Question about Canon Office Equipment & Supplies
I have canon np6050 machine it displayed e002 switch the power off and on again.what i do?plz help me....
    Champion:
  • Canon Expert
  • 234 Answers
Problem with heater.Lamp,thermal switch,thermistors,connections...
Posted on Apr 05, 2015
  • 62 Answers
SOURCE: Canon NP-6035 persistent E002
There is a heating problem connected to the fuser. It could be the heater lamp or thermal switches. Lamp is most likely.
Posted on Aug 27, 2007
SOURCE: Canon NP6050 Error code E013
E013 refers to the waste toner receptical being full, but in this case the toner melts at the end of the worm screw assembly causing the cleaning unit to block up, activating the microswitch which tells the machine the waste toner bottle is full. The solution is to try to free up the worm screw assembly, failing that, replacement of the drum cleaning assembly.
Posted on Apr 15, 2008
  • 47 Answers
SOURCE: error code e002 on canon copier np6050
Also this code needs to be cleared in service mode. Despite what the display says, turning it off and on will not reset it. To enter service mode insert a straightened paper clip into the small hole in the front cover, near the meters, a "$" sign will appear on the display. Press * 4 * in order. Press ">>" to select "error" then press "OK" then power cycle.
(I cant remember on that model but you may need to defeat the interlock on the front door in order to enter service mode.)
Posted on Jun 10, 2008
  • 6 Answers
SOURCE: i bought a secondhand drum taken from a Canon
yes you use it. But when you start the machine leave it for 10 min
Posted on Oct 10, 2009
  • 5 Answers
SOURCE: my canon np6050... displays i55 problem,unlike the
check fuser unit and tharmister
Posted on Jun 30, 2010
My machine is canon NP3050 type F127500 and the problem is that, when you start up the machine, the screan show error code E002 please what can i do?
E002 is a clasic Fuser error
"E002Fuser temperature too low"
Turn OFF and ON the machine, if that dosent help you need to replace the Fuser Unit.
May 25, 2012 | Canon Office Equipment & Supplies
I have canon ir400 machine... it displayed error codes e002.. what i do? plz help me....
If the fuser assy has been repaired and you keep experiancing an E002 the problem is most likely a faulty DC Controller (main board) The DC Controller handles the voltage applied to the fuser assy and gives the error code E002 or E003. Have your tech clean & reseat connectors on the DC Controller before just replacing it. I have found cleaning the connectors & reseating them solves the problem 75% of the time.
Jan 12, 2011 | Canon imageRUNNER 400S Copier
Error code e002 on canon copier np6050
Jun 02, 2008 | Canon NP 6551 Black and White Copier
Error code: E002 at canon NP6551
canon gp 405 copier their was problem E001 & E002 ?
I cannot find the problem
e002 error normally indicates that the heater {fuser} is off
to clear that in most canon models there is a small press switch is to be activated to reset the error
at the rear right side of machine there is a small cover take it out and look for that small black button, press it while or immediately after switching the machine ON , switch OFF and ON again
if the error still exist may a real damage in fuser e.g. blown thermo fuse or lamp
Jan 25, 2008 | Office Equipment & Supplies
E0004 on Canon NP6050
it is a SSR,heater 1 or 2 ,or thermal switch error.   Try to reset,        follow this procedure. SERVICE MODE E004 SSR O FUSER WON´T SHUT OFF
To reset this code use simulation 401
SERVICE MODE: Open front door and cheat door switch.Using an allan key of 2mm, insert it through the hole in the inner front panel and actuate service switch 850. Display will show "1". Press the mode 4 you want to use. then press "ok" . It will read 401 press "ok" use number key a change the value if "1" change to "0" press "ok" . press "clear" takes you out of particular mode turn off the machine. good luck     CE MODE: Open front door and cheat door switch.Using an allan key of 2mm, insert it through the hole in the inner front panel and actuate service switch 850. Display will show "1". Press the mode 4 you want to use. then press "ok" . It will read 401 press "ok" use number key a change the value if "1" change to "0" press "ok" . press "clear" takes you out of particular mode turn off the machine. good luck
Oct 24, 2007 | Canon NP 6050 Copier
Aug 27, 2007 | Canon NP 6035 Copier
old marine
old marine
