Question about Mackie Audio Players & Recorders
Have a Mackie 1801 have no sound could this be a fuse
4 Suggested Answers
  • 5603 Answers
SOURCE: mackie swa 1801 power amp
You likely have other parts blown as well, but Q3 (MJE15033) AND/OR r8 (1 OHM/0.5 Watt) are blown. I suspect that Q3 has a base-collector short and you will find several of the output transistors are fried as well Q4, Q5, Q15, Q16. I suspect that the Zeners D14, D25 may be blown.
When restarting this, put a 100 Watt lampin series with teh 120 volt power to limit current and avoid destroying freshly repaired parts due to a few bad ones not found.
Posted on Aug 11, 2010
soberanis54
SOURCE: swa 1801 mackie blown capacitor
mackie 1801 f 1 blow and tip 122 bad
Posted on Mar 05, 2012
idrvnsx2
  • 60 Answers
SOURCE: no sound
Hi my name is MIchael and I repair the following amps JBL PB10, PB12, TSS-1100, TSS-1200,PS12, PS12, E250P, SUB12 Venue. If it has the screw near the on/off switch. If your amp is blowing the fuse, has bad sound, no sound, doesn't power up or if the output is low or muffled. We can fix it - please check ebay and search WE REPAIR PB10 PB12 - you will find us ... Edwards Electronics ....
Posted on May 24, 2012
The OL and THERMAL LEDs turn on quickly after an even very low level signal input.
These subs are renowned for problems. The PSU and the output stages as well as the main driver are all weak and there are a number of companies that will upgrade them and sort out other issues such as vibrations. Assuming it is out of warranty and you really want to use this you would be best going to a specialist repairer to get it sorted not Mackie.
Jun 21, 2015 | Mackie SRM 1801
Hi sorry it was mackie srm 1801 works fine on A out put can I use for time all is working well
Yes, you can use the A output, as long as you're OK with it being a mono system. It may be helpful to read the manual which has a lot of info including possible setup configurations. Here's a link-
http://www.mackie.com/products/srm1801/pdf/SRM1801_OM.pdf
Mar 28, 2015 | Mackie SRM 1801
Hi, I have a mackie srm1801 and in the middle of a gig the OL LED came on and wouldn't go off. Input was unplugged and still the light wouldn't go off. After a while the fuse went and now there is no
It is likely that the O/P transistors have blown, especially if the fuse keeps blowing and the O/L led comes on. It's a repair shop jobbie
Nov 30, 2011 | Mackie SRM 1801
Model swa 1801 Fuse 240V 4A burned out ! I replaced it but still get no power (any led stay off) What can it be ?
check for integrity of the main amp and the torroidal transformer.
here is a guide , how to check for transistor
if there is a continuity on the primary terminal of the transformer.
Have a tech to guide you , should you need to DIY.
Sep 17, 2011 | Mackie SWA1801 Subwoofer
The peek light is stuck on and im not getting any sound 1801 hd sub
The amp is likely blown. This is not DIY unless you are competent at electronics.
Feb 19, 2011 | Mackie HD1801 Powered Subwoofer (1600...
Where is the fuse on the mackie 1801.....there is no fuse tray at the power cord plug....
There are more than one fuse and they are internal. Replacing the fuse without fixing the cause MAY result in causing more damage to components. The fuse is inside to force one to open the box to repair.
Here is schematic:
http://elektrotanya.com/mackie_swa1801_sch.rar/download.html
Jan 22, 2011 | Mackie HD1801 Powered Subwoofer (1600...
Dont know how to hook up srm1801
Go from the main outs on your mixer to the input on the 1801. With an XLR, connect the 'high pass' output on the 1801 to the input on the 450 on top of it.
Jan 09, 2011 | Mackie SRM-450 System
Swa 1801 mackie blown capacitor
Took alot of finding but you can get them from Digi-key
Sep 16, 2008 | Mackie SWA1801 Subwoofer
No sound
Willing to bet you've blown the amp, or fused the coil. I've had it happen twice, apparently when running off a power source that apparently couldn't handle the load. Hope it's under warranty - if so Loud Technologies (deals with all Mackies warranty stuff) should be able to replace the unit. Otherwise, you'll need to take it in to a service department and have it checked out.
Good luck, you'll have to arm wrestle with them to get them to replace it.
Jun 12, 2008 | Mackie SWA1801 Subwoofer
52 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
