Monitor heater 2400 turned off with code E13, what does that mean?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 83 Answers
This is an over heated indicator, what make and model unit.
Posted on Apr 07, 2015
Monitor MPI it flashes F 13 or 14 & smells, I had it cleaned 6 months ago
The codes are "E" Codes. an E13 is no fuel. E-14 means flame rod malfunction. Unplug the heater then reconnect, this will reset the heater. Try your red prime button. Could also be the fuel pump or your fuel source feed line isn't flowing fuel.
Feb 17, 2016 | Heating & Cooling
How to fix a mpi 2400 with a e13 code how to fix
You need to have the system cleaned up.
Nov 18, 2014 | Heating & Cooling
E 13 message on my monitor 2400. What do I do?
E13 means the heater failed to ignite. This could be because of the igniter, the circuit board, a fuel or fuel pump problem, the flame rod being dirty or grounded, The air pressure switch or an overheat occurred. First check the igniter. You can measure the resistance of the igniter with an ohmmeter, it should be somewhere around 16.8 ohms. If you hear a loud ticking or thumping sound before you get the code then you have a fuel flow problem. This can be because of the filter at your barrel or the strainer in the fuel sump or an air bubble in the fuel line. A dirty flame rod can be cleaned with some steelwool or fine grit sandpaper. Unplug the heater before cleaning the flame rod. If the fuel pump ran before you got the error code then the air pressure switch is ok because the fuel pump will not run if the airpressure switch contacts are not closed.
Oct 09, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Monitor 2400 Kerosene heater service
Check your filter in the fuel line outside if you have one. Also check the strainer in the fuel sump.
Feb 02, 2010 | Heating & Cooling
E13 keeps blinking on my monitor 2400 heater
causes of E13 error code:
Failure of ignitor, solenoid pump
or circuit board.
Incorrect wiring or flame rod
touches to burner parts.
Air pressure switch or overheat
open
I recommend taking it to a qualified service center.
Unfortunately, this can be a hard problem to trace with some experience and equipment.
Hope that helps!
-Helping Hands Services-
_Fairbanks, Alaska_
Nov 21, 2009 | Heating & Cooling
What dose e13 means
error, code 13 for service man
Oct 04, 2009 | Black & Decker Heating & Cooling
We have a monitor 2400 kerosene heater, it will start up and after a few minutes at most it shuts down and starts beeping and many times has a message "error 13"
Next time you try to start the unit listen to the pump on the lower right side of the unit. Just before the E13 message if you hear a thumping noise, you have a fuel problem. If you don't hear a thumping and there is a flame you have a problem with the inside of the burner. I would say since it's a 2400 you have a fuel problem. Low fuel, no fuel, dirty filter or blocked flue pipe.
Tom Hawkins
hawkins111@gci.net
Jan 19, 2009 | Heating & Cooling
E13 code, monitor 2400
You have an obstruction in your fuel line. Lint or rust or some other debris, either in your main fuel filter which I hope you have or in the small one in the fuel sump on the lower right hand side (the little square hole below the round finger hole for the reset button). The screen is cleanable with air or brakekleen or both. Or it might be that your Constant Level Valve is tripping or has tripped. Push the button in the round hole on the lower right hand one time quickly (don't hold it down or press it several times slowly) and you should hear the float drop. Fuel should resume flowing to the fuel sump at that time.
Dec 21, 2008 | Heating & Cooling
I have a Monitor 2400 oil heater. I would like a more detailed description of all the parts for this heater. Also I would like to find a listing of the possible error (e) codes that this heater may display...
I cleaned the fuel screen located on the unit and replaced the filter on the external fuel tank. The external filter can freeze if it accumulates enough water and the temp is cold enough, or it can just get full of debris. I also unplugged the 2400 for 30 min to let the factory preset settings come back. Filter(s) caused the e14 error, preset settings cured the e13 error caused by me fooling with the start stop function so much. Thanks for the help!
Dec 10, 2008 | Heating & Cooling
Have a mpi monitor flashing a e13 code
I have a propane monitor heater just installed 2 months ago and I get an e 13 code and the heater won't stay on???
Oct 19, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Heating & Cooling Logo
219 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
