My Motherboard will not load Windows XP.
My Motherboard has been working but has stopped loading my Windows XP Operating System. The Bios recognises both Maxtor 120 Gb PATA Drives but will not continue to load the O/S. The Message comes up 'No Hard Drives Installed'.
  • 79 Answers
What is the make and model of motherboard?
Have you recently re-installed XP are did it just fail one day?
Posted on Apr 06, 2015
    Master:
  • 742 Answers
Sounds as if you're ide or sata controller has failed I your motherboard. Might also check your bios settings and make sure the drive ports are enabled. If your cmos battery is dead and the system lost power then it could have changed the settings back to factory defaults.
Posted on Apr 04, 2015
  • 70 Answers
No want to to go for any factory defaults.in bios setting go to boot menu and change ACHI/IDE setting to IDE.this setting will sure solve your problem.sorry for bad english
Posted on Apr 05, 2015
How To Enter Bios Setup in windows xp which keys
Bios set up is done by stopping windows loading when you first power up and thus getting on the motherboard screen. It's often the F10 key to get on that screen, but it can vary. Once on the motherboard, you should see the options for Bios set up. Check your motherboard manual for more information.
Jun 16, 2013 | Microsoft Windows XP Professional
My board problem is cannot windows xp instal
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow key scroll down to advanced bios features press enter change your first boot device to cd,press escape then press f10 to save to cmos to restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
(note after you have loaded the operating system you should go back and change the first boot device to your failsafe or optimized defaults)
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope this helps
Apr 22, 2012 | ASUS P4V8X-MX Motherboard
Windows xp start up disk doesn't work
if you are referring to the installaion disk
restart your computer during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the using arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
hope this helps you
Apr 16, 2012 | Computers & Internet
Will windows xp supported in amd sempron 145?
No it should not.
However your post does have one confusing detail - XP when installed does not reside on the motherboard but on a Hard Disk Drive. Parts of it will be loaded into memory when you boot up the PC.
If you mean that you are also installing a new Gigabyte MB under an existing installation of XP, you will probably still need the XP system disk for a reinstall of XP as it may not recognise the new MB.
If you are newly installing XP in an existing PC with the specs you mention, it should be ideal. It is best to have enough memory on board, at least 1 Gb.
Nov 20, 2011 | AMD Sempron 145, 2.8 GHz
Windows stop and nothing happin
hi If able to load win XP or any operating system that mean your system is booting and is in good condition. if there is issue with load of OS in normal mode then you try using last used configuration. follow this steps
1) keep press F8 when bios screen goes off until you see win xp option
2) then choose "last used configuration".
it will try to boot the system even though the system does boot properly then repair the os by booting xp dvd or cd from cd & dvd drive.
i hope this will resolve the issue.
Jun 25, 2010 | Mercury P4VM800M7 Motherboard
Error loading operating system
you'll need to run windows setup again.
Insert the cd restart and when asked to start with cd click enter.
Jan 14, 2009 | Gigabyte GA-EP45-DS3L M-b- P45+ICH10, DDR2...
Dell Precision WorkStation 650 crashed and restore CD won't load
If possible try changing your cd rom or dvd rom for cd use check it is recognised in bios and change bios to boot from it,if you still get the black screen with flashing cursor ,could be os is missing due to hdd failure
Jan 09, 2009 | Asrock AM2NF3-VSTA (4711140874470)...
Motherboard upgrade??
Dear kaname,
Your computer can support Windows XP, which has better hardware support and compatibility with the 2003 Office suit. XP also updates your hardware automatically once you are on the internet. You might want to try this.
Keep in mind that the older the Operating System, the harder it is for Office suites to compat. Newer Operating systems have better support for your computing. If you don't have HDD problems, the BIOS should not prevent you from loading SP2 for Win2000.
Conclusion:
1. The SP2 Source Disk may have a problem
2. The Win 2000 you have already loaded may be missing components, preventing the SP2 to load.
2. Notton Antivirus versions and the 2003 office both reject Win 2000. They just don't like it; it's getting too old.
Get with it, Kaname!!!!
Feb 27, 2008 | A-Trend ATC 5220 (ATC-5220) Motherboard
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
