Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
My Rancher doesn't maintain high rpm. What's wrong?
I checked the spark arrester and it is clean as a whistle.
    Problem Solver:
  • 17 Answers
Most 2-cycle chain saws have 3 carburetor adjustments; idle speed, low RPM fuel/air mix and high RPM fuel/air mix. The fuel/air mix needle valves will probably require a "special" driver tool to adjust them. Be careful with the adjustments, you can really mess things up by incorrectly adjusting them, then your saw goes from running poorly to not at all.
Posted on Apr 04, 2015
  • 37 Answers
Check and clean your air filter. Also make sure that the choke is not sticking...
Saw will not rev up to full rpm when you pull trigger it revs up to 1/2 to 3/4 throttle and starts cutting out.
Engine may be too worn or may have run out of oil at some point, compromising the bearings.
May 13, 2015 | Garden
Engine lopes after it gets hot won't maintain full RPM
still something in that carb that needs to be cleaned out
Feb 08, 2014 | Troy-Bilt 179cc 24" Snow Thrower Storm...
It wont run its like it doesn't have enuff spark
I had a simular problem with my stihl chainsaw, I found the spark arrester screen in the muffler was plugged I cleaned it and haven't had any more problems.
Jul 16, 2012 | Garden
Eng runs with choke 3/4 on. wont reach max rpm
Double-check your mix; it's easy to have too much oil in it which will foul the spark plug and gum up the carb. Also clean / replace the spark plug. It may have a clogged spark arrest screen... remove the exhaust cover & look for a metal mesh screen.
Feb 22, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
No rpm
There are a few things to look at. Try checking carb adjustments. High speed may need to be backed out a little (1quarter). There is also a spark arrester, this is the screen at muffler exit. This can be removed usually held in place by 1 or 2 screws. Remove it and using a small torch burn it clean and reinstall. Hope this gets ya going hfisser.
Dec 20, 2010 | ECHO, Inc. PB-251C Handheld Blower
The idling fluctuates to high rpm and to low rpm without touching the accelerator
vacume leaks will cause that listen around for any hissing or whistling and fix any if found.
Dec 07, 2010 | 1994 Honda Civic
Blower will not achieve maximum rpms and bogs down when accelerated
most new homelites etc have the high speed screw too lean because of epa standards---you usually need a special tool either a splined or pac man screwdriver to open the adjustment screw another 1/4 to 1/2 turn to get the right rpm's
Nov 07, 2009 | Homelite Consumer Products Backpack...
My 455 rancher won't maintain power. I have
if its over a year old and you used other than 93 octane, you need to rebuild the c arb, i did an runs like new
Jul 31, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
162 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
