Question about Zhone 4PORT ADSL2+ MODEM BRIDGE/RTRW/BRCM TR069 & INT P - 6218-I4-200 Wireless Router
I am not able to start windows remote connection on my LAN network. I have a Zhone router Model: 6218-I4.
I have disabled firewall from the PC, funny thing is with other router DRP is working fine. only when obtained IP from this router. i have removed other router from the network already. Please help me to find a solution for this.
SOURCE: Changed router ip now unable to connect...
hi, i have the same problem that cannot connect to router after i changed ip address... i set my network connection to ip address 192.168.254.2 & subnet mask 255.255.255.0 & default gateway to 192.168.254.254... i can ping ip address 192.168.254.254 but cannot get into the web browser... i cant go back the router configuration page... pls. help... my router is zhone 6218...
Posted on Jan 18, 2008
ayamaya
  • 143 Answers
SOURCE: great problem with router zhone 6218
i assume that you're not prompted with the log in screen. if so, you need to check if your computer is properly connected to the LAN/ethernet port of the router (Note: you need to use a hardwired computer if you want a stable connection while checking your wireless settings) and if it has a valid ip address which shoud be within the subnet of the router's ip address (Note: by default the router's ip address is 192.168.1.1 and "admin" is the default username and password)
if you're not sure of the current ip address of the router. go to command prompt and type ipconfig. it'll list there the default gateway which is the router's ip address.
now if you have checked that the computer has a valid ip address and it is properly connected to the router but you can't still access the router's page, there could be a program that is blocking the connection. try to disable any firewall or any antivirus programs installed on your computer.
hope this'll help you. you can click here for the manual if you would like to read some more about the router.
ciao!
Posted on Aug 13, 2008
SOURCE: zhone 6218
Zhone (6218-12-200) I have wifi encrypted to manage 4 passwords. I am having a problem entering 3 additional at 64-bit - keeping in mind each person would be assigned to individual access codes
Posted on Nov 11, 2008
SOURCE: Hello, I need help. I am trying to find out the
admin admin
Posted on Aug 15, 2009
SOURCE: Need login and password for a Zhone router/modem
If you got your Zhone modem from consolidated communications then the login is admin pass is cciadmin
Posted on Dec 29, 2009
I have a Zhone router, model number 6218-I4-200-0CL. I'm trying to figure out how to forward a port, but there is no actual "Port Forward" option under the configuration options. There is...
Hi!
Please follow the guide here... It's for a different Zhone model - but it should work exactly the same!
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Mar 17, 2011 | Zhone 4PORT ADSL2+ MODEM BRIDGE/RTRW/BRCM...
How do you open the NAT on this router
Hello, You can perform the following steps to open NAT.. 1) You can take the IP add of your device( X-box, PS3) and then contact the device vendor(Xbox or PS3) and ask them to give port numbers for your device. Once u get the port numbers you can either open ports on the router by logging into the router interface using your Default gateway(192.168.2.1) of the router or you could put the IP add of your device in DMZ on the router. Basically this will keep the device out of the firewall of the router( Which is the main reason for this issue). 2) If the first step didnt work you could disable the firewall on the router.
If both the steps didnt work you could check if your router has any firmware update or it has to be reset and re-configured and the above steps should be re-done.
Hope this helped.
Feb 15, 2011 | Zhone 4PORT ADSL2+ MODEM BRIDGE/RTRW/BRCM...
Can i connect a wrt54g wireless router to a zhone? to get wireless access on my laptop and wired connection to my computer?
s u can connect as u wish. connect a utp cable lan port of ur wireless router to ur pc. assign ip for ur pc with router's ip as gateway address. similarly search for wireless networks from ur laptop. u will find ur wireless router to in that range. click on it connect to the network. the ip gets automatically assigned for the laptop. Thats it u are done!!!
Jul 21, 2010 | Zhone (6218-I2-200) Router
Need to change the NAT setting on my Zhone 6218 DSL modem. How?
try these simple steps...
connect your computer to one of the LAN(wired) ports of router...
check the ip address and default gateway of your local area connection through control panel > network connections.... if you get the ip adress in the range of dlink router then try going to start > run > type "cmd" and hit enter >command prompt will appear... in command prompt type this
start iexplore(default gateway address) and hit enter...you will see the settings page of your modem.... go ahead and disable firewall and enable dmz for your ip address... also forward the ports that are necessary for your gaming device...
Jul 16, 2010 | Zhone (6218-I2-200) Router
Newbie on this I added MAC adress
Reset the router and start all again. look for a little hole and in the hole should be the reset button, with power off, reset it and do it all again.. this time properly..
get your manual for a how to do it below. http://www.retrevo.com/samples/Zhone-Router-manuals.html
Mar 06, 2010 | Zhone (6218-I2-200) Router
ZHONE 6218 unable to connect
Try to configure you router with WPA authendication. provide some encryption password,if asked. Then configure your lifebook with manual ip by wifi adapter ->network settings-> tcp/ip properties - > specify manual IP something like 192.168.1.2 Now try connecting to your router.It should ask for network key and will connect if key provided matches with the one configured.
May 21, 2009 | Zhone (6218-I2-200) Router
When using utorrent or any other torrent client it says i have problem with my network configuration
You'll need to forward the port you have selected in your BT client (you can set it / checj ut in uTorrent: Ctrl+P -> Connection -> Port used for incoming connections. It should be something between 40000-52000.) to accept incoming connections.
Unfortunatly there is no guide for your router model, but you can help with this one http://www.portforward.com/english/routers/port_forwarding/Zhone/6218-12-200-0TT/6218-12-200-0TTindex.htm, also port forwarding is referenced in your owners manual, so you should check that too.
Mar 21, 2009 | Zhone (6218-I2-200) Router
Router not working
Hello Sean Lin,
The only option for the 5th pc would be to get it wirelessly connected. You need to install a wireless adapter to your pc. Set the IP & DNS to automatically obtained from router.
You also try to adjust or temporarily disable the your firewall and other securities;
Disabling Windows Firewall
Note: A firewall is designed to help protect your computer from attack by malicious users or software. Such software includes viruses that use unsolicited incoming network traffic that infects your computer. Before you disable your firewall, you must disconnect your computer from all networks, including the Internet. To disable your Windows firewall, please follow these steps:
Disable Internet Connection Firewall in Windows XP or Windows XP SP1
1. In the Control Panel, double click Network and Internet Connections. Then, click on Network Connections icon.
2. Right click on Local Area Network (LAN) Connection on which you want to disable the Internet Connection Firewall (ICF), and then click on Properties.
3. On the Advanced tab, you will see protect my computer or network check dialogue. Then, click on the Settings tab.
4. Click on OFF then OK.
Disable Windows Firewall in Windows XP SP2
1. Please click on Start, then click Run. Then, type in firewall.cpl and then click OK.
2. On the General tab, click OFF (not recommended) and then click OK.
I hope this troubleshooting steps will help..if not please notify me
Nov 20, 2008 | NetGear WGR614 54Mbps Wireless Router...
Great problem with router zhone 6218
ciao!
Aug 13, 2008 | Zhone (6218-I2-200) Router
Dec 24, 2007 | Zhone (6218-I2-200) Router
Zhone 4PORT ADSL2+ MODEM BRIDGE/RTRW/BRCM TR069 & INT P - 6218-I4-200 Wireless Router Logo
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Joe Goldman
Joe Goldman
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
