Question about Bonnet Catch Flush Locking In Black
I cant open my bonnet with my key the catch is stuck my key wont turn
Flat battery cant open doors with remote ,cant open door manualy with key
hi kayne, is it possible to open the boot with the key and climb through to get access to the bonnet release catch.
good luck
Apr 26, 2015 | Halonet 98-02 HONDA ACCORD 4DR POWER FRONT...
The bonnet of my nissan misra wont fastern
Doe`s it click onto the secondary saftey catch?
it could be that the cable has stuck, try pushing the bonnet release handle back to it`s original postion (the opposite to how you opened it!) then try shutting it.
Mar 19, 2012 | Cars & Trucks
Bonet is stuck, put the key in turn it left and its not opening,
Look into the grill at the top you will find the bottom of 6 plastic screws, 4 you get two via the grill slots use a chisel and cut them off, Then one either end of the grill. Place the chisel between two plastic layers, gently lift , check and cut, one each end.
With a wiggle that's the top loose, There are two clips holding the bottom in place Put your fingers through the bottom slot in the grill, push down clip and greatly pull the grill, do both sides, It won't come right out but your aim to loosen it., The lock is held in place in a sleeve with a plastic clips each side, you have push the barrel with a suitable item, this is to push it out of the sleeve and out of its housing, It may need a tap!!
Gently wiggle and pull the grill off
Lock
The lock is a 'lock barrel along a shaft to a white plastic coupling' this fits in to the 'bonnet lock'
The security is at the coupling to bonnet lock in the form of a cross shaped plastic key
The key is fitted and held in place in the coupling, and when installed it's fitted in to the lock, and once it's in the lock part it will not come out, so therefore any jolt, pull, movement dislodges the plastic key from the coupling side and due to its design it will not slot back in so the lock barrel just rotates
To open you have to apply pressure on the shaft towards the left and into the coupling and turn the key in the lock barrel at the same time in a aim to get the coupling to catch the plastic key (take a few minutes) but it opens in the end if this is the fault, (alternatively remove the two bolts that hold the bonnet catch to the bonnet)
Once bonnet open remove the bonnet lock mechanism, then with draw the lock barrel, shaft, coupling, By looking in side you will understand regarding the cross key
Anyway you need to remove one of the catches from the side of the plastic key This way it will fit back in to coupling.
Reassemble
Mar 09, 2011 | 2006 Ford Focus
The Bonnet wont open on my Ford Focus 2001, The key will turn but nothing happens? When I Try and lift Bonnet the catch is just stuck.
Have someone push down on the hood (Bonnet)
and have another person pull the inside level,to get it
open when it's stuck. Once open,spray some lubricating spray all over the latch mechanism to help
it stop hanging up,unless the spring is broken,or weak.Good luck.
Mar 31, 2010 | 2001 Ford Focus
Bonnet catch on ford focus wont open turned key as normal but on second turn it wont open
pig of a job but you will need to get a long screwdriver up from underneath and release the second click (safety release)
Sep 10, 2009 | 2006 Ford Focus
Renault clio bonnet wont open
Get a second person to pull bonnet catch and you push up and down on the bonnet whilst catch is being pulled. 1, cable possibly stretched, 2, look at bonnet catch under the coloum to see if wire is attached, 3, try and lie under car and look up the back of the bulkhead to see the catch and release it manually. Hope that helps.
Aug 17, 2009 | 2004 Volkswagen Golf
Ford focus estate - open bonnet
On my 05 model, you need to twist the ford badge on the bonnet anti-clockwise, pushing the left side of the badge down, which will reveal a keyhole. This is then opened with your ignition key. Once the bonnet pops, you just need to release the bonnet catch.
Hope this helps.
Apr 27, 2009 | 2005 Ford Focus
How do you open the bonnet
Flip up the badge on the front radiator grille, put key in and turn one way to release first catch, then turn other direction to open.
TL
Jan 23, 2009 | 2001 Ford Focus
Cant open bonnet of Ford Focus x reg grill operated key lock wont turn
Stuck lock, bonnet won’t open ,,,
You do not need to drill holes in the grill or pay ford £200+
DIY..How?
Look into the grill at the top you will find the bottom of 6 plastic revscrews, 4 you get two via the grill slots use a chisel and cut them off, Then one either end of the grill. Place the chisel between two plastic layers, gently lift , check and cut, one each end.
With a wiggle that’s the top loose, There are two clips holding the bottom in place Put your fingers through the bottom slot in the grill, push down clip and greatly pull the grill, do both sides, It won’t come right out but your aim to loosen it., The lock is held in place in a sleeve with a plastic clips each side, you have push the barrel with a suitable item, this is to push it out of the sleeve and out of its housing, It may need a tap!!
Lock
The lock is a ‘lock barrel along a shaft to a white plastic coupling’ this fits in to the ‘bonnet lock’
The key is fitted and held in place in the coupling, and when installed it’s fitted in to the lock, and once it’s in the lock part it will not come out, so therefore any jolt, pull, movement dislodges the plastic key from the coupling side and due to its design it will not slot back in so the lock barrel just rotates
Reassemble
This is a brief description But the cost to me was 45 minutes, £2 for a pack of plastic rivets / screws, and I cached my bumper with the chisel £5 for a touch up stick Total £7. Well worth the time and effort
Jun 25, 2008 | 2000 Ford Focus
Locked out of car
I took my 99 Laguna to my local mechanic with a stuck bonnet. He pulled the lever from inside and told me to press down on the bonnet at the same time then open the bonnet as normal with the outside catch. It worked ok. After doing it oil the catch mechanism and it now works ok-but best to keep trying it to stop it seizing again.
Jun 15, 2008 | 2000 Renault 181
Bonnet Catch Flush Locking In Black Logo
21 people viewed this question
Top AeroCatch Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you an AeroCatch Vehicle Part and Accessory Expert? Answer questions, earn points and help others
