Why does it keep asking me to update when I have
Why does my iPad keep switching off after a few minutes and then coming on again?
its a conflicted with some software on device, can be a recent update, you will need to reinstall the apple software , you will need itunes installed on a pc or mac and plug you pad into the pc etc with a usb lead and back up to the pc. after you have backed up there is a button on screen main menu to instal updates click on this and it will ask you to download update, it saves the file to the pc. after this is done it will ask you if you want to update device, click yes and let it update. after update it will ask you to put your account info on and let you use the device check before on itunes to maker sure that your find my device is turned off, you can turn it back on after the update. the itunes software will ask if you want to use your backup files click on the one you made and it will put everything back on you had before the update and should run fine after that.
Jan 22, 2017 | Tablets & eReaders
APN updater keeps poping up on my screen
This is an updater for the Ask Toolbar.
You can try to uninstall the Ask toolbar. Try uninstalling it with Revo Uninstaller. Revo first uses the APN's own uninstaller. Then, depending upon what radio button you have ticked, it can also pursue registry settings associated with APN that the primary uninstaller missed. You can manually select or unselect any that you want to remove or keep. The updater is a persistent thing that may reappear afterwards unless you clean out sufficient settings. You see, if the updater changed settings in your browser, simply uninstalled the toolbar is insufficient. So, below are instructions which may pertain to your specific browser.
You can try the manual uninstall directions on this page:
http://www.spywaretechs.com/remove-apn-updater/
Mar 04, 2015 | Computers & Internet
Just updated iPad 4 and now asking for VPN Authentification. I turned VPN off and it still asking for authentification.
I don't know your password but its request you ipad password to update or the program just would like to make sure that correct customer
Feb 26, 2015 | Apple iPad 4th generation
APN Updater has encountered a problem and needs to close. We are sorry for the inconvenience.
APN (Ask Parnter Network) Updater is a software utility that installs with the Ask.com internet browser toolbar and keeps it automatically updated. I suggest you remove the toolbar. Should remove APN Updater by Ask com
Jan 27, 2015 | Computers & Internet
Delete updates from apple ipad
Not sure which updates you mean, if it's the App updates you cannot! The older updates will roll off as you update new apps. It is keeping a record only of your most recently updated apps. If you look closely it is not asking you to update them again.
Mar 05, 2014 | Computers & Internet
Bios update version for hp a1420n
keep the flash drive in hand. try to install xp. while install it was asking for bios update and ask for press f8 for bios update and insert pen drive and select the path it will automatically update the bios and start installing
Apr 03, 2012 | HP Pavilion a1420n PC Desktop
A pop-up window keeps coming <KAV 201- Notification license> asking me to update. when I click on update, My update centre says STOP Update 0% instead of asking me to START Update. It also says the...
You need to wait for an update process. If this is the first time you have updating, its became too long to wait since update database is too big. Also depends on your internet connection speed..
License notification means you need to activate the software, fill it with the activation code you have when you purchased then select activate.
Jul 31, 2011 | Computers & Internet
The sign kept coming up asking me to update to windows live no mention of money so i think i did i now have some new pgs on my computer but it keeps on asking me to sigh up and some things i try to do my...
You need to have a validated copy of Windows, then you REALLY DO WANT to update windows often. The updates typically deal with security based issues. And all of this updating is FREE, except for your time, of course.
Jun 09, 2011 | Computers & Internet
Easy update,cant get updates,unneeded file in way.on dialup.windows xp-sp3.how do i get past file? it keeps asking me to download,then says not needed.this keeps me from getting updates.please help tony..
are you installing with the installation cd of the software or updating with the internet files.if with files retry installing with other files.but if with cd clean the cd and check out.many times there are scratches on the cd that makes the problem.
check out.keep updated.thanks.
Jan 28, 2010 | Avanquest System Suite 9 Professional Full...
Dispite connecting and updating my tom tom 910
It is asking you IF you want to connect it to the computer. There is no problem with that. Every time you connect it to a USB port of a computer you are asked if you want to connect it to the computer. If you want to do so Tap Yes; if you don't, tap No. It will do what YOU ask it to do.
Frequent connections to a computer will ensure that your unit has the latest software updates, map corrections through MapShare.
Dec 30, 2009 | Tomtom Go 910 (Europe, USA and Canada...
Computers & Internet Logo
200 people viewed this question
David Payne
David Payne
