How do I turn the lock off - Washing Machines
    Champion:
  • 208 Answers
Off on what? Please provide way more information of you want a good answer. Brand, model, type of appliance and nature of problem with what you've tried so far, are things we need to help you better.
Posted on Apr 04, 2015
WDT790SAYMO dishwasher will not start. Appears locked. Help
Control Lock On
Use the Lock to prevent your dishwasher from accidentally being turned on. Use the Lock, also, to prevent accidental cycle or option changes during a cycle.
LOCK ON
When LOCK ON is lit, all buttons are disabled.
NOTES:
The dishwasher door can be opened while the controls are locked.
You can turn on the Lock while the dishwasher is running.
To turn on the Lock:
Press and hold NO HEAT DRY for 4 seconds. LOCK ON glows.
If you press any pad while your dishwasher is locked, the light flashes 3 times.
To turn off the Lock
Press and hold NO HEAT DRY for 4 seconds. The light turns off.
If the lock light flashes constantly this indicates that a key (or keys) is most likely shorted or stuck. If this is the case the console or touch pad must be replaced. The console is only available in black (part number 3384340).
Jul 31, 2017 | Televison & Video
Where is the hole on the lock cylinder that allows the key to turn when pushing on it?
have you tried to turn the steering wheel and then turn the key? when the steering wheel is locked it will not let the key turn, try turning the steering wheel to the right and then turning the key. Sometimes when getting out of the car your leg turns the steering wheel and locks it.
Sep 17, 2015 | 2011 Hyundai Accent
I am to turn a key 1/4 turn beforekeying the lock. With a key in the lock it will not turn @ all, so a=cannot key my lock.
If you can get access to the inside of the door, the lock can be removed. Be sure you are using the correct key - try all the Kwikset keys you have. If you're completely locked out, you might need to call a locksmith.
Jul 01, 2014 | Kwikset Locks & Locksmithing
Child safety lock feature is on. how do you take it off
im not sure if your model of dryer but here is some instructions
Child lock
When activated, the child lock prevents the dryer from being operated by locking the control panel functions.
The dryer can be turned on but not started. The "Child lock" indicator will flash.
The door can be opened.
To activate the child lock
1. Make sure the dryer is turned off and
the door is closed.
2. Press and hold the "Anti-crease" and "DRYNESS" buttons at the same time, hold until step 5.
3. Turn on the dryer with the "On/Off" button.
4. Press the "OPTIONS" button 3 times. 5. Release the "Anti-crease" and
"DRYNESS" buttons.
The "Child lock" indicator will flash and the dryer is now locked.
6. Turn off the dryer using the "On/Off" button.
To deactivate the child lock Repeat steps 1. to 5.
The "Child lock" indicator will go out. The control panel is now unlocked.
Dec 15, 2012 | Bosch Washing Machines
Keypad numbers are locked on, how do i unlock??
Boot to your Bios and look in advanced for num lock and disable.
or
go to run in the start menu.
typ: regedit.
Go to: HKEY_USERS\.Default\Control Panel\Keyboard
Then String value- InitialKeyboardIndicators right click click modify then choose a number below.
Explaination numbers.
0= Truns Off, Num Lock, Caps Lock, Scroll Lock
1= Turns On Caps Lock,
2= Turns ON Num Lock,
3= Turns On Caps Lock, and Num Lock
4= Turns ON Scroll Lock
5= Turns on Caps Lock, and Scroll Lock
6= Turns On Num Lock, and Scroll Lock
7= Turns On Caps Lock, Num Lock, and Scroll Lock
Hope this helps.
Feb 07, 2010 | Acer TravelMate 4230-6499 Notebook
My key wont turn in the ignition.
If your Steering Wheel is TURNED and Hard Against the Lock the Key will not Turn. Try turning the Steering Wheel Slightly in the direction that it will turn. This will allow you to turn the Key. This is a very common condition regardless of the make where a Steering Lock is also the Ignition Lock. Before Locking the Lock it is always best to turn the wheel in the opposite direction from any turn you made prior to Shut Down and Lock. It doesn't take much but it will ensure that you can Unlock it for the next usage.
Dec 07, 2009 | 1999 Jeep Grand Cherokee
Display reads OPEN LOCK when I try to open dvd tray.
Samsung Home Theater Systems have a Dealer Lock or Tray Lock Function that prevents the disc tray from being opened.
There are four procedures for turning off the Dealer Lock function. Try one, then the other, to see which works on your system.
Unlocking Procedure 1 To turn off the Dealer Lock function, follow these steps:
  1. Turn on your Home Theater System.
  2. Press the Stop button on the front panel and the Power button on the remote control simultaneously for four seconds.
Note: Repeating the two steps above turns the dealer lock on again.
Unlocking Procedure 2 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Function button on the front panel for 3 seconds. The display shows the word Unlock.
Unlocking Procedure 3 To turn off the Dealer Lock function, follow these steps
  2. Press and hold the Open/Close button on the DVD player on the front panel for more than 4 seconds.
Note: Repeating the two steps above turns Dealer Lock on again.
Unlocking Procedure 4 To turn off the Dealer Lock function, follow these steps
  1. Using the HTS remote press the Menu button + 712, and the HTS will display CAN OPEN.
The Dealer Lock feature is mainly used by retailers to ensure that the display discs are not removed. However, parents of young children may find this feature very useful as well.
Jun 26, 2009 | Samsung HT-DS610 System
CAPs lock key is on al the time
When you start your PC, Num Lock, Scroll Lock, and Caps Lock don’t automatically toggle on. You can automatically turn each of them on or off whenever your PC starts, for all accounts on the PC. As a practical matter, most people probably want to have only Num Lock automatically turned on, but this Registry hack gives you the power to force any combination of keys on or off.
Start>Run then type in "regedit" whithout quotes.
HKEY_USERS.DefaultControl PanelKeyboard.
3eaaaca.jpg Find the String value
InitialKeyboardIndicators. By default, it is set to 0, which means that Num Lock, Scroll Lock, and Caps Lock are all turned off. Set it to any of the following values, depending on the combination of keys you want turned on or off:
0 Turns off Num Lock, Caps Lock, and Scroll Lock
1 Turns on Caps Lock
2 Turns on Num Lock
3 Turns on Caps Lock and Num Lock
4 Turns on Scroll Lock
5 Turns on Caps Lock and Scroll Lock
6 Turns on Num Lock and Scroll Lock
7 Turns on Caps Lock, Num Lock, and Scroll Lock
Exit the Registry. When you restart, the new setting will take effect.
Note: You have problem with Caps Lock so just modify Caps lock option on Regedit.
And do not forget to run virus scan on your computer once you are done.
Rate always the all answers.
Thank you
Jan 02, 2009 | EzKey EZ8000 Smart Office Keyboard PS2
Mitsubishi Galant 2000 Glove Box Lock
First off you will need your key to the lock and a 1/8" flat blade screw driver.  Notice that your lock only turns 1/4 rotation, after doing this procedure you will be able to turn the lock an extra 1/4 turn counter clock-wise (when viewed from the front of the latch).
Turn the lock so it is vertical (perpendicular to the latch itself (counter clock-wise)).  Turn the latch around so you can view the back and the lock is to your left.  Above the lock there is a slot that you can put your screw driver into (not the indention in the metal).  You need to insert your screw driver and listen very closely, you should hear your screw driver hitting the metal latch.  Once you push the latch down with your screw driver, turn the lock another 1/4 turn with your key from the front (counter clock-wise looking from the front).
Once the lock has been turn a full 1/2 turn, you should be able to push the lock out from the back of the latch.
To put the lock in the new latch, you have to have your key in the lock.  Put the lock in the latch with the one pesky keep latch facing the handle used to open the glove compartment.  Once the lock is in the new latch, turn clock-wise until you can't anymore (1/2 turn).
You're done my friend!
Oct 11, 2008 | 2000 Mitsubishi Galant
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
