebook display. The pictures on the internet of the keyboard are not very good - but it looks like pressing the "Fn" key (lower right between the "Ctrl" and "Windows Logo" keys) AND the ""F7" at the same time, should redirect the signal to a monitor connected to the VGA connector.Pressing the keys again will send the signal to the notebook display again.
I hope this helps. Please rate this reply - thanks!
Dec 13, 2010 | Sony VAIO VGN-NR385E Laptop
Ive brought a new gaming rig, as follows CPU: Athlon II X2 240, 2.8Ghz MBD: Biostar TA770E AM3 / DDR2 / SATA RAM: 2GB DDR2 800MHz Case: CoolerMaster Elite 330 PSU: WinPower 450w One 300gb Sata drive One...
These new graphics cards pull a lot of power from the power supply. I know you didn't start off having this issue but given the symptoms you are experiencing I'd take a closer look at the power supply and perhaps replace it with a 650 watt or better.
Nov 16, 2009 | Acer Aspireā„¢ T180 PC Desktop
ATI Radeon 9100 AGP - best driver, how to upgrade
Try this free website. You might be able to get driver updates there. www.driveragent.com
Good luck
Dec 13, 2008 | ATI RADEON 9100 (64 MB) AGP Graphic Card
Recieving error code FF and pc will not boot/recognise harddrive
the problem it is in harddisk
is that u have ur smp (power supply)
just check the power supply & insert the cable
properly in to the slot of motherboard & check whether the display has come if it comes than boot the xp cd if problem occurs go to nearest shop of computer
Dec 04, 2008 | Abit AV8 Motherboard
DCP-130C Clean Unable
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- switch off the printer ,switch it on
- ready to print
Jan 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
Hi :) plese help
remove all external devices and try again does it beep at all?
Jan 03, 2008 | HP OmniBook XE3 Notebook
Disc error
1. Power up unit with no disk in the tray
2. After "no disc" shows on the front display, press PAUSE on the remote
3. Press in order: 1, 4, 7, 2 on the remote (short keypresses). A new screen will show up, EEPROM settings with a green background
4. Write down the EEPROM string for backup/restore purposes in case you screw up. My string was 55 53 00 45 02 55 64 FF (compare with the default string of the 312, which is 55 53 00 45 14 55 64 FF).
5. To enable VCD playback, move the cursor to the "45" (4th group of characters from the left; use the remote up/down arrows to move right/left) and enter "46" or "47" instead, then press ENTER to commit
6. To enable SVCD playback, move the cursor to the "64" field (second from the right) and enter "FE" instead. To enter "F" press "6" on the remote and keep pressed. To enter "E" press "5" on the remote and keep pressed. After you're finished entering "FE" press ENTER on the remote to commit
7. Press PAUSE on the remote to exit the EEPROM screen
8. Power off, then power on again the player
9. It now plays SVCDs and/or VCDs depending on the codes you entered.
The final EEPROM strings with both VCD and SVCD enabled are:
55 53 00 46 02 55 FE FF and
55 53 00 47 02 55 FE FF
(either works)
NB the replacement of 64 by FE was in the past wrongly labeled as Macrovision hack. That's not true. What it really does is enable SVCD playback. If you only do the #5 above, you'll only get VCD playback. If you only do the #6 above, you'll only get SVCD playback. If you do both, you'll get VCD and SVCD playback.
(SVCD playback was especially important to me because I have several hundreds of them - mostly TV shows recorded on my TiVo, then exported to the PC and converted to SVCD)
The other hack for the DVB-312 also works on the 412 (see the configuration screen):
1. press SETUP on the remote
2. Go to "TV Aspect" and move the cursor to "16:9"
3. Press in order: 1, 3, 9, 7, 1, 3, 9 on the remote, then press ENTER
The info showing on that screen for the DVB-412 is:
Model: Zenith ZV8020001
Region: 1
Chip ID: M3355A-B
Servo ver: S101_43180
Microcom ver: V1.50A MP
PROM: 55 53 00 45 02 55 64 FF
Factory reset... done...
(the PROM I listed above is before the VCD/SVCD hack)
Aug 16, 2007 | Zenith DVB412 DVD Player
It keeps ejecting the disc and saying disc error
(either works)
Region: 1
Chip ID: M3355A-B
Feb 17, 2007 | Zenith DVB412 DVD Player
Out of Range message on monitor after T5300 finished booting. No Image.
The out of range refers to the screen resolution size of your pc as apposed to the monitor. It is unable to operate at the set refresh rate and screen res.
Jan 31, 2007 | HP T5300 (dc643a#abu) Network Terminal
Konica Minolta Bizhub Pro C6500 Color Copier Color Printer Logo
546 people viewed this question
Top Konica Minolta Computers & Internet Experts
Lawrence Oravetz
David Payne
David Payne
Fernando Torres
Fernando Torres
Are you a Konica Minolta Computer and Internet Expert? Answer questions, earn points and help others
