Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
Picture flickers every few minutes - RCA D52W20 52" Rear Projection HDTV-Ready Television
  • RCA Master
  • 1,536 Answers
There are several possibilities. This model is based on CRT (picture tube) technology, and has a high voltage circuit. This circuit consists of three heavy wires, one from the side of each picture tube (red, green and blue) going to a single connection block. There is another heavy wire from this to the high voltage transformer on one of the circuit boards.
First, unplug the set, and wait 20 minutes to make sure everything is cool and residual high voltage charge has drained away. Check the wires at the connection block to make sure they are not loose. There is usually some sort of retainer clip to lock the wires in place, make sure these are not broken or unlatched (sometimes they get brittle with heat and aging). Frequently these are covered with a thick layer of dust held on by electrostatic attraction; gently vacuum this off. If all looks good, plug in the set, and wait until it's dark outside. Turn on the set with the room lights off, and look at the high voltage parts. If you see a blue corona glow or sparking, that part has an insulation breakdown problem or a bad connection. It is normal to see an orange glow at the bottom of each picture tube, and you would also see the three colors of the picture coming out of the tops of the picture tube. WARNING: do not touch the interior of the set while it is on, especially not in the dark.
Another probable cause is a cracked solder connection on the power/deflection board (the one with the high voltage transformer on it). If the flickering is one color rather than white or a momentary darkening, the problem is in one picture tube circuit (yellow -> blue dropout; ->cyan -> red dropout; magenta -> green dropout). The picture tube circuit includes not only the high voltage (second anode) section, but also the picture tube drive connection on the base of the tube all the way back to the video processor and switching circuits.
Posted on Apr 17, 2015
I have a Zenith Z50PT320 plasma tv. After a few minutes the picture turns very posterized and flickers. Should I replace the Main Logic CNTRL T-Con board?
There is no T'Con board to Plasma TVs. Flickering can be of many reasons. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Dec 09, 2016 | Zenith Televison & Video
Samsung television flickers to bright white fuzzy picture
In such cases, we have to ensure that it is not the input device that is causing this problem. So, please switch your input device to something you are sure, works. If you notice same problem, look for loose contacts in inter connecting cables and jacks. If problem persists, please refer it to a qualified service technician.
Jul 28, 2012 | Televison & Video
Vizio P42HD, ok for a few minutes then flickers, picture looks "solarized" then goes blank. Flickers on/off at random intervals. May stay good for minutes to hours, may stay bad for minutes to hours, or...
Disconnect the Z sustain board ribbon cables that go to the display and clean them with a small amount of acetone, ( nail polish remover ). ONLY THE COPPER TIPS ON THE RIBBON.....NOT THE RIBBON. Put those back in and do the same with the Y.
Z on the right Y on the left..
Oct 21, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
42HP95 TV screen flickers off/on
Can be either one of three things 1) logic board, power supply, or unfortunately most likely is your panel. But if I were you I'd get a hold of Toshiba warranty center to diagnose because then they could check voltages with toshiba tech support.
Aug 23, 2009 | Toshiba 42HP95 Television
Picture often flickers and image distorts every few minutes
The trouble is most likely in the Video processor. If the trouble looks like its tearing the video only from side to side it may be the line doubler circuit. Some of these boards are no longer available but a good TV tech may be able to componnent level repair it for you.
Apr 15, 2009 | Toshiba TP50H95 50" Rear Projection...
Compaq 7550 monitor keeps turning pink. Works fine for a few minutes then back to pink and hard to see. Sometimes moving the mouse quickly will help but only for a few minutes. Have tried adjusting all...
Defective CCFL backlight may has the following symptom:
· Screen flashs on red/pink and off.
· Picture stays on in red and slowly be come normal.
· Picture flickering with dim display.
· Picture flickering on and off.
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp)
has reached the end of the life and all you need to do is replacing the CCFL lamp.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
Samsung LCD TV, no picture only sound
is the picture clear when on? if yes, does the screen go black after a few seconds. if yes, sounds like you need a back light inverter!
Sep 13, 2008 | Westinghouse LTV-30W2 Television
Flickering picture
Can you please check the model number, what is listed is not valid for a Sony. This could be a simple fix or something expensive. With the model number, I can provide you with details.
Thanks,
Dan
Apr 16, 2008 | Televison & Video
RCA TV flickering problem
Your tv has a video problem, leak capacitor in video section, near in flyback need to replace it.
Apr 14, 2008 | RCA L46FHD37 46 in. LCD HDTV
Picture Flickers
there is a surface mount 9v regulator location # IC2925 i think. part # BA09FP that part is mostly likely the problem. it is located on the board right behind the video inputs. on the bottom right corner(looking at from back)
Feb 21, 2008 | Mitsubishi WS-55613 55" Rear Projection...
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
129 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
