Question about JVC Car Audio & Video
Jvc kd-r320 car cd player reading "warning chk wiring and reset unit" I have checked all wiring and push reset button but still getting same message.
Noggin
  • 944 Answers
SOURCE: Setting Clock for JVC-KD-G420
Here is the link for the manual http://books.jvcservice.com/download/289413083/38360.pdf page 7 Hope this helps :)
Posted on Mar 17, 2007
JMuskovitz
  • 135 Answers
SOURCE: JVC KD-S640 pinout needed
For ten bucks, you can buy a new connector: http://www.jvcservice.com/store/ProductDetail.asp?part=JV16-0001A To figure out how to wire it: http://books.jvcservice.com/download/256614688/28879.pdf Page 25 describes the color of the wiring in the harness.
Posted on Mar 29, 2007
SOURCE: i c an't set the time in my jvc kd-g120 audio cd player
Push the Sel button and hold for 3 seconds (usually displays Demo or Demo Off). Push the Station up and down button til it reads Clock H or Clock M. Turn the volume button to adjust time. Push the Sel button to quit.
Posted on Dec 07, 2007
  • 323 Answers
SOURCE: jvc kd-g200 cd player
http://www.retrevo.com/search/v2/jsp/downloadPage.jsp?doc=260a73e6d269444e666771376ad18c85&q=JVC+KD-G200
Type in the code shown at the bottom.
Click "download now"
Click where it says "link" in blue.
Click "save"
Save the pdf to your computer's hard drive.
Instructions are as follows:
Press and hold the "select" button for more than 2 seconds.
Press the "fast forward" icon button.
Turn the dial to appropriate hour.
Turn the dial to appropriate minutes.
Press the select button.
Posted on Apr 20, 2008
SOURCE: I HAVE A JVC KD-G321 CAR RADIO/CD PLAYER
I had the same problem, the cd refused and radio plays good, with JVC KD G321. I have disconnected the switches behind the radio and also disconnected the antenne (do not forget the antenne) and it played the cd again.
Jan (my english is not so good, i hope my solution is better.
Posted on Sep 18, 2009
I have a jvc kd-r45 it keeps on saying warning unit check wiring then reset
The check wiring message suggests a short probably in a speaker wire. Check that the terminal leads for the speakers are properly covered in insulating tape. Check the rest of your wiring, if you can, to check for any section where the insulation is worn and could come into contact with anything. Next remove the faceplate and use a pen to press and hold the reset button. The button is near the bottom of the middle of the receiver.
If the error persists, then another section of the wiring is making metal on metal contact with the car or another wire. You should contact a JVC dealer or the company that provided the kit with the KD-R45.
I hope this helps.
Jan 27, 2015 | JVC Car Audio & Video
Installing JVC KD-R740BT in 1997 Ford truck, keep getting "miswiring, check wires and reset" message
Check speaker wires. All four speakers must be independent. Means no shorting to chassis.
Sep 25, 2013 | JVC KD-HDR1 CD Player
How do i reset jvc cd receiver it shows warning chk wiring then reset
May be a wrong model. JVC started this feature in 2009. Your model is older than that.
Aug 25, 2013 | JVC KD-PDR31 CD-Receiver -I-Pod...
My JVC KD-R426 keeps on saying warning check wiring and reset system. I've tried everthing but it still does the same. What must I do
Not sure if this will help any other owners since my answer is 4 years late, but this is what I found from another user. Apparently if you mess with the wiring too often, it goes in a safe mode which you need to do some button trickery to unlock the device from it's safe mode. These are the Steps.
1.Disconnect power supply
2.Press [MENU] and [UP arrow] buttons and keep holding.
3. While holding the buttons [MENU] / [UP arrow], connect the power plug again
A. The display will show "DC ERR"
*** if it still shows "Chk wiring ..." repeat the steps above until you get "DC ERR."
4. Press [UP arrow]; the display shows "DC1 ERR"
a. Press and hold [UP arrow] and it will show "DC1 OK"
5. Press [Down arrow], the screen will show "DC2"
a. Press and hold [DOWN arrow] and the display will show "DC2 0"
6. Disconnect the power from the back of the unit.
7. Remove the Face Unit.
8. Reconnect the power from the back.
9. Use a sharp object and press the [RESET] hole for 3 seconds and release.
10. Reinstall the face unit and turn on the power.
Oct 04, 2012 | JVC Car Audio & Video
I tried to wire a jvc kd-r320 in a 1996 jeep grand cherokee, hook it up and i got no lights or sound, when i turned on the jeep lights a loud buzzing sound came over the speakers?
You have the live connected to a speaker, recheck the wiring diagram. Red is the acc power, Black Neutral usually and yellow is direct power from battery. Wire just these and check if you have power and then do the speakers after you have that much working.
Apr 29, 2011 | JVC KD-G710 CD Player
I had cd reciever jvc kd-lh810 my probem is on the screen is EJECT ERROR what i can do?
there is a repair mod for this unit, replacement of motor. try hitting the top of the unit hard. while you push the eject button. this is sometime just enough to get the motor moving again
Dec 12, 2010 | JVC KD-LH810 CD Player
JVC Frontloader MP3 player KD-G415 time set
turn the unit off, while on standby push and hold the select button
May 03, 2010 | JVC KD-G420 CD Player
I c an't set the time in my jvc kd-g120 audio cd player
Apr 30, 2007 | JVC KD-G120 CD Player
Error 10 message on display screen
Same issue but pressing Power and SEL would not reset unit. Found solution. Once again disconnected the car battery. Removed the face unit from the radio base and then reconnected the battery. Replacing the face unit AFTER the power was re-established solved the issue. (Probably pulling the radio fuse rather than toying with the battery connection would have done the same thing.)
Mar 09, 2007 | JVC KD-S640 CD Player
Car Audio & Video Logo
77 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
