Question about Health & Beauty
Why does the green light not come on when I turn the key on, on my days strider mx 4. I bought this secondhand 3 years ago and its been ok until now. Thanks.
    Sergeant:
  • 313 Answers
Check all battery connections, Check battery condition as after 3 years they will be coming to their age limit. is the charger circuit ok
Posted on Jun 16, 2015
dromtonpa
  • 40 Answers
SOURCE: Have a problem with strider 3 wheel mini where the
The batteries really need to have their level checked with an ohm meter. If the chair is left unplugged from the charger and unused for a long period of time,the volts can drop below 12vltsDC and the charger won`t be able bring them back up. You may have to call a dealer or find a friend with an ohm meter.
Posted on Mar 26, 2009
gewiz
  • 1263 Answers
SOURCE: no drive,flashing green light
Are you sure the FREELEVER is in the right position ? , to test try to push the scooter ?
Battery Low ?
Posted on Jun 13, 2009
  • 3 Answers
SOURCE: my wifes strider chair runs
Ztarg is the Medline Industries approved service and parts distributor for the Strider and Gemini Scooters.
Their contact information can be found on their website www.striderscooterservice.com
Posted on Jul 09, 2009
SOURCE: 4 whhel strider won't run, batteries charged
the motor is not working perfectly and chnge motor or check the connection perfctly
Posted on Jul 14, 2009
  • 3 Answers
SOURCE: strider chair starts and stops
Troubleshooting for this model is now available at
http://www.striderscooterservice.com/blink-codes.html
Posted on Jul 23, 2009
Strider maxi charger flashes continuous while plugged in , the 3 diagram lights
Hi have u tested you're batteries u can buy a BATTERY LOAD TESTER ON E/BAY. OPROX PRICE $35. THIS WILL GIVE U an accurate reading on there condition .....Cheers
Jun 16, 2016 | Electric Strider Maxi 4 Wheel Mobility...
Days Strider Midi 4 Plus faults
HOW DO GET THE REAR WHEEL OFF MY SCOOTER NUT VERY TIGHT
Jul 10, 2012 | Electric Mobility Mobility Electric Power...
I have a days strider scooter which is charged (i think) and the green light is flashing when the key is turned on. the scooter does not move at all
Did you try to adjust the speed control? Is it on full or slow? This is the number one issue that people tend to forget.
Apr 12, 2011 | Electric Mobility 4 Wheel Power Electric...
Why won't Minolta film Scanner work with iMac and OSX 10.6.2?
Hi
I bought a secondhand, nearly new Minolta Dimage Scan Elite 5400 a few years ago but never tried to use it until now when I tried to get it to work with my iMac running OSX 10.6.2. I uploaded the Dimage software but I cannot get it to recognise the scanner - any suggestions? Do I need to get updated drivers?
Feb 02, 2010 | Konica Minolta Dimage Scan Elite 5400 II...
Jul 13, 2009 | Electric Strider Maxi 4 Wheel Mobility...
My wifes strider chair runs a bit the stops. Then she turns off the key, turns it back on and it runs a little bit a stops. The green light stays steady until it stops then blinks..any help?
Dec 15, 2008 | Electric Strider Midi 4 Wheel Mobility...
Uniden cordless model DC7758-4
Does the Uniden cordless phone model DC7758 have an answering machine?
Sep 30, 2008 | Uniden Cordless Phone
Sharp tv 2004 model
Program TV Code
1. Turn on the TV.
2. Locate the 5-digit code for your TV.
3. Slide the MODE switch to the TV position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
5. Using the number keys enter the 5-digit code for your brand of TV. If performed correctly, the green light under TV flashed twice.
6. Aim the remote at your TV and press the PWR key once. Your TV should turn off. If it does not turn off, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Slide the MODE switch to the DIRECTV position. Press TV POWER. Your TV should turn on.
Program DVD, VCR, Stereo Receiver, and Stereo Amplifier Code
The AV1 and AV2 switch positions can be setup to control a VCR, DVD, STEREO, second DIRECTV Receiver or second
1. Turn on the component you wish to control (e.g. your DVD Player).
2. Locate the 5-digit code for your component.
3. Slide the MODE switch to the AV1 (or AV2) position.
4. Press and hold the MUTE and SELECT keys at the same time until the green light under AV1 (or AV2) flashes twice, then release both keys.
5. Using the NUMBER keys, enter the 5-digit code for the brand of component being set up. If performed correctly, the green light under the selected position flashes twice.
6. Aim the remote at your component and press the PWR key once. The component should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
7. Repeat steps 1 through 6 to set up a new component under AV2 (or AV1).
Unable to Find Correct Code
If you were unable to find the code for your brand of TV or component, you can try a code search. This process may take up to 30 minutes.
1. Turn on the TV or component. Insert a tape or disk if applicable.
2. Slide the MODE switch to the TV, AV1 or AV2 position, as desired.
3. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
4. Enter 9-9-1 followed by one of the following four digits:
Satellite - 0
TV - 1
VCR/DVD - 2
Stereo Receiver/Stereo Amplifier - 3
5. Press PWR, or other functions (e.g. PLAY for VCR) you want to use.
6. Point the remote at the TV or component and press CHAN+. Repeatedly press CHAN+ until the TV or component turns off.
NOTE: Every time CHAN+ is pressed the remote advances to the next code and power is transmitted to the component.
7. Use the CHAN- key to step back a code.
8. When the TV or component turns off, stop pressing the CHAN+ key. Then, press and release the SELECT key.
NOTE: If the light flashes 3 times before the TV or component responds, you've cycled through all codes and the code you need is not available. You must use the remote that came with your TV or component.
Verifying the Codes
Once you have set up the DIRECTV Universal Remote Control using the above steps, use the following instructions to find out the 5-digit code to which your component responded:
1. Slide the MODE switch to the appropriate position.
2. Press and hold the MUTE and SELECT keys at the same time until the green light under the selected switch position flashes twice, then release both keys.
3. Enter 9-9-0. (The green light under the selected switch position flashes twice.)
4. To view the first digit in the code, Press and release then number 1 key. Wait three seconds, and count the number of times the green light flashes. Write this number down.
5. Repeat step 4 four more times for the remaining digits; i.e., press number 2 for the second digit, 3 for the third digit, 4 for the fourth digit and 5 for the final digit.\
Depending on how you set up your remote, the VOL and MUTE may control the volume only on your TV, regardless of the position of the MODE switch. This remote can be set up so that the VOL and MUTE keys work only with the component selected by the MODE switch. To enable this feature, perform the following steps:
1. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
2. Using the number keys, enter 9-9-3. (The green light will flash twice after the 3.)
3. Press and release the VOL+ key. (The green light flashes 4 times.)
Now the VOL and MUTE keys will work only for the component selected by the MODE switch position.
To Lock Volume to AV1, AV2 or TV
1. Slide the MODE switch to the AV1, AV2 or TV position to lock the volume.
2. Press and hold the MUTE and SELECT keys until the green light under the selected switch flashes twice and release both keys.
3. Using the number keys, enter 9-9-3. (The green light flashes twice.)
4. Press and release the SELECT key. (The green light flashes twice.)
Jan 26, 2008 | Audio Players & Recorders
LG old but brand new blank screen green light making a tik,tik,tik sound.
Nothing you can really do yourself with that. I would call manufacture and get solutions from them. When it comes to monitors, unless your skilled in repairing them you will only do more damage to them. If you really feel like jumping into it and have nothing to lose you should be able to find a service manual on this monitor here http://www.eserviceinfo.com/most_popular/list_8400.html and rip it apart to find the piece to replace.
Jul 17, 2007 | LG L2010B (Grey) (Gray) 20.1" LCD Monitor
Health & Beauty Logo
120 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
