SOURCE: Alignment of Tocuh Screen Panle of Canon Copier IR-6000/6001
I believe under the aditional funcation screen, you can calibrate the touch screen. Is the screen working at all? Does it look like there is Water on it and you can not wipe it OFF. If so, the display screen is cracked and needs to be replaced.
SOURCE: imageRUNNER 400S Copier: Canon IR 330-400 Ps Ver 1.0 i keep getting the ...
E-100 is an error of the Laser Beam detect PCB. Either the laser unit is not working or the beam detect PCB is not detecting the beam. You can't see the beam so don't try. Since you are also getting a E-220 which is a Scan Lamp error. Most likely cause is a ribbon cable between the CCD unit and Image Processor PCB. You may need a tech to trouble shoot this problem
SOURCE: Solution for canon ir 2520 error code E000020
E020 0000
The path between the sub hopper and the developing
assembly is clogged with toner.
1.Check the rotation of hopper motor gear. (If rotating, false
detection by the sensor is doubted. Feed the toner to the
developing unit in service mode: CLEAR>ENGIN>TNRINST.)
2.Replace the Developing Assembly Toner Sensor (TS1).
3.Replace the Sub Hopper Toner Sensor (TS2).
4.Replace the DC Controller PCB (PCB4).
SERVICE MODE:
* 28 * or MENU and #
SOURCE: frozen touch screen by canon ir-4570
Its PDA(touch screen) is faulty contact cannon for new Display or PDA jack is loose
SOURCE: canon iR 2520 toner install problem.
u can go in service mode by pressing additional function + 2+8 then go in clear by pressing scrolling, then go in engine. after press ok in tnrinst. machine will process for 2 minutes. for toner installation.
you can recalibrate the touch screen. from my experience it doesnt hold very long the lcd touch screen needs replaced
