Question about Ovens
Is there a way to fix what seems to be a sprung hinge?
    Problem Solver:
  • 9 Answers
If you are saying the door no longer returns to its upright position on it's own than the spring broke, the hinge is fine so long as it travels the same path.
Just google: "oven door spring XXXX" where the x's are your model number.
Posted on Apr 04, 2015
How do you remove the door?
the spring is sprung now and will need to be replaced
Jan 10, 2016 | Ovens
Need fitting instructions to replace door hinges as manual misplaced. thank you.
The user manual probably wont have instructions for replacing your door hinges anyway. The service manual would, but they don't generally supply those with the oven.
I'd need to know the brand and model of your oven in order to give advice on fitting, as would any other expert here. Some ovens have sprung tension hinges, others have pivot/swing hinges.
Oct 10, 2010 | Neff B1421 Electric Single Oven
Oven door seems sprung as if a spring may be shot and door dose not close all the way?
You need to replace both oven door hinges, as the springs are weak, and there is no adjustment available.
Sep 25, 2010 | Cadco OV-400 Electric Single Oven
Kenmore 790.49073400 oven door won't close completely
Hello- You are on the right track. The hinge assemblies are 'sprung' or bent out of shape. Replacing them is pretty easy, so you can do it yourself. Four screws on each side. Be careful, these springs can snap closed and bite ya. Use the little pins that come with the new set to lock hinge so this doesn't happen. Let me know if this info helps- have more if needed- Thanks- Ed
Mar 19, 2010 | Kenmore Ovens
Oven door won't completely shut
either the hinge screws are lose or the door is sprung! and needs to be readjusted
Jan 20, 2010 | Ovens
I have a Kitchen Aid oven, model #KEBS107DWH2 and the hinges are "sprung" so the door will not close all the way to turn off the oven door sensor, unless you prop something up against the door. That said,...
You are very lucky if that machine lasted as long as it has. if you replaced those hinges in 2007 that's 10 years. The last one i bought they said we will be lucky if we get five to ten years out of the new one. Unless you want to put money in this one its probably cheaper to buy a new one in the long run.
They could not care less if you tell them you won't buy anything from them again. I had a large company official tell me that.
Apr 08, 2017 | KitchenAid Ovens
My husband did not put a nail (or something) into the hinge when we took off the oven door and the hinge sprung into the walls of our RV Magic Chef oven. How do I retrieve the hinges so I can take the...
this is a serious pain
down a few hundred of these overe the years
ok you will need long needle nose pliers
and a sturdly flat head screw driver
try to reach it with the needle nose
and usae the flat head as a pincher try to work it behind the hinge
these springs are 110 lbs so it will take some effort to get them out
short of this you will need to drop them out of the cavity on each side of the drawer
Oct 07, 2009 | Ovens
Door hinges appear to be sprung
pull up alittle on door then back down to seat the hinge
unless you put something heavy on door , this should work
Mar 02, 2009 | Frigidare FGB24S5DC Gas Single Oven
Ovens Logo
66 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
