Question about Acer Computers & Internet
My acer 4630z has its boot manager missing or corrupted...it happened when i use recovery method..how to fix it?
    Top Expert:
  • Acer Master
  • 8,211 Answers
See if you can get in to safe mode,
try rebooting and see if it will let you get into safe mode.
Posted on Apr 04, 2015
GodSpeed
SOURCE: d2d recovery
Send me an e-mail and I will send you the fix! If you can't downloadload it from the below link. I had the same problem. The mbr was replaced, you have to add RTMBR.BIN to the MBR and it will work again. As long as you can get on your desktop and run this bat file you will repair the D2D again. Took me an hour to learn what was wrong, It works 100% though.
I have the Aspire 5610Z with the 2GB 533 mhz memory Stock.
Link #1
http://rapidshare.com/files/64293596/Acer_MBR_F10_Repair.zip.html
Link #2
http://www.sendspace.com/file/ngd4ql
matrix@gainbroadband.com
Posted on Oct 22, 2007
mtspace
  • 103 Answers
Is the d2d erecovery function enabled in the bios?
To check, activate the BIOS utility, press <F2> during the POST; while the notebook PC logo is being displayed.
To enable D2D recovery ard disk recovery), select Main from the categories listed at the top of the screen.
Find D2D Recovery at the bottom of the screen and use the <F5> and <F6> keys to set this value to Enabled.
That should allow you to use the F10 function key to activate D2D.
* Note: D2D e-recovery is not in Acer Empowering Management.
AEM is a power management utility that supports ACPI (advanced configuration and power interface) which allows for maximum power conservation and maximum performance. (Managed by the windows OS)
Posted on Jan 04, 2008
  • 2692 Answers
SOURCE: extensa 4630z boot mrg is missing no restart programs
  4620z. To redo your computer Hard drive to the state that it was in when it came out:
Download the Post Ace disk Formatter CD ISO image.Last one on the list. I believe that is the "installCD" software
http://www.acerpanam.com/synapse/forms/portal20.cfm?website=AcerPanAm.com&siteid=7117&areaid=2&formid=3394#results
Posted on Jan 08, 2009
  • 240 Answers
SOURCE: Windows boot manager problem acer aspire 5920
Creating recovery discs After setting up the computer for the first time, be sure to create a set of recovery discs of the full factory image. the recovery discs are used to start up (boot) the computer and recover the operating system and software to factory settings in case of system instability or failure.
Posted on Jun 16, 2009
  • 13 Answers
SOURCE: acer extensa 4630z will not boot up.
If you want to go down the route of reinstalling windows, you will need the windows disk which came with the laptop.
Insert the Windows CD that came with your PC, and reboot your system. If you didn't receive a Windows disc with your machine, the files you need are sitting in a hidden partition on your hard drive. To access them, press the keys indicated on your screen when you reboot, but before Windows loads.
If it gives you the option to boot from the CD, make sure to do this.
Once you have got to this stage you follow the steps through. Delete all the partitions and the format the hard drive. You will then be able to do a clean install of windows.
Best of luck
Posted on Jul 07, 2009
How to fix my acer extensa 4630z? Its boot manager is missing or corrupted.
First you need:
To enter Recovery Console in Windows XP, you will need to boot from the Windows XP CD.
Watch for a Press any key to boot from CD... message similar to the one shown above.
Press a key to force the computer to boot from the Windows CD. If you do not press a key, your PC will continue to boot to the Windows XP installation that's currently installed on your hard drive. If this happens, just restart and try to boot to the Windows XP CD again.
  1. Enter Windows XP Recovery Console. The Recovery Console is an advanced diagnostic mode of Windows XP with special tools that will allow you to restore the boot.ini file.
When you reach the command line (detailed in Step 6 in the link above), type the following command and then press Enter.
bootcfg /rebuild
The bootcfg utility will scan your hard drives for any Windows XP installations and then display the results. Follow the remaining steps to add your Windows XP installation to the boot.ini file.
The first prompt asks Add installation to boot list? (Yes/No/All).
Type Y in response to this question and press Enter.
The next prompt asks you to Enter Load Identifier:.
This is the name of the operating system. For example, type Windows XP Professional or Windows XP Home Edition and press Enter.
The final prompt asks you to Enter OS Load options:.
Type /Fastdetect here and press Enter.
Take out the Windows XP CD, type exit and then press Enter to restart your PC.
Assuming that a missing or corrupt boot.ini file was your only issue, Windows XP should now start normally.
Apr 01, 2015 | Acer Extensa 4630z
Says boot manager is missing
Try inserting the windows recovery disc and reboot the machine. At the language screen, bottom left, click repair your computer. At the recovery options screen, click on startup repair. This should recover the boot manager file. Reboot machine when completed.
Mar 22, 2012 | Acer Computers & Internet
My bootmgr is missing on Acer Aspire 7736z. It is not allowing me to boot in safe mode(f8) or alt f10. How can this be fixed?
Unfortunately you have to reinstall the operating system. It's the best solution.
If I could be of further assistance, let meknow.
Mar 26, 2011 | Computers & Internet
Acer aspire 9301 notebook - cannot find acer recovery management for this model running windows vista ultimate
When booting, at the point when the POST screen dissapears press F8. It may take some practice to get it to work as there is a very small time window.
Select restore or recovery from the menu. It is a hidden partition on your hard drive. If it is corrupt or missing, use your windows disk at that point and select recover.
Hope that helps.
Nov 27, 2010 | Acer Aspire 3000 Notebook
Acer extensa 4630z webcam not working. cannot find it in device manager, what should I do next?
The issue might be due to corrupted webcam drivers. Try to find it out in device manager as it will be listed under Imaging Devices.
Reinstalling the webcam drivers may fix the issue.
Visit the below weblink for more information:
http://notebook-solutions.blogspot.com/2009/05/webcam-does-not-work.html
Sep 06, 2010 | Acer Computers & Internet
Kernel missing or corrupt
First, try doing Alt-F10 at bootup. It's supposed to load erecovery management. This is where the recovery software is located. If you can execute it, you will be able to restore windows and still create another recovery set.
Now, if you have tried to boot into Safe Mode with Command prompt and this doesn't work, then you will have to contact Acer and order the discs. It'll cost about 50 dollars to order a recovery set from Acer.
Sep 30, 2009 | Acer Aspire 5610-4648 Notebook
Have an acer extensa 4630z wont start up
Bring your Laptop to the nearest Computer Center or any Local Technician to see your laptop. Laptop like this are problem with short circuit or manage power voltage connection.
Also it's having some trouble with motherboard pizza's inside.
Sep 23, 2009 | Acer Extensa 4620 Notebook
Acer extensa 4630z windows complete restore
I wrote to Acer myself about this and this is their reply.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Jul 06, 2009 | Acer Extensa 4620 Notebook
Jun 16, 2009 | Acer Aspire 5920-6727 Notebook
Recovery cd for acer aspire 3000
The "NTLDR is missing" error can sometimes occur when the boot.ini file is corrupt or missing but in your case it sounds like the HardDrive is the problem.
Try the Following:
Start>Run>Type "Cmd" and enter>Type "dir c:" and enter>Type "chkdsk" and enter. Your computer might promote you to chkdsk later Press "Y" and restart you computer
The Acer Aspire series usually have a eRecovery manager than ables you to burn 2 recovery disk which you should have done when you first got the laptop. Since you haven't done that you'll have to buy new recovery CD/DVD
http://www.user-guides.co.uk/asp/product.asp?product=1241&ph=search&keywords=Acer,Aspire,Recovery,CD&recor=1&SearchFor=any&PT_ID=100
OR you can try the following.
Start>All Programs>Accessories>System Tools>System Restore. Choose a restore point that goes back to before your NTLDR problem started.
Please Rate, Thanks.
Jan 08, 2009 | Acer Aspire 3000 Notebook
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
