Question about Miele Washing Machines
Our W4466 has just come up with error messahe 'close door' half way through cycle. Have cleared drain and emptied machine of water through bottom left hand side but error message still appears.
    Top Expert:
  • Miele Master
  • 10,875 Answers
The door switch is out of alignment or needs to be replaced
Posted on Apr 04, 2015
What does E20 mean
The E20 error code indicates a problem with water drainage. Inspect the drainage hose for kinks that could impede the drainage flow. This frequently occurs when the machine is pushed up against the wall without allowing room for the hoses. If there are no kinks, the hose is probably clogged. Carefully detach the hose from the machine, and use a garden hose to force water through it. If the water doesn't pass through, use a plumber's snake to clear the clog. If there is no clog, inspect the drain pump for clogs. Unplug the machine, and open the small rectangular door towards the bottom of the front of the machine. Drain the pump through the emptying hose into a container until the water flow stops, and rotate the pump impeller to clear any foreign objects. Close the pump and restart the cycle. If the problem persists, contact a service center.
May 18, 2012 | Zanussi ZWF1430W Front Load Washer
Stops in cycle, not sure if its when rinsing? I notice it stops and an error code of OE ?
This error code OE means the tub is not fully drained 10 minutes after the drain pump is turned on.This is possibly due to a clogged/kinked drain hose or the drain filter is blocked. Make sure the drain hose is clear then open the filter door located at the bottom left front of the machine. Drain the remaining water from the tub through the emergency drain hose located in the filter door area. Once completely drained, turn the knob counterclockwise then pull out and clean the filter. Reach in the pump impeller area and turn it with your finger. Replace the drain pump if the filter is clear and the impeller is broken or restricted and cannot be freed.
Jun 18, 2011 | LG WM0642H Front Load
Washing machine Airturbo stops at 17 minutes and 7 minutes and error code SE appears. what is to be done washing nachine is one year old only
  1. Open the filter-cover near the bottom of the machine. Unscrew emergency drain cap by turning it to the left and drain off all the water. Unscrew the filter cap and take it out. Wash any dirt or other material from the filter. Make sure the drain pump propeller behind the filter is not blocked. Replace the filter cap. Replace the filter-cover.
  2. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
  3. If the water only trickles out of the draining hose, pause the washer and blow air down the hose, you should hear the water inside the unit bubble a few times. If you don't hear bubbles, the hose is still blocked.
  4. Drain the load, empty the washer of clothes and try running a rinse & spin cycle. You should repeat this until the water runs clear from the drain hose.
  5. If the machine still fails to drain, you may need to replace your Drain pump.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Feb 26, 2011 | Samsung Washing Machines
Laundry tub has a bad smell/stinch like mildew. Has gotten into towels and other laundry. How do you get into the machine to see if there is lint buildup or what is causing this? Have used numerous odor...
Water left in bottom of washing machine should not be more than a tablespoon or so. Have you tried washing a full cycle with EMPTY washer, 1 gallon of clear distilled vinegar and 1 pound box of baking soda...the plain one on the grocery shelf. You got some drain tube that seems to be harboring this smell, which feeds back to your clean clothes. Empty the washer immediately upon washing being done. Always leave your lids or doors open. You may have to change out the tubing/drains from INFLOW and OUTFLOW. This is all under the assumption you have a front loader. I don't believe this would exist with regular top loader as gravity pulls all to the drains.
Oct 17, 2017 | Kenmore Washing Machines
Door locked and will not open. i ran an empty cycle to see if that would work and it doesn't.....thanks! Margit
IF water is left in machine then door wont unlock, check pump, run drain cycle. If pump runs but doesnt remove water, then check filter at bottom (small door on bottom front) water will come out when this is done. If washer is completely empty of water and door locked then you may access lock release tab from bottom or reaching down from top to lock asm. Then check lock
Jul 19, 2009 | LG WM1814CW Front Load Washer
My GE Front load washer (WBVH6240) has an odor that smells like mildew in it. If the is left closed the odor is really bad. Do you know how to fix this or what is comes from?
run a empty cycle with bleach on whites/ sanitize. clean boot (rubber gasket at door) with bleach or other cleaner inside especially at bottom, make sure 3 holes at bottom are clear.
this may take multiple cycles to rid of odor.
For maintenance, you should wipe excess water from boot after last load, and check lower drain holes. Once a month wipe boot with windex or other. and run cleaner cycle (empty) newer machines have a special clean washer cycle. (6240 doesnt).
Also clean your drain pump filter at bottom front behind access panel.
If boot is really bad , replace.
Jul 16, 2009 | GE WSXH208A Front Load Washer
Washer won't spin and drain
Sounds like your drain poump is failing. It's spinning lighter loads but not able to take a full load. I woule definately replace the drain pump,
Feb 28, 2009 | Frigidaire Washing Machines
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Miele
Clean the drain by opening the door on the bottum left.
Use the yellow plastic thingy in the front of the soap drawer to do it.
You can open the machine door by pulling the yellow tag in the bottom door.
Drain the water through the filter, clean the filter and close.
Then unplug the machine and tilt it forward by about 1 foot until you see water coming out of the bottom (put towel on floor).
Plug back in and voila!
I do think that this machine is a major pain. No spin cycle and this kind of stuff to go through. Anyone want to buy mine?
Dec 24, 2007 | Miele Touchtronic W1213 Front Load Washer
Washing Machines Logo
44 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
