Question about Nike Triax Watches
Help me set the time on my nike WC0040 watch - Triax Nike Watches
  • 29 Answers
SOURCE: how to set a nike triax watch
Press and hold in the mode button the seconds should start to flash.
Press top right button to select hour.
Press set button to advance hour.
Press top right button to select minutes.
Press set button to advance minutes.
Repeat this for the month/dte/dy/yr
Press mode button when done
Posted on Mar 11, 2008
SOURCE: nike watch
In TIME mode - not ALARM - top right hand button marked "START/LAP" toggles hourly beep on/off. As not in ALARM menu, easy to put on unintentionally.
Posted on Mar 23, 2009
nikeananth
  • 267 Answers
SOURCE: how do you set the nike imara soar watch?
HI,
this is the user manual will help you to set the time.
http://safemanuals.com/user-guide-instructions-owner-manual/NIKE/IMARA-SOAR-_S
thank you,
vijay
Posted on Sep 30, 2009
escapement
  • 2334 Answers
SOURCE: don't know how to set time on Nike Women's WC0061
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all NIKE watch manuals. Rate me, please
Posted on Mar 14, 2010
escapement
  • 2334 Answers
SOURCE: I can't change the time on my nike Imara watch.
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all NIKE watch manuals.Rate me, please.
Posted on Mar 18, 2010
I need to change the time on my nike wk0006 watch, but nike doesn,t sell it anymore...WHAT DO I DO!!!!????
TRY!
Make sure the watch is facing the correct way. Put the watch on your wrist as you normally would, or pick it up by the strap with your left hand. You should see that the Nike swoosh is right side up. You should be able to read the time.
Find the left side of the watch. This will be your left when the watch is facing you correctly the same way that you would look at it to read the time. You will see at least two buttons. One will be labeled "mode" and the other will be labeled "set."
Press the "mode" button. Press the "mode" button. Continue to press the "mode" button until you have scrolled through the options and are on the correct setting. The correct setting should be "time."
Hold down the "set" button. You should see the currently set time on your watch and the hour should be flashing. You should see a plus sign (+) and a minus sign (-). If your current time says three (for example) and you want to read five, press the button that corresponds with the plus sign. If you want to go backwards, press the button that corresponds to the minus sign. When you are finished hit next.
Change the minutes. Now the minutes should be flashing. Repeat step four: press the button that corresponds with the plus sign to increase the minutes. Press the button that corresponds to the minus sign to decrease the minutes. Hit "next" when you are finished.
Hit "done." Congratulations, you have now successfully set the time on your Nike watch. Now your watch should read the correct time. If you want to get really crazy, you can repeat the steps above to change the date on your Nike watch.
Sep 28, 2014 | Nike Triax WK0006-001 Watch
I don't know how to set my nike watch.
How to set time on Nike watch WC0061. PLease help
Sep 30, 2010 | Nike Imara Strive Black/Border Blue WC0061...
Don't know how to set time on Nike Women's WC0061 watch
Mar 14, 2010 | Nike Wc0061 040 Imara Strive Watch
One of the screws that connects the band to the body of the watch fell out. Is there any way to replace screw without sending it in to Nike? What size screw would I need if I went to the hardware store?
It is unlikely that any hardware store will have the size of screw that you need, since watch screws tend to be much smaller than are generally available.
The best place to go is a watch shop. They should be able to get it replaced for you.
Feb 21, 2010 | Nike Mettle Sledge Watch WC0040 096
How can i get the user's manual? WC0040
http://www.nike.com/timing/
Find your watch and it will allow you do download your manual in pdf format! :-)
Jan 09, 2010 | Nike Mettle Sledge Watch WC0040 096
"one touch backlight"
You must hold start button 3 seconds, then your backlight turn on by adjust button
Jul 18, 2009 | Nike Mettle Sledge Watch WC0040 096
How do I set the time on my digital nike presto watch?
KEEP YOUR FINGER ON THE BOTTOM LEFT HAND BUTTON. WHEN IT STARTS BLINKING PRESS IT AGAIN. USE THE OTHER BUTTONS TO CHANGE TIME
Apr 03, 2009 | Nike Presto CEE WT0001-607 Wrist Watch
Nike watch problem
Okay, mine's a Chisel but I'm pretty sure the module is similar, if not the same, across the Mettle range.
Anyway, press and hold the light button - marked adjust - until the display says "hold to adjust"; after a couple of seconds the time display will return and the hours will be flashing.
To adjust up, press "start/+" and down press "stop/-". To cycle through the options, press "mode".
Once you're done, press the "adjust" button again to return to regular timekeeping mode.
Enjoy your Sledge - if you don't I'll have it!!
Regards,
Martin.
Jul 16, 2008 | Nike Mettle Sledge Watch WC0040 096
Watches Logo
44 people viewed this question
Top Nike Watches Experts
Ansel Alberto
Ansel Alberto
TIME TRACK SERVICES
TIME TRACK SERVICES
Are you a Nike Watch Expert? Answer questions, earn points and help others
