Question about Garden
Idc cultivitor 400 I need an engine to replace one that was on this machine any
2 Suggested Answers
ka4iup
  • 3957 Answers
SOURCE: idc cultivitor 400 I need an engine to replace one that was on this machine any suggestions?
Try a google search on both the unit and the engine alone. Once you identify the type of engine and specs, you can usually find a replacement through google, amazon, or a garden equipment repair facility.
Posted on Mar 31, 2015
Idc cultivitor 400 I need an engine to replace one that was on this machine any suggestions?
Mar 31, 2015 | Garden
Indesit 123 FAULT F06
I had this error and engineer said the meaning of the codes on the web are wrong as they don't like to disclose their real code meanings for pure protectionism reasons. F06 on IWD7145 is a burnt out door interlock IDC error. He replaced the part number C00085194 (replacement door interlock) and microritardator part number 085194 and it works ok now.
Sep 06, 2012 | Indesit W 123 Front Load Washer
I need parts for the IDC 400 31cc cultivator
ordertree.com has them for abt 50 dollar. part 753-04125, I believe its a mtd part. plus abt 10.00 shipping
Aug 25, 2012 | Yard Machines Cultivator
Need the code for Blaupunkt IDC A09
Ask here for free advice and code
www.ukbookshelf.co.uk
Jun 12, 2010 | Blaupunkt IDC-A09 5-Disc CD Changer
Machine status P-9 what is this message?
Black Imaging Unit failure
• All density readings taken from the density pattern produced
on the Transfer Belt are 0.5 g/m2 (IDC Sensor
photoreceiver output) or less during max. density
adjustment (Vg/Vdc adjustment).
on the Transfer Belt are 4.5 g/m2 (IDC Sensor
Photoreceiver output) or more during max. density
adjustment (Vg/Vdc adjustment.)
Remove and reset the Black Image Unit. If this doesn't help the Image Unit may need to be replaced.
May 25, 2010 | Konica Minolta bizhub C250 All-In-One...
Entered code says wait 1 hour
When you add an IDC-A09 changer to a pre-2004 car, you should not need to enter any code, it should just plug and play. If you have added an IDC-A09 changer to a post 2004 car the you have probably got the wrong changer. Post 2004 cars *usually* need the IDC-A04 changer, which looks identical.
The IDC-A04 uses CAN-bus while the IDC-A09 uses VAN-bus wiring. The two are not interchangable.
Apr 03, 2010 | Blaupunkt IDC-A09 5-Disc CD Changer
Peugeot 307 Blaupankt CD Changer IDC-A09
Hi, I know this is an old post, but I'll reply, so that other readers may get the benefit of my answer.
2004 was the year that Peugeot/Citroen changed from VAN bus to CAN bus wiring on their stereo's. If your car is before or early 2004 you will need the IDC-A09 blaupunkt in dash changer, which should just plug in and work straight away.
However, If your car is later 2004 onwards you will need the IDC-A04 Blaupunkt changer which will plug in and power up, but will not work properly untill you go to a peugeot dealer and they hook up some diagnostic software to tell the car a changer has been added. Both the IDC-A04 and A09 changers look identical.
I would say that you got the wrong changer, as the IDC-A09 changers in pre/early 2004 should just plug in and work.
Remember: Pre 2004 cars need IDC-A09 (plug and play) and Post 2004 cars need IDC-A04 changer (get pug dealer to reprogram cars computer)...its a costly mistake if you bought the wrong one!
Oct 28, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
CD Changer Blaupunkt IDC A09
EBK zeewolde can get code out of serial number
coast 25 / 30 euro
i try to get code for cdc on my vistion radio cd
and try to use disconnect l / r output cdc and place mp3
signal to radio input when cdc turns
greets wilco1v @12move.nl
Aug 02, 2008 | Blaupunkt IDC-A09 5-Disc CD Changer
B420 konica minolta
Check the following , Dirt of IDC sensor, Clean up the IDC sensor, if no then Printer control board abnormality Replace board
Jun 19, 2008 | Konica Minolta Office Equipment & Supplies
Garden Logo
53 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
