Question about Canon Ir 3300 Black & White Copier
Ir3300copier machine when coping top side view is cutting print out
Same thing happen to me, so I used to keep paper little bit down. Till U get printer engineer from Canon to solve your issue, try to follow the above technique.
Posted on Apr 04, 2015
How do i cut floor trim with my stanley mitre box
To do the job right, you make a miter cut, then a coping cut. There is an excellent article on this at:
http://www.wikihow.com/Cut-a-Coped-Joint-in-Wood-Trim
Getting a nice-looking coped joint is very satisfying, but takes a bit of practice. But it's worth it. Miter joints are great for picture frames and trim on furniture, but not for trimming a room.
Oct 15, 2010 | Stanley Garden
We can duplex copy but not duplex print on the KM Bizhub 250. When printing from the computer, in the Konica Document Properties Window on the Layout tab, when the Print Type pull down screen is activated...
Hello
See if you have selected weight paper from the tray in the duplex mode.
Weight paper is selected in duplex mode only from the bypass.
So you check that the paper in the tray 1 or tray 2 must be plain paper and in duplex mode it can print normally.
Jan 29, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Canon powershot sx10 IS. It will not print whats in the LCD view, its cutting the top,bottom and sides off
I suspect the problem is in the settings of your printer. I usually do not print directly from the camera so I don't get the problem. However (I don't know the canon) there might be a menu in your camera where you can set the size of the print out...
Aug 21, 2009 | Cameras
White Out Line
wjite areas are usualy to do with dust on the scanner mirrors or on the lens slips for the laser unit. when you lift the feeder of the copier put a liece of paper on the glass and do a copy if you look at the scanner mirors where the bulb is you might see some dust either white paper dust or dirt this has a blanking effect on the copy quality also if you are connected to print to the machine and the copies are fine then this points to the copy side of things and the dirty mirrors.. they can be cleaned off with a dry cloth.. first turn off the machine then undo the screws holding th covers on the top holding the glass in place.. then gentley move the scanner to the side so you hav eaccess to the mirrors and gently wipe the dust off.. then replace glass and covers and try again. if the lines are still there the problem is with the dev units or toner supply.. also check the amount of toner in all cartridges as this will afffect the colour balance if one is out..if you let me know what machine you have I can probably get more details on proceedure
Aug 13, 2009 | Office Equipment & Supplies
Only half of incoming faxes are printed.
Is this a machine that uses a big, black roll of thermal donor film? The Fax 1250 and several other models have a common problem where the left side prints perfectly, but fades to blank on the right (or the opposite). When you replace that donor film cartridge, you open the top and push a blue lever back on each side to raise the print element assembly.If one of those levers cracks, it will still hold down the head and look normal, but it won't hold it tightly enough the paper to to print on that side.
For models Fax-1150/1250M/1350M/1450MC/1550MC
the parts are
Left (as viewed from the front):UF6085001
Right: UF6087001
One or two screws hold the metal plate on top, then the levers are held on by the springs.
Aug 05, 2009 | Brother Office Equipment & Supplies
Oce 3121 coping machine make random black line shadows
if you are getting copy quality issues on all aspects of the machine, IE, printing, copying, ADF, it looks like then you might need a new drum installed. please contact your local service department for service and make sure if you need supplies, to have those on hand before calling a tech to come service the machine. drums, developers, and toner are considered a supply item and are NOT carried by technicians unless otherwise stated in your local contract.
Jun 23, 2009 | OCE Office Equipment & Supplies
After the riso makes a master it cuts off the top of when printed
Is this machine interfaced with the computer? if it is.. then it's nothing to do with the machine... Either it's the machine settings.. So you have selected letter size on the machine and ledger on the computer.. Something like this. The machine is probably fine..
Apr 03, 2009 | Riso Office Equipment & Supplies
Can't get a neat straight and stretch stitch underneath
Sounds like a bottom tension problem, to be sure I would have to have a look, I would suggest you have it looked at. Not sure about the materials you are sewing and have serious doubts as to whether the machine you are using is up for the job and will give you a satisfactory finish. It is possible a "walking foot" machine is what you need.
Mar 25, 2008 | Bernina Activa 130
Canon Ir 3300 Black & White Copier Logo
35 people viewed this question
old marine
old marine
