F8 code imdicates gets off after 5 minutes working
    Problem Solver:
  • 19 Answers
There are timeout settings for F8 options at startup just press arrow keys to move it up/down and the timer will go away until you restart the computer.the timer can be customized but in your case its not needed as you just need to press arrow keys to hold it.
Posted on Apr 04, 2015
Duet. What does F8E1 code indicate needs to be done to restore operation?
Check out the Link and the info below.
Question: Front Load Washer - Error Code - F8 E1 or LO FL Answer Product Symptom:
F8 E1 or LO FL Code in display:
No water detected entering washer after 13 minutes, the pressure switch input has not been detected.
If the washer has an F8 E1 error or LO FL error, the door will be locked, and the control will be unresponsive. The washer will start a drain routine which takes approximately 8 to 10 minutes, during which time the pump will run continuously. The control will not accept any input during this time. Please wait 10 minutes before trying to perform any functions.
Check the water supply:
Turn on the water. Check the household water supply to see if the hot and cold water faucets are turned on. Make sure to open both faucets completely for proper fill.
NOTE: Both Hot and Cold water must be supplied to the washer.
Whirlpool recommends that appliances be direct connected to the water supply for optimum machine performance.
If a "flood saver" device is being considered:
  • Check with the manufacturer of the device to ensure it will not affect the performance of the appliance.
  • Whirlpool has experienced that "flood safety" devices can interfere with the performance of the appliance. Whirlpool typically does not recommend these devices.
Two types of "flood-saver" devices, hoses and valves are illustrated below. anti%20flood%20hose%202.jpeg floodsafe%203.jpeg Whirlpool Duet Washer F8 Code Appliance Repair Forum
Jan 19, 2016 | Whirlpool Washing Machines
How do I run F8 on a minolta Di2010?
go in service mode (utility/counter -> stop - 0 - 0 -stop - 0 - 1 )
go in tech choice, and there you find somwhere f8, and press start. wait about 5 minuts. when start button turn blue reset the mashine.
remember never to stop the f8 procedure.
Jan 20, 2015 | Konica Minolta Office Equipment & Supplies
Error F8 on a Frigidaire AC model FASE24C6****
Good Afternoon Konrad,
I understand that you are receiving an F8 error code on your Frigidaire air conditioner, model# FASE24C6. I also see that it will work for hours before displaying F8 or sometimes only minutes before displaying the error code. The F8 tells me that there might be a key stuck. I suggest resetting your air conditioner, by unplugging it for 3-5 minutes. Plug your appliance back in and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 08, 2014 | Frigidaire Heating & Cooling
What must we do to rectify an F8 fault?
I went to the roof and turned the unit off, waited a minute and turned it back on and the unit worked fine after that. It was a power failure that messed ours up.
Jun 03, 2014 | Carrier 36KCARMS Air Conditioner
AEG Oven model D98000VF - error code F8 on display. All functions failed (no grill,ovens,hob)
I am pretty sure this is the temerature probe that has failed it can also be a failure of the main control board see how you get on but resubmit question if in bother.Hope I helped.
May 02, 2010 | Electrolux Ovens
Runnung windows XP SP2 - 2 or 3 minutes after booting up my computer goes to the ''blue screen of death'' and displays the following error code. stop: 0x000000F4 (0x0000003, 0x85D1F7B8, 0x85D1F92C,...
Unplug all the components plugged to the computer after 2-5 mins you can plug them back and then try to press F8 on start up, select Last known good configuration, and turn press enter. If it works fine, if not then turn off again and then press F8 on startup go to safe mode and then try to do system restore. ( start - all programs - accessories - system tools - system restore ) select a date before the day when the problem started. It will not effect yous saved files, and will help you to fix your problem.
Feb 26, 2010 | Computers & Internet
My vostro 1760 laptop shows power but a black screen Also I cannot switch it off I can hear it running but nothing I do will switch if off I was working on it & didnt realise the battery was at a...
How do you switch off you laptop? Try this press and hold on the power button for about 5 seconds. So it won't boot to windows? When you turn on the laptop and you see the dell logo keep tapping on F8 then try booting in safe mode, if fails do F8 again then last known good configuration, if fails do F8 then startup repair, if fails do F8 then system restore, if all fails reinstall os. but before all these steps try to test hdd first. make sure laptop is off. press and hold on the Fn key then press power button. Run the PSA test and once it finish it will show you some errors code like 0142 -0146 means hdd needs to be replaced.
Sep 23, 2009 | Computers & Internet
I have Fridigaire double oven part# PLEB27T8ACA with F8 code prob
wow, that is so weird...i was just getting ready to write the exact same thing. this last time mine beeped, i just kept letting it beep for several minutes. if kept on. i then went in and pressed all the buttons except for cancel and nothing happened. then i pressed the oven light button. the beeping stopped. not sure if it's coincidence or if that was what i was supposed to press. i will keep messing with the buttons and let you know if i figure it out. i will dread if it beeps all night long.
Feb 14, 2009 | Frigidaire PLEB27T9DC Electric Double Oven
" LOCK CODE ENTERED INCORRECTLY 5 TIMES. CODES WILL UNBLOCK IN 5 MINUTES"
When u enter wrong security code at least 5 times
Cell phone not working situation in Next 5 minutes.
Solution..................
Remove the battery at least 7 to 10 minutes and enter Correct security code and enjoy...
Awais Shahid
Dec 20, 2008 | Nokia N73 Cellular Phone
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
