Question about southland Garden Cultivator Tiller S-cv-43 -
After market carb kit
Discontinued from manufacture A200774 or c13 i believe
  • Eugene Rounds Apr 04, 2015
    Hi J.r. Prak, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Can post find any marking on the carburetor itself? It appears to similar to Walbro Rotary but there are several manufactures of these type carburetors.
Diagram a200774 carburetor
Laurence, the # you posted shows nothing.
RE POST year make model and your complete question.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Feb 24, 2016 | Cars & Trucks
I have a weedeater featherlight which is discontinued, but anyway where is the setscrews on the carb i need to tune it!
they are covered,if you need to tune it then you need to clean and rebuild the carb and replace gas lines,buy it all on ebay for less than 20 bucks,ethanol kills plastic,buy the whole carb,you cant adjust yours
Jul 26, 2015 | Garden
Troy-Bilt Tb575 Ec
  1. Replace carb or,
  2. Overhaul carb or,
  3. Try one of the new "on-engine" carb cleaner-solvent kits which are available at most auto parts stores.
I've never tried one of these kits so I don't know if they actually work, or are just another marketing "pretty face!"
Jun 30, 2014 | Troy-Bilt Tb575 Ec 17-inch 29cc 4-cycle...
Amana stove flashs F3 on control panel. I checked the sensor probe in the oven....It read 1050 Ohms at room temperature. I believe the problem is in the control panel. The Manufacture stop making this
They may still have those parts in the warehouse even though that model has been discontinued. That is if it isn't too old. Try RepairClinic.com. I have used them before on some older Appliances.
Nov 26, 2011 | Kitchen Ranges
Is the wii going to be discontinued?
Hello There :)
There is no official remark about the Wii being discontinued. I believe that that lack of availability is simply a marketing ploy. The Wii has been one of the most successful gaming consoles ever. I dont think that it will be discontinued in the near future. There are probably locations FULL of Wiis that just havent been shipped out yet.
Hope this helps! Thumbs up always welcome.
May 03, 2011 | Nintendo Wii Console
My 1982 jeep scrambler is barely running. I just replaced the after market fuel injection system with a 2BB carb and put in the correct mechanical fuel pump. Right after I installed the carb, it ran...
Check out your EXHAUST system...
Sounds like you have seriously checked
all around fire & fuel...
Runs.. then doesn't ...
actually sounds like a rusty MUFFLER baffle
(internal blockage)...
I have ALSO
had a collapsed CATALYTIC CONVERTER.
Get your prices... (below)
1982 JEEP SCRAMBLER 4 2L 258cid L6 Catalytic Converter RockAuto
1982 JEEP SCRAMBLER 4 2L 258cid L6 Muffler RockAuto
More Information for EASTERN EXHAUST EE700068
Carnac the Magnificent
Jun 11, 2017 | AMC Scrambler Cars & Trucks
What size jet would i need if ive got a 70cc big bore kit on a standard carb ??
I believe the standard starting place is to go 2 jet sizes bigger, but I would check with the manufacturer of the big bore kit to make sure. Hope this helps
Oct 26, 2009 | 2000 Yamaha XV 125 - S
Thottle will no stay in one position. There is a black spacer that slides over the throttle shaft between the shaft an the leaver. Will a new leaver come with that black spacer. Blower model wt200
Three (3) possible carbs were available on your machine.
If you have:
Walbro model WT-606 carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071726 and choke lever kit part #530071725.
If you have:
ZAMA model C1Q-W11 carb, the choke AND throttle levers are BOTH a part of the carb itself. (Would need a whole carb to get your part.) Complete carb part #530071465.
If you have:
ZAMA model C1Q-W11C carb, the choke and throttle levers are available in kit form (which leads me to believe the spacer comes with them). Throttle lever kit part #530071715 and choke lever kit part #530071716.
Hope this helps.
Oct 04, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
My lock off lever is broke too.
Look on ToolPartsDirect for a breakdown. Some Ryobi stuff is discontinued. I recommend DeWalt or Makita if your in the market for a new one. Lemme know. lease rate me
Jun 11, 2009 | Ryobi 12A 7-1/4 in. Circular Saw
southland Garden Cultivator Tiller S-cv-43 - Logo
147 people viewed this question
Top southland Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a southland Garden Expert? Answer questions, earn points and help others
