Question about Ricoh Office Equipment & Supplies
Ricoh mP 2018D Giving " adding toner "message always
Adding toner message always comes when new toner bottle added
    New Friend:
  • Ricoh Expert
  • 164 Answers
That what it does to let you know that its adding toner
Posted on Apr 06, 2015
How do i clear the toner amlmost empty message on ricoh mpc2800 , it still appears after i added toner in the bottles.
because the bottle is what the machine is looking for it cant tell that there is new toner in the bottle, it knows its new when the bottle is replaced go to store and buy a new bottle with toner in it.
Jun 12, 2015 | Ricoh Aficio Mpc2800 Digital Color Copy...
HOW DO I RESET WHEN adding a new toner cartridge
There is nothing to reset the toner will load itself unless there is another problem. Make sure the insert plug from the old bottle came out before you placed the new bottle in.
Jun 11, 2015 | Ricoh Aficio Mp161 Copier Photocopier Copy...
I had a jam, upon clearing the jam, the printer will hang with the motor turning, and the display saing 'adding toner'. I changed the (new) toner, for a brand new one. Still message will not go away.
Leave the machine working to see the next message of Adding Toner. Usually the next message of "Adding Toner" is "Ready to Copy".
If the next message is "Add Toner", i suggest you to pull the new toner kit out and push it a little bit harder and check again.
If you power the machine off and on again, can you see what the message about toner is, Original or Unknown Toner is installed?
Sep 30, 2014 | Kyocera Office Equipment & Supplies
Ricoh aficio mp 1600 add toner problem ?
If its not adding toner there could be 4 possible causes, 1.make sure all the covers are closed, if they are not then the machine will not "run" to add toner. 2.Did you check to make sure there is enough toner in the toner bottle. 3. when the machine starts running/adding toner, can you feel a vibration or hear noise like gears grinding/slipping, if so, call a technician to replace drum/dev gears.4. when you open the toner tray/harper/hopper, at the bottom there is a flat silver sliding plate, when you slide it open, is there toner falling oout of that hole, if not, ask a technician to strip and clean the toner tray/ harper/ hopper.
May 01, 2014 | Ricoh Aficio Mp-1600 Copier
What is the meaning og service code coo 70 for minolta ep 1054. thanks
Toner bottle rotation failure. This is usually caused by the toner bottle/cartridge not being installed correctly. Did you just recently install a new one?
Best solution is to try and remove the cartridge. Then leave it out, and close the machine back up and let it run. Only re-install the toner cartridge after the machine has completely stopped.
The machine rotates this cartridge when adding toner. So what happens is the add toner light comes on and if you open the machine to add toner while it is running the bottle stops turning and is thus out of it's home position.
Nov 25, 2009 | Office Equipment & Supplies
Message says to add toner after I replace toner
Plunger from the top of the previous bottle is probably still stuck in the machine. Remove the toner bottle and check/remove .
Jun 29, 2009 | Ricoh Aficio 1013F Copier
Toner light does not go out after adding toner
Are you sure that the "plunger" located in the top of the toner bottle did not remain in the machine from the previous bottle? Sometimes it is not fully released when it is removed, and then it obstructs the flow from the next bottle. Remove the new cartridge, and look into the front of the toner hopper. All you should see are the "claws" that grab the bottle when it is inserted into the machine. If the "plunger" is in there remove it. Please let me know :)
Jun 04, 2009 | Ricoh 3310LE Copier
Add Toner
pull out hopper and remove bung of old tube from inside!.
Feb 08, 2008 | Ricoh Aficio 2022 All-In-One Laser Printer
Toner cartridge
As well as adding toner, there is a chip that must be replaced (with the cartridge bottom up, the chip is towards the right side and held in place with two small screws). The chip can be purchased separately but is included with refilling kits that are overall less expensive than buying the parts individually.
Dec 23, 2007 | Konica Minolta PagePro 1350W Laser Printer
Km-1510 .. AP error code
AP = Adding Powder (toner) it's not an error
it's adding toner from the container into the developer unit while displaying AP. when there is enough toner in the container the AP will disappear and copies can be made when there is not enough toner in the container the toner empty light will come on.
Oct 22, 2007 | Kyocera KM-1510 Copier
94 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
