Question about Craftsman Garden
How to replace the spool on craftsman 316-39176
    Top Expert:
  • Craftsman Master
  • 10,875 Answers
Posted on Apr 04, 2015
How do you take off the spool head of a craftman weedeater and replace it with a precut line head?
You can remove the spool by pulling firmly on the tapper button to remove it. The spool will then be exposed and can be replaced. reinstall the button by snapping back into place.
Apr 29, 2011 | Craftsman 25cc Gas Line Trimmer
I have a craftsman 32cc weedeater model 316791810. I am not sure how to replace the trim line. Is the line supposed to automatically length itself when the line breaks?
An auto feed line system will do just that and if too much line is released there is usually a cutter inside the edge of the plastic guard covering the string head. I use a Troy Built head on a 32 craftsman and I unscrew the bump knob ...twist and pull out the spring loaded spool....cut a lenth of line 6-8 feet or so....thread the two raw ends thru the two holes in the inner spool....pull them out until they are even with each other....then grasp each one and hold them side by side and wind them onto the spool in a clockwise manner. This is how I do the string head with a split boom that fits the 32cc Sears Power head (an older Troy Bilt).
Aug 23, 2010 | Craftsman 25cc Gas Line Trimmer
I have a craftsman weedwacker model 257 799750 and need to know if I am putting the spool on correctly. Is it the spring then the spool then the cap or the spool then the spring then the cap. when I put...
Spring, spool then cap....if that way doesn't let the line out correctly, then it is possible you have wound the line on the spool in the wrong direction. Try taking the line off and winding it on the other way.
Aug 07, 2010 | Craftsman Garden
I am trying to change the string on a Craftsman Weed Trimmer
Usually you "Push in" as you turn them. Or...there is a knob with a male thread shaft screwed into place holding it all tight. Hold the spool steady as you try to turn the knob off. Or...there is simply a "nut" to take off. But for the most part the newer wacker spools usually just "push in and turn/twist" out. Simple. to reinstall it or replace it with a new one simply push and twist it the opposite removal direction. FYI most lines can be manually "rewound/refilled" by yourself and reused over and over until they really wear out. There are little tricks to doing a rewinding but it isn't anywhere near difficult to do...or learn. Usually the price of a replacement spool is 5 times the cost of rewinding them yourself. Comon its easy! If ya want I'll help ya thru it.
May 10, 2010 | Craftsman Garden
Craftsman parts 172.745440 same as
The part number for this part from the manual is GGT4591U-41. They call it a 'winding spool decorate cover' - and yes, this trimmer is a piece of junk.
Apr 02, 2010 | Craftsman Garden
32cc Craftsman Brushwacker
You have to take the machine apart. The first thing is to separate the shaft from the engine. Then take off the shaft driver. There is a screw in the end. It takes a #15 TORX screwdriver. Once that is off, you have to spin off the clutch. To do that, hold the engine somehow and remove the clutch counter-clockwise. With that off, you can then remove the engine from the molding at the other end. The spool will be sitting on the rewind spring so BE CAREFUL. If the spring comes out it will be a big pain! Just lift the spool off, replace the rope and attach as the old one was. Now, you have the rope connected. Place the spool on the spring. Place the rope in the notch at the edge of the spool and slowly wind the spool on the spring. When you have it wound as far as you want, take the rope from the notch and into the spool. Allow the rope to rewind onto the spool. Put everything back as it was before you started and you have finished...Good luck...Lee
Sep 08, 2009 | Craftsman 25cc Gas Line Trimmer
Have Craftsman gas weedwacker double line ran out.
take off knob that holds on the spool on bottom of weedwacker, remove spool, there are notches around the outside splines on the bottom of the spool. (the bottom is the end that fits up into the spool housing. there are 2 little holes opposite one another on the spool - one on each section. Cut two lengths of line about 6 feet long. stick line into first hole (near bottom of unit) wrap line around spool. once wrapped line gets short - to the point where you cant wrap it anymore - stick the end into one of the notches - do the same with the other line - insert spool back into housing - make sure spring is attached to the spool and lines come out of the holes in the housing - reinsert knob and tighten - make sure as you are doing this you unseat the ends of the lines off of the notches on the spool and they are out through the housing - tighten knob and you should be good to go
Sep 06, 2009 | Craftsman Garden
I need part for a Craftsman Weedwacker
You can either go to sears, or craftsman website or even easier if you can get one off of ebay
Aug 18, 2009 | Garden
Broken starter cord lawn mower #944.368300/craftsman
Please note ! patients is required with this one !
Hi, remove the recoil top cover with the recoil attached. ( DO NOT TAKE OUT THE SPOOL OR YOU COULD HAVE THE SPRING GET YOU IN THE FACE)
Remove old cord.
With your new cord lace it through the recoil spool centre hole with a knott on the end.
now depending if the recoil winds in clockwise when spool is facing you wind the cord around it a few times by turning the spool clockwise,
Then put the cord in the notch at the side of the spool & wind the spool & cord anticlockwise about twice the number of turns of cord (this should tension the spring).
Take your end of the cord & lace it through the hole outside of the casing & fit you pull handle.
But hold the spool firmly untill the cord has a good knott on the end of it.
(Sometimes I see the guys here putting a loop in the cord to stop it sliping in while they tie a knott on the end of the handle.)
Sep 09, 2008 | Garden
Garden Logo
108 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
