Question about Clarion VZ401
The e brake thing did not work - Clarion VZ401
    Top Expert:
  • Clarion Master
  • 10,875 Answers
Check inline fuse,how many questions do u need?
Posted on Apr 04, 2015
Ps light came on my 2015 Nissan note n won't go in gear unless I put the key in the locking shifter thing were u put the key thing please help me asap
check to see if the brakes lights are working. some cars have an interlock were the brake light pedal has to be depressed and the brake lights working to unlock the shift interlock.
Jun 30, 2015 | Nissan Cars & Trucks
Back brakes not working , plenty of meat on the shoes, not working with hand or foot brake
Sounds like an ABS problem. (Automatic Brake system) Dealer or very reliable repair shop.
Apr 13, 2015 | Cars & Trucks
No brake lights
There could be 2 switches on the brake pedal. The other thing to check is wiring harness on back of the vehicle.
Feb 17, 2014 | Dodge Stratus Cars & Trucks
Brake lights don't work but taillights do
This can be one of several things. First thing I would check is to make sure you don't have a blown fuse for the brake lights. They may not be on the same fuse as the taillights. If no blow fuse then check the switch that touches the metal bar on your brake pedal. This switch closes when you apply the brake. Use an volt meter to make sure the switch is shorted when you apply the brake. If both of these things are ok then you will probably have to take it to a dealer.
Dec 20, 2012 | 2000 Jeep Grand Cherokee Laredo
1988 nissan navara brake booster not working
it sounds like you have a leak someplace in the system.
Feb 09, 2018 | 1996 GMC Yukon
1995 Honda accord ex gear shift lock, what can I do
The gearshift interlock prevents the shifter from being moved out of the PARK position unless the brakes are applied. The system uses power from the brake lamp switch to determine if the brakes are applied.
The first thing to do is to check your brake lights to see if they are working. If the brake lights are working, then your problem is most likely a defective shift lock solenoid.
If the brake lamps are not working, then you need to diagnose your brake lamp circuit to find out why. A common cause for the brake lamps to not work is a defective brake lamp switch. however, please be aware that there are other things that can cause your brake lamp circuits to not work. In any case, if your brake lamps are not working, getting the brake lamps to work will fix your shifter problem.
Nov 06, 2011 | 1998 Chevrolet Malibu
Brake lights dont work was working jus the other day
Hi: 1st Thing to Check is Your Brake Light Swith ,Which is Down Where the Brake Pedal is But Follow it UP to Find It,It Could be Mounted On your Steering Column ,Or Theres A Bracket(METAL) Hold The Switch. When not Pressing your Brakes The Switch is Being Pushed in By the Brake Pedal Metal Arm and You Should beable to Find It. 1- Thing don't seem like your Brake Light Bulbs would Both Stopping working at the same Time.You Also need to look in your Fuse Box and Se if Theres a Fuse Labeled on Your Fuse Box Cover (STOP LIGHTS Or BRAKE LIGHTS. Hope you Can Find it and Get you Rolling again ,PLEASE Reply And Rate My Help i Gave you by Voting On My Solution: Thanks The WYOCWBOY
May 29, 2010 | 2001 Chevrolet Malibu
'92 Toyota Landcruiser 80 series- brake light came on in the instrument panel and remains on all the time. Brakes working ok. What's the cure?
You say the brakes work fine, so lets start with the e-brake switch,make sure swith is working and ebrake is all the way off, the next thing is the sensor in the mastercylinder, is the brake fluid low or is the sensor working,with this sensor and the ebrake sensor try unplugging and see if light goes out, start with these things first,also there are no brake fluid leaks on the ground,this would cause the poprotioning valve to turn the light on also,but lets start with the other things first. hope this helps.
Apr 06, 2010 | 1992 Toyota Land Cruiser
What do i check for if both brake lights do not work on my 94 camry?
check the bulbs, check the connector ,check ground and voltage power check fuses and check brake light switch right above the brake padal.
Mar 27, 2010 | 2002 GMC Envoy XL
2001 dodge ram 1500 brake lights
I would guess the brake fuse ( this does not use the same fuse as the tail lights/blinkers) or the ground for the brake light bulb.
Aug 13, 2008 | 2001 Dodge Ram 1500 Truck 2WD
Clarion VZ401 Logo
71 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
