Question about GE 29893GE1 Corded Phone
How to resolve flash error
Unplugged the phone for 10 seconds but couldn't resolve
How to stop lights flashing on the control panel
Unplug the oven from the outlet or turn off the circuit breaker that controls power to the oven.
Wait about 5 or 10 minutes- so that any remaining stored capacitor voltage has been fully drained.
Restore power to the oven- if you get an alpha-numeric error/fault code or the lights on the oven's control panel blink, refer to your owner's manual for troubleshooting and/or interpreting the fault codes or flashing lights; or you can try contacting your local appliance repair shop for assistance in interpreting the fault errors or to schedule a repair service call.
Sometimes you can Google the error codes for info, help, and repair solutions...
You can also try the oven manufacturer's website to resolve your problem- they may have a troubleshooting/solutions link or phone number to get live tech support...hope this helps.
Mar 08, 2015 | Ovens
My htc touch couldn't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Oct 14, 2012 | Computers & Internet
My whirpool locked light keeps flashing and wont wash
Hi
The light is flashing due to the door lock error. The door lock is activated as the machine experienced an error or was stopped in middle of a cycle. Or the door was being pulled while the machine was running a cycle. Try unplugging your washer and restart the washer to check if you are still getting the same blinking light. If error is still not resolved then start the rinse/spin cycle & stop the cycle, now press and hold the cancel button for 5-10 seconds. However, if you are still not able to get the door open then you'll need to open the door manually by disassembling the washer.
Hope this helps... Please post back for any further assistance.
Daniel
Apr 18, 2011 | Washing Machines
The button to open/close my Philips DVD player Model DVP5140/37 is not functioning, and the remote does not have an open/close button. How do I fix this??
Here are some troubleshooting steps to get you started to resolve the issue.
First, Try to unplug the unit for 10 seconds from the power source. Wait 10 seconds after unplugging and reconnect. Try to open/close and see if the tray opens. This may resolve the issue as this is what Philips Technical Support says to do in this situation on their website.
Also, you should be able to eject with the remote. To eject or open the disc tray with the remote, you need to hold the STOP button on the remote for 5 seconds.
Hope this helps! If not, I was told to give a direct phone call to Philips Customer Care Center from 12pm-8pm EST Monday-Saturday. Their phone number is 1-866-323-9916. Have the device/unit ready when you call with the Serial Number handy.
Warm regards,
Craig
Mar 20, 2011 | Philips DVP5140/37 DVD Player
GE refrigerator pfss6pkwbss flashing 88 82 after a brief power outage...any info on how to resolve?
Simply press the top left (Engery Saver) and top right (Alarm) buttons at the same time for about 10 seconds--it will beep and reset the panel! I was told by both GE and a local repair service that I had to replace the entire control panel...what a RACKET!! GE needs to start telling people this trick when they call in with this error...it will come up every time there is a power outage.
Nov 23, 2010 | Refrigerators
It's STUCK
Hi
The light is flashing due to the door lock error. The door lock is activated as the machine experienced an error or was stopped in middle of a cycle. Or the door was being pulled while the machine was running a cycle. Try unplugging your washer and restart the washer to check if you are still getting the same blinking light. If error is still not resolved then start the rinse/spin cycle & stop the cycle, now press and hold the cancel button for 5-10 seconds. However, if you are still not able to get the door open then you'll need to open the door manually by disassembling the washer. Please post back for any further assistance.
Daniel
Jul 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • Feb 01, 2010 | Canon BJC 4400 InkJet Printer
    Flashing error code e f on kenmore elite refrigerator model 253.4450360
    Hi
    The first thing you need to do is to unplug the a/c cord from the mains and plug that back in after 10-15 minutes. This is an error within the main mother board (control board). If it still is not resolved then you’ll have to keep it unplugged for 5-24hrs so that the controls get reset.
    Please do accept the solution if the issue is resolved or else revert for further assistance.
    Thanks
    Rylee
    Sep 07, 2009 | Refrigerators
    Model KV-27S40; no picture/no sound
    Most likely IC 541 is faulty on the A board. The IC number is TDA8172
    May 29, 2008 | Televison & Video
    No Link to Base
    to re-register the phone, hold down the "handset locator" button on the base untill he "charge" light flashes. then, on the phone, hold down the flash/call waiting button until the LCD screen says "handset registering." if after it registers it says "error!!!" then retry. that is what it says in the instructional booklet, but i have not done this successfully. mine keeps saying error.
    Oct 22, 2007 | Panasonic KX-TG2313 Cordless Phone
    GE 29893GE1 Corded Phone Logo
    50 people viewed this question
    Top GE Lands Phones Experts
    Computer Repairing
    Computer Repairing
    Dudeman321
    Are you a GE Lands Phone Expert? Answer questions, earn points and help others
