Pump keeps turning on about every ten minutes,inlet valve clear,air pressure OK. Model 444
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check pressour switch very thin black pipe may have soap in it
Posted on Apr 13, 2015
  • 209 Answers
SOURCE: Washing machine not filling with water not washing but will empty and will spin
like the anchor idea?, no sorry, this does sound like the water is not getting to the machine, so, when you turn the machine on does it make a slight buzzing noise, if so the fault is no water in the pipes to the machine (from the house), if no buzzing check the solenoids with a multimeter for open circuit (removing the 2 wires first) oh and the plug obviously / replace solenoid if needed, i am sure this will cure your problem, if so rate me please, thank you
Posted on Sep 18, 2007
IB4G2008
  • 3587 Answers
SOURCE: Washing machine drain problem
you know, it sounds not like a mechanical issue. Sounds like your control circuitry is off kilter..
Posted on Mar 09, 2008
  • 225 Answers
SOURCE: washer won't stop filling. don't
"Found that a rat had chewed through a hose" - ah, sorry - that wasn't in my faultfinding chart :-)
Posted on Jul 16, 2008
  • 31 Answers
SOURCE: keeps filling with water when turned on
A lot of wahing machines use a bunch of micro-switches to turn the various solenoids on and off. If your washer has that type of switch, it could be sticking, subsequently sending an "on" signal to the fill solenoid.
Posted on Apr 19, 2009
localwonder
  • 6784 Answers
SOURCE: Cold water good for a few minutes then slows to a trickle. Shut off for a few hours and cold water good again for a few minutes. Inlets are clear. Is this normal behaviour for a dying valve?
Yes, it will fail soon. it is beat to go ahead a order a new inlet valve assembly asap. the pressure sensors that are housed in the valve assembly are failing.
Posted on May 22, 2009
What means code FH in the console A/C Model DSC-F1253L-V Thanks
No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Check/Repair:
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation
If this is intermittent, it would be very hard to determine the cause.
It can be caused by low water pressure into the water from the customers water supply, or clogged inlet water valve screens.
Make sure you don't have any duct tape or something around your drain pipe, it needs that air gap to prevent siphoning. Hope this helps
Dec 15, 2016 | Washing Machines
Tip
I get error IE on my LG dishwasher.
IE is inlet error, displayed when "Not reached to the normal water level in spite of 10 min. water supply"
Possible cause:
  • The Water Supply Tap is closed.
  • The Water Supply is shut off.
  • The Inlet Hose is kinked.
  • The Water Pressure is very low.(below 10 psi)
  • Inlet Valve is OK?
  • The filter of Inlet Valve is clogged by impure water.
  • The Hall sensor is OK?
  • The Impeller of Air Guide is bound.
Remedy:
  • Cut power by tripping circuit breaker or unplugging power cable for ten minutes.
  • Take action on Water Supply device.
  • Measure the electric resistance of Inlet Valve. (950-1300 )
  • Clean the filter of Inlet Valve.
  • Check the frequency of Inlet Water by the Test Mode.
  • Replace the Air Braker.
on Jan 31, 2009 | LG 24 in. LDS 5811 Built-in Dishwasher
Keeps saying F1 when trying to start
If the control has turned the water valves on and after 8 minutes the flow meter has detected water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display. If there is no water in the unit: Make sure that both valves at the water source(s) are turned on all the way. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves Check inlet valve operation If there is water in the unit: Check Drain pump operation Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch Check there is not a siphon problem Check wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU) Check all hoses for possible leaks Check pressure switch operation Check flow meter operation Check CCU operation
cheers
Mar 27, 2011 | Whirlpool Washing Machines
Error code 'FH' flashing - washing machine is fillling up, washing but not draining. We have removed and cleaned pump and checked waste pipe is clear.
FH: If after 30 seconds the control does not detect water entering
machine, the valves will be turned off and the error code will be
displayed. OR If the control has turned the water valves on and after
8 minutes the flow sensor has detected 10.5 gallons of water passing
-Make sure that both valves at the water source(s) are turned
on all the way.
-Check for plugged or kinked inlet hoses or plugged screens in
the inlet valves.
-Verify inlet valve operation.
-Verify drain pump operation.
-Verify that the pressure switch hose is in good condition and
properly connected to tub and pressure switch.
1. Verify there is not a siphon problem.
2. Unplug washer or disconnect power.
3. Verify wire harness connections to inlet valves,
pressure switch, drain pump, flow meter, and
Central Control Unit (CCU).
4. Check all hoses for possible leaks.
5. Plug in washer or reconnect power
6. Verify pressure switch operation.
7. Verify flow meter operation by blowing air through the part and
measuring the resistance.
8. Verify CCU operation by running a Diagnostic test or any cycle.
Dec 28, 2010 | Washing Machines
Washer keeps turning off and displaying f-20...why?
NO WATER DETECTED ENTERING MACHINE OR PRESSURE SWITCH TRIP NOT DETECTED.
The pressure switch is not tripped after 6 minutes.
Follow the links
Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
Verify that the pressure switch hose is in good condition and properly connected to tub and pressure switch.
2. Press PAUSE/CANCEL twice to clear the display. The machine will drain for 3 minutes before unlocking the door.
3. Unplug washer or disconnect power.
4. Verify wire harness connections to inlet valves, pressure switch, drain pump and Central Control Unit (CCU).
5. Check all hoses for possible leaks.
6. Plug in washer or reconnect power
7. Verify pressure switch operation.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
Nov 04, 2010 | Whirlpool Duet GHW9150P Front Load Washer
M washer keeps coming up with the f 20 error code. What does that mean?
F20 = NO WATER DETECTED ENTERING MACHINE OR PRESSURE SWITCH TRIP NOT DETECTED.
valves.
Nov 26, 2009 | Kenmore Elite 45986 Front Load Washer
FH has shown up on my whirlpool duet washer GH9150, water was shut off and now it is stuck in cycle and will not stop
FH = (No water detected entering machine or pressure switch trip not detected)
If after 30 seconds the control does not detect water entering machine, the valves will be turned off and the error code will be displayed.
OR
If the control has turned the water valves on, and after 8 minutes, the flow sensor has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off, and the error code will flash.
Possible Causes / Procedure
• If there is no water in the unit:
- Make sure that both valves at the water source(s) are turned on all the way.
- Check for plugged or kinked inlet hoses or plugged screens in the inlet valves.
- Verify inlet valve operation.
• If there is water in the unit:
- Verify drain pump operation.
- Verify that the pressure switch hose is in good condition and properly connected to tub
3. Verify wire harness connections to inlet valves, pressure switch, drain pump, flow meter,
5. Plug in washer or reconnect power.
7. Verify flow meter operation by blowing air through the part and measuring the resistance.
Replace failed component.(Which will be the pressure switch if all checks out ok, above)
Nov 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
IE problem
Possible cause:
Remedy:
Dec 23, 2008 | LG LDF8812 Stainless Steel Built-in...
LG Dishwasher ie error code problem
Possible cause:
Remedy:
Oct 31, 2008 | LG 24 in. LDS 5811 Built-in Dishwasher
Whirlpool duet washing machine
Or
  • Verify there is not a siphon problem
  • Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
  • Check all hoses for possible leaks
  • Verify pressure switch operation
  • Verify flow meter operation
  • Verify CCU operati
Nov 21, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
