Question about Kenmore Washing Machines
Why is my Kenmore Elite 655 leaking water onto the floor?
  • tom cassidy
    tom cassidy Apr 12, 2015
    Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Kenmore Master
  • 5,323 Answers
More than likely u have a leak in one of ur hoses? or cracked water pmump
Posted on Apr 20, 2015
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite Calypso won't drain
"CA" is an Average Current Limit alarm or error. It's an indication that the you may have a problem with the drive motor, thermal protector, or motor controller. Overloading the washer can cause this problem. Press Pause/Cancel to clear the alarm. If the problem persists, then I would suspect one of the causes that were mentioned. I hope this may help you.
Posted on Jun 27, 2007
Amigaman
  • 248 Answers
SOURCE: kenmore series 70
  The whole cabinet comes off on this washer.  Too remove you need to remove 2 screws in console.  These may be in back on the right and left ends of console or may be in front on each end.  If you can-not find them they might be hidden under plastic end trim.  They are located in front of console on both ends.  To remove pry them up from the inner lower edge and peel towards outside of washer.  Then remove screws and shake console back and forth while pulling up.  Console will hinge back.
   Remove to gold colored clips with screwdriver prying at front.  Make note of the position of these clips.  Unplug lid switch harness and pivot cabinet back and off.  The usual spot for a leak is the pump.  Check for stain coming from area on pump where motor shaft enters.  The pump can be removed by taking off the 2 clips.  Also check small diameter hose that enters side of wash tub in back side.  Make sure this is attached to tub.
Posted on Oct 23, 2007
watugot
  • 290 Answers
The most likely thing to cause the code and the leak is the water pump. If the shaft seal on the pump leaks, the water gets into the drain pump motor and shorts it out. The code is telling you there is a high current/amp draw at one of the motors.
You can see if the pump is leaking by tilting the machine back, removing the screws that hold the bottom to the front edge of the machine and looking at the pump. If the pump is leaking, you will need a new pump and possibly a new motor control board.
Post back if you need further instructions and we will walk through the repair.
Posted on Nov 09, 2007
aborcass
  • 2651 Answers
SOURCE: leaks water onto floor in front of washer after spin cycle, help
open the door though, put your hand around the rubber boot assy, run *** all around looking for small tears, and or holes, if so replace it. only other thing to do is remove the lower access panel and watch it spin a load and youll be able to detect where te waters coming from
Posted on Mar 23, 2008
  • 240 Answers
SOURCE: Whirlpool Cabrio Washer- When draining, water leaks out of hole
probably rubber hose from tub to pump broke, access from back or bottom, (cabrios are open bottom) pump in rear. there is a recent bulletin about tub ring not channeling water from dispenser completely into tub
Posted on Mar 14, 2009
Why does it leak all over floor after last spin cycle?
my washing machine leaks water onto the floor during each spin ...
https://answers.yahoo.com/question/index?qid...
Feb 3, 2010 - During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. ... It happened to us due to over loading. ...something can get betwen the two tubs it this all fails your tub seal is ...
Sep 30, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
We have a Kenmore Elite 795 fridge. It is constantly leaking water from the bottom right corner of the unit onto the floor. There always seems to be a build up of ice at the bottom of the unit.
Usually the result of CONDENSATION due to eithr bad door seals allowing air and moister in to condensate. or a plugged or clogged evaporator drain line which causes water to back up and freeze or leak out the lowest point the bottom?
Mar 19, 2015 | Kenmore Refrigerators
Water leaking from bottom of machine onto floor during fill and wash cycle
there are 3 bolts are bottom front compartment, may be taken off with a phillip screwdriver, or it may be a torx. when you take it off, cut your washer on and see where it is leaking, your gasket could be broken, your hoses or pump.
Sep 07, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore HE3 will not hold water leaks into the pedestal
run you fingers into the door boot and inspect for holes ,, that probably what it is ,,,,,,big tear
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Water leaking into bottom of freezer and on rto floor in front. Kenmore elite bootom freezer 596 series
Drain hose clogged. Removed rear panel and blew out hose. draining fine and no water leaking into bottom of freezer or floor. Be sure to thaw out drain and tray before you return to service.
Sep 14, 2008 | Kenmore Refrigerators
Leaks water onto floor in front of washer after spin cycle, help
Mar 22, 2008 | Kenmore Elite 45986 Front Load Washer
Water comes out the bottom of washer as fast as it goes in the top
hazy, it's possible it's running out your pump. You need to pull the cabinet off to get a real look at where the leak is coming from. Check out the pics...and post back.
Apr 23, 2007 | Kenmore Elite 20972
Washing Machines Logo
Sal DeAngelo
fordexpert
Mike Carew
