Question about Delphi 1995 - 1997 Dodge Stratus Fuel Pump Strainer FS0088 Dodge Fue
What does it mean when u turn ignition and just aclick noise and if you keep trying it will evenually stat .?
Before this happened it did the sam thing but everything went dead and it was igniton fuse.we replaced it and it was fine now it s noot dead everything stays on just keep turning it till it works not sure what to get a switch or starter help.
  • Delphi Master
  • 3,519 Answers
Hi Linda:
There are several possible problems so working through them should solve the problem. What I would be thinking is that you're not getting nough power to the starter, so let's try finding why:
1) Are the connections on the battery nice and clean?
2) Is the engine ground cable securely attached?
3) Is the battery fully charged?
4) Is the solenoid working properly? If you short across the terminals and it starts every time ....Ta Da!!!
5) Is the starter the problem? Hopefully not because it's the biggest pain.
Let us know what you find.
Posted on Apr 04, 2015
    Sergeant:
  • 333 Answers
Hello Linda, I would clean both battery terminals and cables.
How do I check for a short when battery cable is connected
The clicking noise from fuse box is probably a relay! Nothing happening could mean anything! Without turning the ignition can you turn on headlights, does the inside light come on when you open the door, horn work?
Nov 02, 2014 | 2005 Pontiac Grand Prix
My heater keeps clicking and trying to turn off, but pops right back on before it acutally shuts down. The little control box next to the fuel heater is the noise maker
Will it shut down if you unhook the t-stat wires???
If so then the problem is not in the heater...
Other wise you may have a t-stat/wiring problem....
turn down the t-stat and check if it stops....
then if it goes like that when the t-stat is calling for heat the flame sensor of the t-stat is bad...
My first iclination would be the flame sensor and/or ignition control...
heatman101
Dec 28, 2010 | Heating & Cooling
My bike makes starting noise but it won't turn
if you hear a spinning noise then the starter needs replaced, aclicking noise means u need a battery.
Jul 27, 2010 | 1998 Suzuki VS 800 Intruder
Tv will not turn on
If you hear a clicking noise that sounds like the ballast trying to power on the lamp, but nothing happens, the lamp may be faulty.You can go to http://www.discount-merchant.com/
to purchase a quality lamp.
Mar 26, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Would not start - growling/clicking noise - evenually started - same thing this morning - had to take different vehicle to work. I kept trying last night and eventually it started - then took it to several...
Replace the battery it has a bad cell. When you got it started the vehicle charged it long enough so it would start for your mechanic. But it needs a battery.
Oct 23, 2009 | 2008 Chrysler Pt Cruiser
1990 1200xl sport not starting
Is the clicking noise coming from the starter? If it is I would say your bendix is shot and needs to be rebuilt.
Apr 28, 2009 | Harley Davidson XL 1200 S Sportster Sport...
Steering colom will not let key turn
Try this if steering wheel is turned slightly to one side meaning front wheels turn steering wheel to that sam side take strain off the lock in steering column and key should turn. I believe that the steering wheel is locked. If it doesn't work turn left or right and try again. Good Luck and contact if you need more help.
Jan 05, 2009 | 2005 Nissan Titan
Delphi 1995 - 1997 Dodge Stratus Fuel Pump Strainer FS0088 Dodge Fue Logo
Top Delphi GPS Experts
Vernon Taylor
Are you a Delphi GPS Expert? Answer questions, earn points and help others
