Question about Sony MegaStorage CDP-CX455 400-Disc CD Changer
Player won't play discs.. Removed cover, little carousel motor belt wrapped around shaft. Untangled and put back on pulleys but seems loose motor rotates but carousel barely moves
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Search eBay for belt replacement parts.
Posted on Jan 02, 2016
    Top Expert:
  • Sony Master
  • 12,962 Answers
U are better off getting the right belt since it will have a little give and stretch. An o ring does not and if it is a tad tight, it will be too tight on the weak motor bearings and will not turn.
If the belt you need is not for a motor that drives the actual disk but is for, say, the load mechanism, you can use a rubber band in lieu.
Posted on Apr 06, 2015
    Genius:
  • Sony Master
  • 1,054 Answers
Take the belt to your local ace hardware and find an o-ring that is slightly smaller than the belt. Install that and you should be back up and running for less than a dollar.
Posted on Apr 04, 2015
CDP cx355 cd doesn't spin
You can clean the lens with a small amount of windex and put a little oil like 3 and 1 oil on the spindle motor shaft and on the sled rails. Good luck !
Aug 13, 2015 | Audio Players & Recorders
I have a Maytag SE-1000 stacking washer dryer setup. I am trying to replace a broken dryer belt, and have the disassembly done, and the replacement belt in place. My problem is trying to understand how the...
Most dryers are tension idler pulley directed but must first go around the grooved pulley on the motor shaft. make sure the idler goes on the smooth side of the belt and the grooved side of the belt is in the grooves on the motor shaft.
Oct 13, 2013 | Maytag Dryers
Carousel will not turn
Could be a broken/loose carousel belt. take the cover off and look near the back of the unit and make sure that both belts are on there respective pulleys.
Jan 02, 2013 | Sony MegaStorage CDP-CX355 300-Disc CD...
Haier HLP21E belt broke. My machine was overloaded. How do I replace it?
put new belt on big pulley first then roll in over on smaller one
Mar 29, 2010 | Haier HLP21E Top Load Washer
Need diagram showing how to install belt belt came off need to know how it go on and how to ajust it
first jack up the right front tire side of your car and remove cover under your car motor, so you can see your pulleys from underneath your car, remove black cover where your timing chain belt is thats on the top center between alternator and powersteering pulleys, ok,looking at all your pulleys from your right side of your front end, starting from your top left is your alternator pulley,put belt on it and go underneath the motor mount to your right top powersteering pulley,then go down around the bottom right ac pulley,then to your left bottom crankshaft pulley,the back side of the belt thats on your top alternator pulley wraps around the soft edge pulley thats above your center waterpump pulley,then wrap around the idler pulley that's under your top alternator pulley,then wrap the backside of your remaining belt around the tensioner pulley that's in on your right, under your top ac pulley, use a 13 mm wrench to adjust by turning towards the back of your car so you can slide the belt on
alt ps
soft edge
idler wp tensioner
cs ac
Jul 12, 2009 | 1999 Ford Escort
I am installing a new belt but the pulley that mounts to the ground i found was not attached and i am not posotive of its correct spot i need a diagram
The idler pulley goes in front of motor shaft. There is two slits in sheet metal where it slides in. after pulley is on. put the belt around drum and pinch belt together. put belt under idler wheel then put end on motor shaft. You can push up on idler pulley to get around motor.Make sure grooved side of belt is wrapped around drum. Good Luck!!
Apr 24, 2009 | Dryers
PUT ON BLET
The belt normally wraps around the bottom of the metal platter. Put the platter back on the turntable, and you'll see holes on opposite sides of the patter. Just pinch the belt out a little, and wrap around the motor shaft - should be a brass shaft assembly.
- OPTiC
Turntable Repair Expert
Digital Analog Therapy
Dec 13, 2008 | Audio Players & Recorders
Belt sliped off dryer
If u can acess the motor there will be an idler pulley, usually with a spring that you will have to pull tight. Wrap the belt around the pulley, then the motor shaft. Release the pulley and try it.
Apr 07, 2008 | Dryers
Belt came loose
BELTS DON'T JUST FALL OFF THERE MUST BE AN UNDER LYING PROBLEM.WHEN YOU FIGURE THAT OUT TO PUT THE BELT ON GET ON YOUR HANDS AND KNEES
REACH IN ONE ARM ON EACH SIDE UNDERNEATH THE DRUM WITH YOUR RIGHT HAND GRAB THE BELT (BE SURE ITS NOT TWISTED) WRAP IT AROUNG THE MOTOR PULLEY.
HOLD IT THERE, NOW WITH THE LEFT HAND PUSH THE TENSIONER PULLEY TOWARDS THE MOTOR
THE BELT SHOULD GO OVER THE MOTOR PULLEY FROM THE RIGHT SIDE. SO IF HOOKED UP CORECTLY THE BELT WILL GO DOWN THE RIGHT SIDE OF THE TUB-AROUND THE LEFT SIDE OF THE TENSIONER PULLEY TO THE RIGHT SIDE OF THE MOTOR PULLEY THEN BACK UP THE LEFT SIDE OF THE DRUM
GOOD LUCK=)
Feb 20, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Fixing a Kenwood KD 491F turntable
The reason why the audio is low, is that todays receivers do not have a phono input, and these types of inputs are differant then the ones of today. You will need whats called a phono preamp, and one should still be available from Radio shack. Or you can go here to find out more about them: http://www.phonopreamps.com/ To reseat the belt, take off the rubber mat on the turntabe disc. Install the belt around the inside ridge, there should be a couple of holes on the platter disc. Install the patter back onto the center spindle. Turn the platter around till you see the motor pully through one of the holes in the platter. Take the belt that is around the turntable platter, and pull it over to the motor pulley. Good Luck
Jun 15, 2007 | Kenwood KD-291RC Turntable
Sony MegaStorage CDP-CX455 400-Disc CD Changer Logo
308 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
